Data sheet | Item number: 2636-1103/020-004
PCB terminal block; 16 mm²; Pin spacing 10 mm; 3-pole; Push-in CAGE
CLAMP®; special version; 16,00 mm²; black
www.wago.com/2636-1103/020-004
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/7
Dimensions in mm
L = (pole no. – 1) x pin spacing + 11.6 mm
Item description
PCB terminal strips with Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled conductors
Ideal for panel feedthrough applications via operation parallel to conductor entry
Testing can be performed both parallel and perpendicular to conductor entry
Hansastr. 27
32423 Minden
13.10.2021 Page 2/7
Data
Notes
Variants:
Other pole numbers
Direct marking
Other colors
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
1000 V
Rated surge voltage (III/3)
8 kV
Rated voltage (III/2)
1000 V
Rated surge voltage (III/2)
8 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
8 kV
Rated current
76 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
66 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
66 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
600 V
Rated current CSA (Use Group B)
66 A
Rated voltage CSA (Use Group C)
600 V
Rated current CSA (Use Group C)
66 A
Connection data
Total number of connection points
3
Total number of potentials
3
Number of connection types
1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.75 … 16 mm² / 18 … 4 AWG
Fine-stranded conductor
0.75 … 25 mm² / 18 … 4 AWG
Hansastr. 27
32423 Minden
13.10.2021 Page 3/7
Fine-stranded conductor; with insulated ferrule
0.75 … 16 mm²
Fine-stranded conductor; with uninsulated ferrule
0.75 … 16 mm²
Fine-stranded conductor; with twin ferrule
0.75 … 6 mm²
Strip length
18 … 20 mm / 0.71 … 0.79 inch
Conductor connection direction to PCB
0 °
Pole No.
3
Physical data
Pin spacing
10 mm / 0.394 inch
Width
31.6 mm / 1.244 inch
Height
32.6 mm / 1.283 inch
Height from the surface
28.6 mm / 1.126 inch
Depth
29.1 mm / 1.146 inch
Solder pin length
4 mm
Solder pin dimensions
1.2 x 1 mm
Drilled hole diameter with tolerance
1.7 (+0.1) mm
Mechanical data
Mounting type
Feed-through mounting
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (staggered)
Number of solder pins per potential
3
Material data
Color
black
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Weight
25.6 g
Environmental
requirements
Hansastr. 27
32423 Minden
13.10.2021 Page 4/7
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
PU (SPU)
50 Stück
Packaging type
box
Country of origin
PL
GTIN
4055143765992
Customs tariff number
85369010000
Optional accessories
Tool
Operating tool
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-721
Ferrule
Ferrule
Item no.: 216-210
Ferrule; Sleeve for 16 mm² / AWG 6; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-210
acc. to DIN 46228, Part 4/09.90; blue
Item no.: 216-284
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-284
Item no.: 216-286
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-286
Item no.: 216-287
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287
acc. to DIN 46228, Part 4/09.90; gray
Item no.: 216-288
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-289
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-289
acc. to DIN 46228, Part 4/09.90; red
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
Hansastr. 27
32423 Minden
13.10.2021 Page 5/7
2.0 MB
CAD/CAE-Data
CAD data
2D/3D Models 2636-1103/020-004
URL
Download
URL
Download
URL
Download
PCB Design
Symbol and Footprint 2636-1103/020-004
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 2636-1103/020-004
Hansastr. 27
32423 Minden
13.10.2021 Page 6/7
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2636-1103/020-004
PCB terminal block; 16 mm²; Pin spacing 10 mm; 3-pole; Push-in CAGE CLAMP®;
Installation Notes
Conductor termination
Insert fine-stranded conductors and remove
all conductors via operating tool
Insert solid or ferruled conductors via pushin termination
Hansastr. 27
32423 Minden
13.10.2021 Page 7/7
很抱歉,暂时无法提供与“2636-1103/020-004”相匹配的价格&库存,您可以联系我们找货
