Data sheet | Item number: 2706-160
PCB terminal block; lever; 6 mm²; Pin spacing 7.5 mm; 10-pole; CAGE
CLAMP®; commoning option; 6,00 mm²; gray
www.wago.com/2706-160
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/11
Dimensions in mm
L = pole no. x pin spacing
Item description
High-current PCB terminal strips with lever-actuated CAGE CLAMP® connection
Tool-free termination – fingers open/close levers
Several clamping units can be held open simultaneously – convenient for terminating multi-core cables
Two solder pins per contact point for high mechanical stability
Versions with optional commoning for distributing potentials
Hansastr. 27
32423 Minden
07.10.2021 Page 2/11
Data
Notes
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Other colors
Mixed-color PCB connector strips
Direct marking
Electrical data
Ratings per
IEC/EN 60664-1
Ratings (note)
Using adjacent jumpers, the rated voltage is reduced to 400 V with
7.5 mm pin spacing in Category III/3.
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated voltage (III/2)
630 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
41 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
30 A
Rated voltage UL (Use Group C)
150 V
Rated current UL (Use Group C)
30 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
30 A
Connection data
Total number of connection points
10
Total number of potentials
10
Number of connection types
1
Number of levels
1
Number of jumper slots
1
Connection technology
CAGE CLAMP®
Actuation type
Lever
Solid conductor
0.5 … 6 mm² / 20 … 10 AWG
Fine-stranded conductor
Hansastr. 27
32423 Minden
07.10.2021 Page 3/11
Fine-stranded conductor; with insulated ferrule
0.5 … 6 mm²
Fine-stranded conductor; with uninsulated ferrule
0.5 … 6 mm²
Strip length
11 … 12 mm / 0.43 … 0.47 inch
Conductor connection direction to PCB
30 °
Pole No.
10
Physical data
Pin spacing
7.5 mm / 0.295 inch
Width
75 mm / 2.953 inch
Height
30 mm / 1.181 inch
Height from the surface
25.5 mm / 1.004 inch
Depth
30 mm / 1.181 inch
Solder pin length
4.5 mm
Solder pin dimensions
1 x 1.4 mm
Drilled hole diameter with tolerance
1.8 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
1.079 MJ
Weight
57.5 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial
data
Hansastr. 27
32423 Minden
07.10.2021 Page 4/11
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
15 Stück
Packaging type
box
Country of origin
PL
GTIN
4050821093190
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2143801.01
CCA
EN 60947-7-4
NTR NL7869
CCA
EN 60947-7-4
71-117469
CSA
C22.2 No. 158
2516072
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1059
E45172
UL-Approvals
Logo
Optional accessories
Jumpers
Jumper
Item no.: 745-380
Hansastr. 27
32423 Minden
07.10.2021 Page 5/11
Item no.: 745-380
Jumper; 10-way
www.wago.com/745-380
Item no.: 745-382
Jumper; 2-way
www.wago.com/745-382
Item no.: 745-381
Jumper
www.wago.com/745-381
Item no.: 745-385
Jumper; 5-way
www.wago.com/745-385
Item no.: 745-383
Jumper; 3-way; silver-colored
www.wago.com/745-383
Item no.: 745-384
Jumper; 4-way
www.wago.com/745-384
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-107
Ferrule; Sleeve for 4 mm² / AWG 12; uninsulated; electro-tin plated
www.wago.com/216-107
Item no.: 216-108
Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-108
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Ferrule
Ferrule
Item no.: 216-121
Hansastr. 27
32423 Minden
www.wago.com/216-121
07.10.2021 Page 6/11
Item no.: 216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-207
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; gray
www.wago.com/216-207
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-205
Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow
www.wago.com/216-205
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-208
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
Hansastr. 27
32423 Minden
www.wago.com/216-224
07.10.2021 Page 7/11
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-246
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-246
Item no.: 216-266
www.wago.com/216-266
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-286
www.wago.com/216-286
Item no.: 216-287
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-288
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267
Testing and measuring
Testing accessories
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Hansastr. 27
32423 Minden
07.10.2021 Page 8/11
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2706-160
PCB Design
Symbol and Footprint 2706-160
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Hansastr. 27
32423 Minden
07.10.2021 Page 9/11
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 2706-160
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2706-160
PCB terminal block; lever; 6 mm²; Pin spacing 7.5 mm; 10-pole; CAGE CLAMP®;
Installation Notes
Conductor termination
To open the clamping unit, pull the operating
lever all the way back — 2706 and 2716
Series.
Inserting/removing a conductor – 2706 and
2716 Series.
Testing
Hansastr. 27
32423 Minden
07.10.2021 Page 10/11
Testing with test plug – 2706 and 2716
Series.
Commoning
Inserting a comb-style jumper bar.
Push jumper bar down firmly using a
screwdriver until it hits the backstop – 2706
and 2716 Series.
To remove the comb-style jumper bar, lift it
up using a screwdriver – 2706 and 2716
Series.
Hansastr. 27
32423 Minden
07.10.2021 Page 11/11
很抱歉,暂时无法提供与“2706-160”相匹配的价格&库存,您可以联系我们找货
