Data sheet | Item number: 2721-109/008-000
1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5
mm²; Pin spacing 5 mm; 9-pole; 100% protected against mismating; Snap-in
mounting feet; 2,50 mm²; light gray
www.wago.com/2721-109/008-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/12
Dimensions in mm
L = (pole no. x pin spacing) + 1.5 mm
L1 = 5 mm
2-pole female connectors – one latch only
Item description
Universal connection for all conductor types
Easy-to-use design does not require specialty tools
Ability to wire while mated
Simple, push-in termination of solid and ferruled conductors
Integrated test ports for testing parallel to the conductor entry
Hansastr. 27
32423 Minden
07.10.2021 Page 2/12
Coding option available
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Gold-plated or partially gold-plated contact surfaces
Electrical data
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
320 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
16 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Rated voltage UL 1977
600 V
Rated current UL 1977
15 A
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group C)
150 V
Rated current UL (Use Group C)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group C)
300 V
Rated current CSA (Use Group C)
15 A
Hansastr. 27
32423 Minden
07.10.2021 Page 3/12
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Total number of connection points
9
Total number of potentials
9
Number of connection types
1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.2 … 2.5 mm² / 24 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 2.5 mm²
Strip length
10 … 11 mm / 0.39 … 0.43 inch
Pole No.
9
Conductor entry direction to mating direction
0 °
Physical data
Pin spacing
5 mm / 0.197 inch
Width
46.5 mm / 1.831 inch
Height
19.5 mm / 0.768 inch
Height from the surface
15 mm / 0.591 inch
Depth
25.6 mm / 1.008 inch
Mechanical data
Housing sheet thickness
0.6 … 1.2 mm / 0.024 … 0.047 inch
Mounting type
Snap-in foot
Mounting type
Panel mounting
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Mismating protection
Yes
Locking of plug-in connection
Without
Hansastr. 27
32423 Minden
07.10.2021 Page 4/12
Material data
Color
light gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load
0.105 MJ
Weight
14.4 g
Environmental requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
50 Stück
Packaging type
box
Country of origin
PL
GTIN
4045454722449
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
CSA
C22.2 No. 158
2314554
KEMA/KEUR
EN 61984
2190761.01
UL-Approvals
Hansastr. 27
32423 Minden
Certificate
07.10.2021 Page 5/12
Logo
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1977
E45171
UL
UL 1059
E45172
Counterpart
Item no.721-609
1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 9-pole; 100% protected against
mismating; 2,50 mm²; light gray
www.wago.com
/721-609
Optional accessories
Tool
Operating tool
Item no.: 231-159
Operating tool; natural
www.wago.com/231-159
Item no.: 210-250
Operating tool; for MCS MINI & MIDI with CAGE CLAMP® connection; red
www.wago.com/210-250
Item no.: 231-231
Combination operating tool; red
www.wago.com/231-231
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Item no.: 231-131
Operating tool; made of insulating material; 1-way; loose; white
www.wago.com/231-131
Item no.: 231-291
Operating tool; made of insulating material; 1-way; loose; red
www.wago.com/231-291
Insulation stop
Insulation stop
Hansastr. 27
32423 Minden
07.10.2021 Page 6/12
Item no.: 231-672
Insulation stop; 0.75 - 1 mm²; dark gray
www.wago.com/231-672
Item no.: 231-671
Insulation stop; 0.25 - 0.5 mm²; light gray
www.wago.com/231-671
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Ferrule
Ferrule
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Hansastr. 27
32423 Minden
07.10.2021 Page 7/12
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Hansastr. 27
32423 Minden
07.10.2021 Page 8/12
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Testing and measuring
Testing accessories
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Item no.: 231-661
Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray
www.wago.com/231-661
Marking accessories
Marking strip
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/500-206
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/500-205
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
/500-204
Mounting adapter
Mounting accessories
Item no.: 209-148
Hansastr. 27
32423 Minden
www.wago.com/209-148
07.10.2021 Page 9/12
Item no.: 209-148
Multi mounting adapter; for DIN-35 rail; 25 mm wide; gray
Strain relief
Strain relief plate
Item no.: 734-126
Strain relief plate; light gray
www.wago.com/734-126
Mounting
Item no.: 209-137
Mounting adapter; can be used as end stop; 6.5 mm wide; gray
www.wago.com/209-137
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 2721-109/008-000
CAE data
ZUKEN Portal 2721-109/008-000
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 2721-109/008-000
1-conductor female connector; push-button; Push-in CAGE CLAMP®; 2.5 mm²; Pin
spacing 5 mm; 9-pole; 100% protected against mismating; Snap-in mounting feet;
Installation Notes
Conductor termination
Hansastr. 27
32423 Minden
07.10.2021 Page 10/12
Inserting/removing a conductor via 3.5 mm
screwdriver – Push-in CAGE CLAMP®
actuation in mated condition.
Push-in termination of solid conductors or
fine-stranded conductors with ferrule
Testing
Marking
Labeling via direct marking or self-adhesive
strips.
Coding
Hansastr. 27
32423 Minden
07.10.2021 Page 11/12
Coding a female connector by removing
coding finger(s).
Installation
Male connector with strain relief plate
Strain relief housing shown with a male
connector equipped with CAGE CLAMP®
Product family
MCS MIDI
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 12/12
很抱歉,暂时无法提供与“2721-109/008-000”相匹配的价格&库存,您可以联系我们找货
