2734 Series 1-Conductor Female Connector
WAGO “Leverlution”
Page 1
2734 Series Rollout March 2022
Internal
MCS MINI with lever 2734 Series - Initial Range
1-Conductor-Female
Connector
1-Conductor-Female
Connector with centered
interlocking
4-8, 10, 12 & 16 poles
2-8, 10, 12 & 16 poles
Page 2
Internal
Pin spacing 3.5mm
Phoenix will have 3.81mm
Rated current 10 A
Phoenix will have 8 A
Height 10 mm only !!
Phoenix 12.5mm
Universal Push-In Cage Clamp for all type of conductors, flexible
or solid
Conductors from 26 to 14 AWG
Available pole numbers for product launch
2- to 8-poles, 10-, 12- and 16-poles
100% protection against mis-mating
Test port to contact a probe for testing, from top-side
Marking with direct printing from wire entry or top-side,
our self-adhesive marking strips can be used alternatively
Coding system for individual coding , No molded coding fingers
but a carrier for coding fingers to do field-side coding
Accessories:
Jumper push-in type 2-way
Coding pin carrier
2734-402,
2734-505
Page 3
Internal
Supplementary Catalog 2021 / 2
Page 4
Internal
Page 5
Internal
Page 6
Internal
MCS MINI with lever 2734 Series - Conductor
termination & removal
Direct push-in of solid conductors
Flexible conductors with lever
operation
Direct push-in of flexible conductors
with ferrules
Removal of conductors with lever
operation
Page 7
Internal
MCS MINI with lever 2734 Series - Coding
MCS MINI female connectors with lever - standard
suffix / 0327-0000 will come without coding fingers
Where Field Coding is required a separate Carrier
with coding fingers has to be used.
Page 8
2734-505 Coding carrier
Internal
MCS MINI with lever 2734 Series - Printing
Direct Printing from wire entry side
Direct Printing from top side
Page 9
Internal
MCS MINI with lever 2734 Series - Testing
Range for Testing (45°- 90°)
Testing from top side ( 90°)
Test pin 1mm
735-500
Page 10
Internal
MCS MINI with lever 2734 Series - Jumper
Direct push-in of jumper
Removal of jumper
2734-402 Jumper push-in type 2-way, 10 A
Page 11
Internal
MCS MINI with lever – Competitor products
LPC 1.5/ … -ST-3.81mm
Height 12.55 mm!!
Pin Spacing 3.81mm
8A
Height 9.95 mm!!
Pin Spacing 3.5mm
10 A
2734-1106/0327-0000
3.5mm
Page 12
Internal
Internal
很抱歉,暂时无法提供与“2734-1106/327-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+56.498132+6.75990
- 10+55.8487310+6.68220
- 30+55.2921030+6.61560
- 75+54.9210175+6.57120
- 200+54.08606200+6.47130
