2734-1107/327-000
2734-1107/327-000
    WAGO(万可电子)
    7 针位端子块 插头,母插口 0.138"(3.50mm) 180° 自由悬挂
2734-1107/327-000 数据手册
2734 Series 1-Conductor Female Connector WAGO “Leverlution” Page 1 2734 Series Rollout March 2022 Internal MCS MINI with lever 2734 Series - Initial Range 1-Conductor-Female Connector 1-Conductor-Female Connector with centered interlocking 4-8, 10, 12 & 16 poles 2-8, 10, 12 & 16 poles Page 2 2734 Series Rollout March 2022 Internal MCS MINI with lever 2734 Series  Pin spacing 3.5mm Phoenix will have 3.81mm  Rated current 10 A Phoenix will have 8 A  Height 10 mm only !! Phoenix 12.5mm  Universal Push-In Cage Clamp for all type of conductors, flexible or solid  Conductors from 26 to 14 AWG  Available pole numbers for product launch 2- to 8-poles, 10-, 12- and 16-poles  100% protection against mis-mating  Test port to contact a probe for testing, from top-side  Marking with direct printing from wire entry or top-side, our self-adhesive marking strips can be used alternatively  Coding system for individual coding , No molded coding fingers but a carrier for coding fingers to do field-side coding  Accessories: Jumper push-in type 2-way Coding pin carrier 2734-402, 2734-505 Page 3 Internal Supplementary Catalog 2021 / 2 Page 4 Internal Supplementary Catalog 2021 / 2 Page 5 2734 Series Rollout March 2022 Internal Supplementary Catalog 2021 / 2 Page 6 2734 Series Rollout March 2022 Internal MCS MINI with lever 2734 Series - Conductor termination & removal Direct push-in of solid conductors Flexible conductors with lever operation Direct push-in of flexible conductors with ferrules Removal of conductors with lever operation Page 7 2734 Series Rollout March 2022 Internal MCS MINI with lever 2734 Series - Coding MCS MINI female connectors with lever - standard suffix / 0327-0000 will come without coding fingers Where Field Coding is required a separate Carrier with coding fingers has to be used. Page 8 2734-505 Coding carrier 2734 Series Rollout March 2022 Internal MCS MINI with lever 2734 Series - Printing Direct Printing from wire entry side Direct Printing from top side Page 9 2734 Series Rollout March 2022 Internal MCS MINI with lever 2734 Series - Testing Range for Testing (45°- 90°) Testing from top side ( 90°) Test pin 1mm 735-500 Page 10 2734 Series Rollout March 2022 Internal MCS MINI with lever 2734 Series - Jumper Direct push-in of jumper Removal of jumper 2734-402 Jumper push-in type 2-way, 10 A Page 11 2734 Series Rollout March 2022 Internal MCS MINI with lever – Competitor products LPC 1.5/ … -ST-3.81mm Height 12.55 mm!! Pin Spacing 3.81mm 8A Height 9.95 mm!! Pin Spacing 3.5mm 10 A 2734-1106/0327-0000 3.5mm Page 12 2734 Series Rollout March 2022 Internal Internal
2734-1107/327-000 价格&库存
很抱歉,暂时无法提供与“2734-1107/327-000”相匹配的价格&库存,您可以联系我们找货
2734-1107/327-000
    库存:5
