Data sheet | Item number: 280-565/280-319
2-conductor actuator terminal block; with colored conductor entries; 2.5
mm²; CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/280-565/280-319
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/16
Data
Electrical data
Ratings (note)
Electrical ratings are given by the fuse plug or empty component
plug housing.
Nominal voltage (III/3)
125 V
Rated current
5 A
Rated voltage (III/3) 2
250 V
Rated current 2
6.3 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
3
Total number of potentials
2
Number of levels
3
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Aluminum
Anschließbare Leiterwerkstoffe Hinweis
Terminating Aluminum Conductors
WAGO spring clamp terminal blocks are suitable for solid aluminum
conductors up to 4 mm²/12 AWG if WAGO “Alu-Plus” Contact Paste
is used for termination.
“Alu-Plus” Contact Paste Advantages:
Automatically destroys the oxide film during clamping.
Prevents fresh oxidation at the clamping point.
Prevents electrolytic corrosion between aluminum and
copper conductors (in the same terminal block).
Provides long-term protection against corrosion.
Hansastr. 27
32423 Minden
07.10.2021 Page 2/16
Using terminal blocks with CAGE CLAMP® Spring Pressure
Connection Technology, aluminum conductors must first be
cleaned with a blade and then immediately be inserted into the
clamping units filled with “Alu-Plus” Contact Paste.
For spring clamp connections with PUSH WIRE® connection
technology, WAGO recommends that the aluminum conductor first
be cleaned and then immediately inserted into the clamping unit
filled with “Alu-Plus” contact paste.
It is also possible to apply WAGO “Alu-Plus” additionally on the
whole surface of the aluminum conductor before termination.
Please note that the nominal currents must be adapted to the
reduced conductivity of the aluminum conductors::
2.5 mm² = 16 A
4 mm² = 22 A
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Note (conductor cross-section)
12 AWG: THHN, THWN
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Wiring direction
Front-entry wiring
Physical data
Width
6 mm / 0.236 inch
Height
80 mm / 3.15 inch
Depth from upper edge of DIN-rail
55.5 mm / 2.185 inch
Mechanical data
Design
angled
Mounting type
DIN-35 rail
Marking level
Center marking
Material data
Color
gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.268 MJ
Weight
12.5 g
Hansastr. 27
32423 Minden
07.10.2021 Page 3/16
Commercial data
Product Group
1 (Rail Mounted Terminal Blocks)
PU (SPU)
50 Stück
Packaging type
box
Country of origin
DE
GTIN
4044918890229
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2160584.53
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172
Optional accessories
Insulation stop
Insulation stop
Item no.: 280-472
Hansastr. 27
32423 Minden
www.wago.com/280-472
07.10.2021 Page 4/16
Item no.: 280-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
Item no.: 280-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/280-470
Item no.: 280-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/280-471
Testing and measuring
Testing accessories
Item no.: 209-170
Test plug adapter; 8.3 mm wide; for 4 mm Ø test plugs; suitable for 1.5 mm² - 10 mm² tbs; gray
www.wago.com/209-170
Plugs
Fuse plug
Item no.: 280-854/281-413
www.wago.com/280-854
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); DC 15 - 30 V; 1 A FF; 5 mm wide;
/281-413
gray
Item no.: 280-854/281-415
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); AC 15 - 30 V; 1 A FF; 5 mm wide;
/281-415
gray
Item no.: 280-856/281-415
www.wago.com/280-856
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); AC 15 - 30 V; 2 A FF; 5 mm wide;
/281-415
gray
Item no.: 280-856/281-414
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); DC 30 - 65 V; 2 A FF; 5 mm wide;
/281-414
gray
Item no.: 280-856
Fuse plug; with soldered miniature fuse; 2 A FF; 5 mm wide; gray
Item no.: 280-854/281-414
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); DC 30 - 65 V; 1 A FF; 5 mm wide;
/281-414
gray
Item no.: 280-856/281-413
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); DC 15 - 30 V; 2 A FF; 5 mm wide;
/281-413
gray
Item no.: 281-511
Fuse plug; with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; without blown fuse
indication; 6 mm wide; gray
www.wago.com/281-511
Item no.: 281-512/281-501
Fuse plug; with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; with LED indicator; 24 V
AC/DC; 6 mm wide; gray
www.wago.com/281-512
/281-501
Item no.: 281-512
Fuse plug; with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; with port for LED; 6 mm
Hansastr. 27
32423 Minden
07.10.2021 Page 5/16
wide; gray
Item no.: 281-512/281-418
Fuse plug; with pull-tab; for miniature metric fuses 5 x 20 mm and 5 x 25 mm; with blown fuse indication
/281-418
by neon lamp; 120 V; 6 mm wide; gray
Item no.: 281-512/281-417
/281-417
by neon lamp; 230 V; 6 mm wide; gray
Item no.: 280-850/281-414
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); DC 30 - 65 V; 250 mA FF; 5 mm
wide; gray
www.wago.com/280-850
/281-414
Item no.: 280-850/281-413
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); DC 15 - 30 V; 250 mA FF; 5 mm
wide; gray
/281-413
Item no.: 280-850/281-415
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); AC 15 - 30 V; 250 mA FF; 5 mm
wide; gray
/281-415
Item no.: 280-852/281-413
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); DC 15 - 30 V; 500 mA FF; 5 mm
wide; gray
www.wago.com/280-852
/281-413
Item no.: 280-852/281-414
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); DC 30 - 65 V; 500 mA FF; 5 mm
wide; gray
/281-414
Item no.: 280-852/281-415
Fuse plug; with soldered miniature fuse; with indicator lamp; LED (red); AC 15 - 30 V; 500 mA FF; 5 mm
wide; gray
/281-415
Item no.: 280-854
Fuse plug; with soldered miniature fuse; 1 A FF; 5 mm wide; gray
Item no.: 280-852
Fuse plug; with soldered miniature fuse; 500 mA FF; 5 mm wide; gray
Item no.: 280-850
Fuse plug; with soldered miniature fuse; 250 mA FF; 5 mm wide; gray
Empty component plug housing
Item no.: 280-801
Empty component plug housing; gray
www.wago.com/280-801
Marking accessories
Marker
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
www.wago.com/2009-115
/000-002
Hansastr. 27
32423 Minden
07.10.2021 Page 6/16
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 793-5501/000-007
www.wago.com/793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
Item no.: 793-501/000-007
Hansastr. 27
32423 Minden
www.wago.com/793-501
/000-002
07.10.2021 Page 7/16
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501
Hansastr. 27
32423 Minden
07.10.2021 Page 8/16
Item no.: 793-5501
type; white
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Protective warning marker
Cover
Item no.: 280-415
Protective warning marker; for 5 terminal blocks; with high-voltage symbol, black; yellow
www.wago.com/280-415
Mounting
Mounting accessories
Item no.: 249-116
Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-116
Item no.: 709-154
Cover; Type 2; suitable for cover carrier, type 2; 1 m long; transparent
www.wago.com/709-154
Item no.: 709-168
Cover carrier; Type 2; incl. fixing/retaining screws and knurled nut; suitable for 283 to 285 Series railmounted terminal blocks; suitable for 279 to 281 Series double- and triple-deck terminal blocks;
suitable for 780 to 785, 775, 776 and 777 Series TOPJOB® rail-mounted terminal blocks; suitable for
280 Series sensor and actuator terminal blocks; suitable for 282 Series disconnect/test terminal
blocks for transformer circuits; gray
www.wago.com/709-168
Carrier rail
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715;
silver-colored
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Hansastr. 27
32423 Minden
07.10.2021 Page 9/16
colored
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
silver-colored
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Hansastr. 27
32423 Minden
www.wago.com/216-302
07.10.2021 Page 10/16
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
Tool
Operating tool
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Push-in type wire jumper
Jumper
Item no.: 249-123
Push-in type wire jumper; 0.75 mm²; insulated; 180 mm long; black
www.wago.com/249-123
Item no.: 249-126
Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; black
www.wago.com/249-126
Item no.: 249-127
Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; black
www.wago.com/249-127
Item no.: 249-125
Push-in type wire jumper; insulated; 60 mm long; black
www.wago.com/249-125
Item no.: 210-123
Wire commoning chain; insulated; blue
www.wago.com/210-123
Item no.: 280-402
Jumper; insulated; gray
www.wago.com/280-402
Item no.: 210-103
Wire commoning chain; insulated; black
www.wago.com/210-103
Item no.: 280-492
Jumper; 2-way; insulated; gray
www.wago.com/280-492
Item no.: 280-482
www.wago.com/280-482
Item no.: 280-484
Jumper; 4-way; insulated; gray
www.wago.com/280-484
Item no.: 280-490
Jumper; 10-way; insulated; gray
www.wago.com/280-490
Jumpers
Jumper
Item no.: 280-485
Hansastr. 27
32423 Minden
07.10.2021 Page 11/16
Item no.: 280-485
Jumper; 5-way; insulated; gray
www.wago.com/280-485
Item no.: 280-483
Jumper; 3-way; insulated; gray
www.wago.com/280-483
Item no.: 709-110
Wire commoning chain; 2.5 mm²; insulated; black
www.wago.com/709-110
Item no.: 709-112
www.wago.com/709-112
Item no.: 709-111
www.wago.com/709-111
Item no.: 780-454
Staggered jumper; from 1 to 4; insulated; gray
www.wago.com/780-454
Item no.: 780-452
Staggered jumper; from 1 to 2; insulated; gray
www.wago.com/780-452
Item no.: 780-453
Staggered jumper; from 1 to 3; insulated; gray
www.wago.com/780-453
Item no.: 780-457
Staggered jumper; from 1 to 7; insulated; gray
www.wago.com/780-457
Item no.: 780-456
Staggered jumper; from 1 to 6; insulated; gray
www.wago.com/780-456
Item no.: 780-455
Staggered jumper; from 1 to 5; insulated; gray
www.wago.com/780-455
Item no.: 780-458
Staggered jumper; from 1 to 8; insulated; gray
www.wago.com/780-458
Downloads
Documentation
Bid Text
280-565/280-319
Feb 19, 2019
xml
3.6 kB
Download
Mar 30, 2017
doc
25.6 kB
Download
X81 - Datei
280-565/280-319
doc - Datei
Hansastr. 27
32423 Minden
07.10.2021 Page 12/16
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.2 MB
Download
EPLAN Data Portal 280-565/280-319
URL
Download
WSCAD Universe 280-565/280-319
URL
Download
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 280-565/280-319
2-conductor actuator terminal block; with colored conductor entries; 2.5 mm²; CAGE
Installation Notes
Installation
Hansastr. 27
32423 Minden
07.10.2021 Page 13/16
Snapping a terminal block onto the DIN-rail.
Terminal blocks with a grounding foot
automatically establish a direct contact to
the rail.
Removing the terminal block from DIN-rail.
Notice: Remove jumper contacts first!
Conductor termination
CAGE CLAMP® connection
Inserting a conductor via straight operating
tool (210-720).
Inserting a conductor via angled operating
tool (210-658).
Commoning
Hansastr. 27
32423 Minden
07.10.2021 Page 14/16
Commoning using an adjacent jumper
(280‑402).
Push jumper down until fully inserted.
Testing
Testing via banana plug and test plug
adapter (209-170).
Testing via voltage tester directly on the
current bar.
Installation
Min. mounting distance – terminal blocks to
cable duct
Marking
Hansastr. 27
32423 Minden
07.10.2021 Page 15/16
Labeling via WMB Multi Marking System.
Hansastr. 27
32423 Minden
07.10.2021 Page 16/16
很抱歉,暂时无法提供与“280-565/280-319”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+144.915081+18.76051
- 10+103.2302710+13.36405
- 25+91.8032325+11.88473
- 50+84.9588350+10.99866
- 100+79.45244100+10.28581
- 250+73.88257250+9.56474
- 500+70.71014500+9.15404
- 1000+68.241831000+8.83450
