Data sheet | Item number: 280-623/281-410
Component terminal block; 4-conductor; with diode 1N4007; anode, left
side; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²;
gray
www.wago.com/280-623/281-410
i
Picture differs from the item.
Color:
Data
Electrical data
Nominal voltage
250 V
Reverse voltage
1,000 V
Ratings per
IEC/EN 60947-7-1
Rated current
0.5 A
Connection data
Total number of connection points
4
Total number of potentials
1
Number of levels
1
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Aluminum
Anschließbare Leiterwerkstoffe Hinweis
Terminating Aluminum Conductors
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/9
WAGO spring clamp terminal blocks are suitable for solid aluminum
conductors up to 4 mm²/12 AWG if WAGO “Alu-Plus” Contact Paste
is used for termination.
“Alu-Plus” Contact Paste Advantages:
Automatically destroys the oxide film during clamping.
Prevents fresh oxidation at the clamping point.
Prevents electrolytic corrosion between aluminum and
copper conductors (in the same terminal block).
Provides long-term protection against corrosion.
Using terminal blocks with CAGE CLAMP® Spring Pressure
Connection Technology, aluminum conductors must first be
cleaned with a blade and then immediately be inserted into the
clamping units filled with “Alu-Plus” Contact Paste.
For spring clamp connections with PUSH WIRE® connection
technology, WAGO recommends that the aluminum conductor first
be cleaned and then immediately inserted into the clamping unit
filled with “Alu-Plus” contact paste.
It is also possible to apply WAGO “Alu-Plus” additionally on the
whole surface of the aluminum conductor before termination.
Please note that the nominal currents must be adapted to the
reduced conductivity of the aluminum conductors::
2.5 mm² = 16 A
4 mm² = 22 A
Solid conductor
0.08 … 2.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Wiring direction
Front-entry wiring
Physical data
Width
5 mm / 0.197 inch
Height
73 mm / 2.874 inch
Depth from upper edge of DIN-rail
28 mm / 1.102 inch
Mechanical data
Design
horizontal type
Hansastr. 27
32423 Minden
07.10.2021 Page 2/9
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Side marking
Material data
Color
gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.156 MJ
Weight
8.7 g
Commercial data
Product Group
1 (Rail Mounted Terminal Blocks)
PU (SPU)
100 Stück
Packaging type
box
Country of origin
CN
GTIN
4050821275411
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2157201.01
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Ship Approvals
Logo
Certificate
name
Hansastr. 27
32423 Minden
07.10.2021 Page 3/9
Required accessories
End plate
End plate
Item no.: 280-317
End and intermediate plate; 2.5 mm thick; orange
www.wago.com/280-317
Item no.: 280-316
End and intermediate plate; 2.5 mm thick; gray
www.wago.com/280-316
Optional accessories
Insulation stop
Insulation stop
Item no.: 280-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
www.wago.com/280-472
Item no.: 280-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/280-470
Item no.: 280-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/280-471
Carrier rail
Mounting accessories
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715;
silver-colored
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Item no.: 210-113
Hansastr. 27
32423 Minden
www.wago.com/210-113
07.10.2021 Page 4/9
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
silver-colored
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Mounting
Hansastr. 27
32423 Minden
07.10.2021 Page 5/9
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 249-116
Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray
www.wago.com/249-116
Item no.: 709-153
Cover; Type 1; suitable for cover carrier, type 1; 1 m long; transparent
www.wago.com/709-153
Item no.: 709-167
Cover carrier; Type 1; incl. fixing/retaining screws and knurled nut; suitable for 279 to 282 and 880
Series rail-mounted terminal blocks; suitable for 264 Series miniature rail-mounted terminal blocks;
suitable for 270 Series sensor and actuator terminal blocks; gray
www.wago.com/709-167
Protective warning marker
Cover
Item no.: 280-415
Protective warning marker; for 5 terminal blocks; with high-voltage symbol, black; yellow
www.wago.com/280-415
Item no.: 210-123
Wire commoning chain; insulated; blue
www.wago.com/210-123
Item no.: 210-103
Wire commoning chain; insulated; black
www.wago.com/210-103
Item no.: 280-492
Jumper; 2-way; insulated; gray
www.wago.com/280-492
Item no.: 280-482
www.wago.com/280-482
Item no.: 280-484
Jumper; 4-way; insulated; gray
www.wago.com/280-484
Item no.: 280-490
Jumper; 10-way; insulated; gray
www.wago.com/280-490
Item no.: 280-485
Jumper; 5-way; insulated; gray
www.wago.com/280-485
Item no.: 280-483
Jumper; 3-way; insulated; gray
www.wago.com/280-483
Item no.: 709-110
Wire commoning chain; 2.5 mm²; insulated; black
www.wago.com/709-110
Jumpers
Jumper
Item no.: 709-112
Hansastr. 27
32423 Minden
07.10.2021 Page 6/9
Item no.: 709-112
www.wago.com/709-112
Item no.: 709-111
www.wago.com/709-111
Marking accessories
Marker
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
End plate
End plate
Item no.: 280-327
Separator plate; 2 mm thick; oversized; orange
www.wago.com/280-327
Item no.: 280-337
Separator plate; 2 mm thick; oversized; gray
www.wago.com/280-337
Testing and measuring
Testing accessories
Item no.: 249-141
L-type test plug module; modular; with spring-loaded contact pin; Center module; 1,50 mm²; gray
www.wago.com/249-141
Item no.: 249-143
L-type spacer module; modular; e.g., bridging commoned terminal blocks; gray
www.wago.com/249-143
Item no.: 249-142
L-type end module; modular; with rigid contact pin; End module; 1,50 mm²; gray
www.wago.com/249-142
Tool
Operating tool
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Downloads
Hansastr. 27
32423 Minden
07.10.2021 Page 7/9
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.2 MB
Download
EPLAN Data Portal 280-623/281-410
URL
Download
WSCAD Universe 280-623/281-410
URL
Download
URL
Download
ZUKEN Portal 280-623/281-410
URL
Download
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAE data
CAD data
2D/3D Models 280-623/281-410
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 280-623/281-410
Component terminal block; 4-conductor; with diode 1N4007; anode, left side; for DINrail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray
Installation Notes
Commoning
Hansastr. 27
32423 Minden
07.10.2021 Page 8/9
Commoning using comb-style jumper bars:
Push comb-style jumper bars down until fully
inserted.
These diode terminal blocks have been
specially developed for custom diode
circuits, such as lamp test and collective
fault signal circuits.
Polarized diode gates with a common
cathode can be created using the following
terminal blocks:
280‑623/281‑410 or 280‑623/281‑411
Hansastr. 27
32423 Minden
07.10.2021 Page 9/9
很抱歉,暂时无法提供与“280-623/281-410”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+90.031581+11.26650
- 5+88.789775+11.11110
- 20+87.7253620+10.97790
- 50+87.0157550+10.88910
- 125+85.68523125+10.72260
