280-672
280-672
    WAGO(万可电子)
    端子块连接器 4 位置 馈通式 黄色 12-28 AWG
280-672 数据手册
Data sheet | Item number: 280-672 3-conductor through terminal block; 2.5 mm²; center marking; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; yellow www.wago.com/280-672 i Picture differs from the item. Color: Data Electrical data Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 800 V Rated surge voltage (III/3) 8 kV Rated current 24 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Total number of connection points 3 Total number of potentials 1 Number of levels 1 Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Aluminum Anschließbare Leiterwerkstoffe Hinweis Terminating Aluminum Conductors Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Terminating Aluminum Conductors WAGO spring clamp terminal blocks are suitable for solid aluminum conductors up to 4 mm²/12 AWG if WAGO “Alu-Plus” Contact Paste is used for termination. “Alu-Plus” Contact Paste Advantages: Automatically destroys the oxide film during clamping. Prevents fresh oxidation at the clamping point. Prevents electrolytic corrosion between aluminum and copper conductors (in the same terminal block). Provides long-term protection against corrosion. Using terminal blocks with CAGE CLAMP® Spring Pressure Connection Technology, aluminum conductors must first be cleaned with a blade and then immediately be inserted into the clamping units filled with “Alu-Plus” Contact Paste. For spring clamp connections with PUSH WIRE® connection technology, WAGO recommends that the aluminum conductor first be cleaned and then immediately inserted into the clamping unit filled with “Alu-Plus” contact paste. It is also possible to apply WAGO “Alu-Plus” additionally on the whole surface of the aluminum conductor before termination. Please note that the nominal currents must be adapted to the reduced conductivity of the aluminum conductors:: 2.5 mm² = 16 A 4 mm² = 22 A Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Note (conductor cross-section) 12 AWG: THHN, THWN Strip length 8 … 9 mm / 0.31 … 0.35 inch Wiring direction Front-entry wiring Physical data Width 5 mm / 0.197 inch Height 64 mm / 2.52 inch Depth from upper edge of DIN-rail 28 mm / 1.102 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Center marking Material data Color yellow Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 0.123 MJ Weight 7.6 g Commercial data PU (SPU) 100 Stück Packaging type box Country of origin DE GTIN 4044918391269 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 60947 2157201.01 CSA DEKRA Certification B.V. C22.2 1536071 Ship Approvals Logo Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 Certificate name 20HG1941090PDA Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/16 Data sheet | Item number: 280-672 www.wago.com/280-672 BV Bureau Veritas S.A. EN 60947 07436/F0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register EN 60947 91/20112 (E9) UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 Required accessories End plate     End plate Item no.: 280-324 End and intermediate plate; 2.5 mm thick; gray www.wago.com/280-324 Item no.: 280-326 End and intermediate plate; 2.5 mm thick; orange www.wago.com/280-326 Optional accessories Insulation stop     Insulation stop Item no.: 280-472 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip www.wago.com/280-472 Item no.: 280-470 Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white www.wago.com/280-470 Item no.: 280-471 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/280-471 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Item no.: 280-471 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/280-471 Protective warning marker     Cover Item no.: 280-415 Protective warning marker; for 5 terminal blocks; with high-voltage symbol, black; yellow www.wago.com/280-415 Tool     Operating tool Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured www.wago.com/210-657 Item no.: 210-658 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured www.wago.com/210-658 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Marking accessories     Double marker carrier Item no.: 209-128 Adaptor; gray www.wago.com/209-128 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501     Marker Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white     Group marker carrier Item no.: 209-142 Group marker carrier; gray www.wago.com/209-142 Item no.: 209-141 Group marker carrier; gray www.wago.com/209-141 Item no.: 209-140 Group marker carrier; gray www.wago.com/209-140 Item no.: 249-105 Group marker carrier; gray www.wago.com/249-105 Mounting     Mounting accessories Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Mounting     Mounting accessories Item no.: 209-106 Mounting carrier; for isolated mounting on DIN 35 rails; gray www.wago.com/209-106 Item no.: 249-116 Screwless end stop; 6 mm wide; for DIN-rail 35 x 15 and 35 x 7.5; gray www.wago.com/249-116 Item no.: 709-153 Cover; Type 1; suitable for cover carrier, type 1; 1 m long; transparent www.wago.com/709-153 Item no.: 709-167 Cover carrier; Type 1; incl. fixing/retaining screws and knurled nut; suitable for 279 to 282 and 880 Series rail-mounted terminal blocks; suitable for 264 Series miniature rail-mounted terminal blocks; suitable for 270 Series sensor and actuator terminal blocks; gray www.wago.com/709-167 Carrier rail     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Jumpers     Jumper Item no.: 210-123 Wire commoning chain; insulated; blue www.wago.com/210-123 Item no.: 280-402 Jumper; insulated; gray www.wago.com/280-402 Item no.: 210-103 Wire commoning chain; insulated; black www.wago.com/210-103 Item no.: 280-492 Jumper; 2-way; insulated; gray www.wago.com/280-492 Item no.: 280-409 Jumper; insulated; gray www.wago.com/280-409 Item no.: 280-422 Jumper; insulated; yellow-green www.wago.com/280-422 Item no.: 280-482 Jumper; 2-way; insulated; gray www.wago.com/280-482 Item no.: 280-484 Jumper; 4-way; insulated; gray www.wago.com/280-484 Item no.: 280-490 Jumper; 10-way; insulated; gray www.wago.com/280-490 Item no.: 280-485 Jumper; 5-way; insulated; gray www.wago.com/280-485 Item no.: 280-483 Jumper; 3-way; insulated; gray www.wago.com/280-483 Item no.: 284-414 Step-down jumper; from 284/282 to 281/280/279 series; insulated; gray www.wago.com/284-414 Item no.: 709-110 Wire commoning chain; 2.5 mm²; insulated; black www.wago.com/709-110 Item no.: 709-112 Wire commoning chain; 2.5 mm²; insulated; black www.wago.com/709-112 Item no.: 709-111 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Item no.: 709-111 Wire commoning chain; 2.5 mm²; insulated; black www.wago.com/709-111 Item no.: 780-454 Staggered jumper; from 1 to 4; insulated; gray www.wago.com/780-454 Item no.: 780-452 Staggered jumper; from 1 to 2; insulated; gray www.wago.com/780-452 Item no.: 780-453 Staggered jumper; from 1 to 3; insulated; gray www.wago.com/780-453 Item no.: 780-457 Staggered jumper; from 1 to 7; insulated; gray www.wago.com/780-457 Item no.: 780-456 Staggered jumper; from 1 to 6; insulated; gray www.wago.com/780-456 Item no.: 780-455 Staggered jumper; from 1 to 5; insulated; gray www.wago.com/780-455 Item no.: 780-458 Staggered jumper; from 1 to 8; insulated; gray www.wago.com/780-458 Testing and measuring     Testing accessories Item no.: 209-170 Test plug adapter; 8.3 mm wide; for 4 mm Ø test plugs; suitable for 1.5 mm² - 10 mm² tbs; gray www.wago.com/209-170 Item no.: 281-407 Test plug; 6 mm wide; Nominal current 24 A; for 0.08 mm² - 2.5 mm²; 2,50 mm²; gray www.wago.com/281-407 Item no.: 249-106 B-type test plug module; modular; 1,50 mm²; gray www.wago.com/249-106 Item no.: 249-107 B-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/249-107 Item no.: 249-141 L-type test plug module; modular; with spring-loaded contact pin; Center module; 1,50 mm²; gray www.wago.com/249-141 Item no.: 249-143 L-type spacer module; modular; e.g., bridging commoned terminal blocks; gray www.wago.com/249-143 Item no.: 249-142 L-type end module; modular; with rigid contact pin; End module; 1,50 mm²; gray www.wago.com/249-142 Item no.: 280-418 Test plug module; modular; suitable for all WAGO 280 and 780 Series rail-mounted terminal blocks with www.wago.com/280-418 jumper slots in the current bar; gray Item no.: 280-404 Test plug adapter; 5 mm wide; for test plug (2.3 mm Ø); suitable for 1.5 mm² - 4 mm² tbs; gray www.wago.com/280-404 Item no.: 280-419 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Item no.: 280-419 Spacer module; modular; bridging commoned terminal blocks; gray www.wago.com/280-419 Push-in type wire jumper     Jumper Item no.: 249-123 Push-in type wire jumper; 0.75 mm²; insulated; 180 mm long; black www.wago.com/249-123 Item no.: 249-126 Push-in type wire jumper; 0.75 mm²; insulated; 110 mm long; black www.wago.com/249-126 Item no.: 249-127 Push-in type wire jumper; 0.75 mm²; insulated; 250 mm long; black www.wago.com/249-127 Item no.: 249-125 Push-in type wire jumper; insulated; 60 mm long; black www.wago.com/249-125 Item no.: 284-334 Step-down cover plate; 1 mm thick; for 2-, 3- and 4-conductor terminal blocks; gray www.wago.com/284-334 Item no.: 280-346 Separator plate; 2 mm thick; oversized; orange www.wago.com/280-346 Item no.: 284-344 Step-down cover plate; 1 mm thick; for 2-, 3- and 4-conductor terminal blocks; orange www.wago.com/284-344 Item no.: 280-344 Separator plate; 2 mm thick; oversized; gray www.wago.com/280-344 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored www.wago.com/216-104 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 End plate     End plate Ferrule     Ferrule Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Plugs     Neon indicator module Item no.: 280-803/281-417 Component plug; 2-pole; 10 mm wide; gray www.wago.com/280-803 /281-417 Item no.: 280-803/281-418 Component plug; 2-pole; 10 mm wide; gray www.wago.com/280-803 /281-418 Item no.: 280-803/281-420 Component plug; 2-pole; with rectifier diode and LED; 10 mm wide; gray www.wago.com/280-803 /281-420 Item no.: 280-803/281-421 Component plug; 2-pole; with rectifier diode and LED; 10 mm wide; gray www.wago.com/280-803 /281-421 Item no.: 280-803/281-411 Component plug; 2-pole; with diode 1N4007; 10 mm wide; gray www.wago.com/280-803 /281-411 Item no.: 280-803/281-414 Component plug; 2-pole; LED (red); 48 VDC; 10 mm wide; gray www.wago.com/280-803 /281-414 Item no.: 280-803/281-413 Component plug; 2-pole; LED (red); 24 VDC; 10 mm wide; gray www.wago.com/280-803 /281-413 Item no.: 280-803/281-415 Component plug; 2-pole; LED (red); 10 mm wide; gray www.wago.com/280-803 /281-415 Item no.: 280-803/281-416 Component plug; 2-pole; LED (red); 10 mm wide; gray www.wago.com/280-803 /281-416     Diode plug     LED plug     Empty component plug housing Item no.: 280-803 Empty component plug housing; 10 mm wide; Type 4; 2-pole; gray www.wago.com/280-803 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 10/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Downloads Documentation Bid Text 280-672 Feb 19, 2019 xml 3.3 kB Download Feb 28, 2017 doc 24.6 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download EPLAN Data Portal 280-672 URL Download WSCAD Universe 280-672 URL Download ZUKEN Portal 280-672 URL Download URL Download X81 - Datei 280-672 doc - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 280-672 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 280-672 3-conductor through terminal block; 2.5 mm²; center marking; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; yellow Installation Notes Installation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 11/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Snapping a terminal block onto the DIN-rail. Quick assembly keys prevent reverse mounting. Removing a terminal block from the assembly. Steel DIN-rails are not suited for PEN (ground and N-conductor) applications per EN 60947-7-2 (VDE 0611, Part 3). Conductor termination CAGE CLAMP® connection CAGE CLAMP® connection Inserting insulation stops. Inserting a conductor. Inserting a conductor. With ferruled conductors, it is necessary to use a terminal block one size larger than the conductor's nominal cross-section. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 12/16 Data sheet | Item number: 280-672 www.wago.com/280-672 CAGE CLAMP® connection Removing a solid conductor. Commoning Commoning using an adjacent jumper (280‑402). Staggered jumpers are suitable for sophisticated circuit requirements. Push jumpers down until fully inserted! Push jumper down until fully inserted! Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 13/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Push-In Type Wire Jumpers When installing machines or control systems, it is often necessary to make an additional connection between two terminal blocks that are not next to each other on the rail. In such cases, WAGO's touch-proof, push-in type wire jumpers are the ideal solution. Commoning using comb-style jumper bars: Push comb-style jumper bars down until fully inserted. Commoning terminal blocks of different sizes via step-down jumpers. These jumpers are compatible with the following rail-mount terminal blocks: - 279 Series (1.5 mm²/16 AWG), - 280/775/780 Series (2.5 mm²/14 AWG) - 281/769/776/777/781 and 880 Series (4 mm²/12 AWG) They are available in three conductor lengths (60, 110 and 250 mm), allowing up to 60 terminal blocks to be commoned depending on their width (see table on the right). The 280/775/780 and 281/776/777/781 Series Terminal Blocks accept two wire jumpers, allowing the use of commoning chains. Furthermore, the 280/769/775/780 /880 and 281/776/777/781 Series allow both wire jumper and adjacent jumper to be simultaneously plugged into a same terminal block. Testing Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 14/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Testing with a test plug. L-type test plug modules fitted with CAGE CLAMP® B-type test plug modules fitted with CAGE CLAMP® Picture shows a test plug fitted with CAGE CLAMP®. Testing with a test plug. Test plugs modules are directly plugged into the jumper contact slot of the current bar. Picture shows a test plug adapter (209-170). Cover Protective warning markers inserted into the operating slots Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 15/16 Data sheet | Item number: 280-672 www.wago.com/280-672 Labeling via WMB Multi Marking System. Terminal block marking with double marker carriers (209‑128) Terminal blocks with side marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 16/16
280-672 价格&库存
很抱歉,暂时无法提供与“280-672”相匹配的价格&库存,您可以联系我们找货
