280-803/281-417
280-803/281-417
    WAGO(万可电子)
    COMPONENT PLUG; 2-POLE; 10 MM WI
280-803/281-417 数据手册
Data sheet | Item number: 280-803/281-417 Component plug; 2-pole; 10 mm wide; gray www.wago.com/280-803/281-417 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/4 Data sheet | Item number: 280-803/281-417 www.wago.com/280-803/281-417 Data Electrical data Voltage type 1 AC/DC Operation status indicator 230 V Connection data Actuation type Operating tool Physical data Width 10 mm / 0.394 inch Material data Color gray Insulation material Polyamide (PA66) Fire load 0.078 MJ Weight 4.4 g Commercial data Product Group 1 (Rail Mounted Terminal Blocks) PU (SPU) 50 Stück Packaging type box Country of origin DE GTIN 4045454195984 Customs tariff number 85366990990 Optional accessories Terminal blocks     Through terminal block Item no.: 280-833 4-conductor through terminal block; 2.5 mm²; center marking; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-833 Item no.: 280-901 2-conductor through terminal block; 2.5 mm²; center marking; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-901 Item no.: 280-101 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/4 Data sheet | Item number: 280-803/281-417 www.wago.com/280-803/281-417 Item no.: 280-101 2-conductor through terminal block; 2.5 mm²; lateral marker slots; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-101 Item no.: 280-633 4-conductor through terminal block; 2.5 mm²; center marking; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-633 Item no.: 280-603 4-conductor through terminal block; 2.5 mm²; center marking; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; orange www.wago.com/280-603 Item no.: 280-601 2-conductor through terminal block; 2.5 mm²; lateral marker slots; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-601 Item no.: 280-621 4-conductor through terminal block; 2.5 mm²; lateral marker slots; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-621 Item no.: 280-681 3-conductor through terminal block; 2.5 mm²; center marking; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-681 Downloads Documentation Bid Text 280-803/281-417 Feb 19, 2019 xml 2.7 kB Download Apr 27, 2017 doc 24.1 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download WSCAD Universe 280-803/281-417 URL Download ZUKEN Portal 280-803/281-417 Subject to changes. Please also observe the further product documentation! URL Download X81 - Datei 280-803/281-417 doc - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 280-803/281-417 CAE data WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/4 Data sheet | Item number: 280-803/281-417 www.wago.com/280-803/281-417 ZUKEN Portal 280-803/281-417 URL Download WSCAD Universe 280-803/281-417 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 280-803/281-417 Component plug; 2-pole; 10 mm wide; gray Installation Notes Installation Similar to push-in type jumpers, these LED and neon indicator modules are simply pushed into the current bar's contact slots of two adjacent through terminal blocks, providing the following advantages: Compatibility with all 280 Series Through Terminal Blocks Easy retrofits for existing systems Additional advantages: Separation into functional and wiring levels Fast replacement of other functional units Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/4
280-803/281-417 价格&库存
很抱歉,暂时无法提供与“280-803/281-417”相匹配的价格&库存,您可以联系我们找货
