280-850
280-850
    WAGO(万可电子)
    连接器 保险丝插头 用于 DIN 导轨端子块
280-850 数据手册
Data sheet | Item number: 280-850 Fuse plug; with soldered miniature fuse; 250 mA FF; 5 mm wide; gray www.wago.com/280-850 Color: Data Electrical data Ratings (note) Electrical ratings are given by the fuse. Nominal voltage (III/3) 125 V Rated current 5  A Operation status indicator without Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/5 Data sheet | Item number: 280-850 www.wago.com/280-850 Operation status indicator without Physical data Width 5 mm / 0.197 inch Mechanical data Marking level without marking level Art der Sicherung Minature fuse 250 mA FF Material data Color gray Insulation material Polyamide (PA66) Fire load 0.051 MJ Weight 2.7 g Commercial data Product Group 1 (Rail Mounted Terminal Blocks) PU (SPU) 100 Stück Packaging type box Country of origin DE GTIN 4045454196387 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 60947 2160584.53 Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 Ship Approvals Logo Certificate name 20HG1941090PDA Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/5 Data sheet | Item number: 280-850 www.wago.com/280-850 DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 Optional accessories Terminal blocks     Carrier terminal block for modules and plugs Item no.: 280-610 3-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-610 Item no.: 280-916 2-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-916 Item no.: 280-616 2-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-616 Item no.: 280-686 4-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-686 Item no.: 280-816 4-conductor carrier terminal block; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; CAGE CLAMP®; 2,50 mm²; gray www.wago.com/280-816 Downloads Documentation Bid Text 280-850 Mar 14, 2017 doc 23.6 kB Download Feb 19, 2019 xml 2.9 kB Download Apr 3, 2019 pdf 2.2 MB Download URL Download doc - Datei 280-850 X81 - Datei Additional Information Technical explanations CAD/CAE-Data CAE data WSCAD Universe 280-850 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/5 Data sheet | Item number: 280-850 www.wago.com/280-850 Environmental Product Compliance Compliance Search Environmental Product Compliance 280-850 URL Download Fuse plug; with soldered miniature fuse; 250 mA FF; 5 mm wide; gray Installation Notes Using fuse plugs with rail-mount terminal blocks (280/281 and 769 Series) for control circuit protection is highly advantageous because the function and wiring levels are separated: No additional assembly and wiring costs No risk of accidental contact with live parts when disconnecting the fuse plug Quick plug replacement in case of a blown fuse The fuse plug can be removed by service personnel No unintentional reclosing of the circuit by another person Additional advantages: Terminal blocks/plugs provide ultra high-density wiring in a width of just 5 mm Optional LED indicates blown fuse Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/5 Data sheet | Item number: 280-850 www.wago.com/280-850 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 5/5
280-850 价格&库存
很抱歉,暂时无法提供与“280-850”相匹配的价格&库存,您可以联系我们找货
