288-364
288-364
    WAGO(万可电子)
    继电器 24VDC 线圈 DIN 轨道
288-364 数据手册
Data sheet | Item number: 288-364 Relay module; Nominal input voltage: 24 VDC; 1 make contact; Limiting continuous current: 5 A; Module width: 13 mm; 2,50 mm²; gray www.wago.com/288-364 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/6 Data sheet | Item number: 288-364 www.wago.com/288-364 Data Technical data Number of make/switch-on contacts 1 Contact material (relay) AgNi 0.15 Limiting continuous current 5 A Inrush current (resistive) (max.) (AC) 16 A / 4 s Switching voltage (max.) AC 250 V Switching power (resistive) (max.) AC 1250 VA Pull-in time (typ.) 4 ms Drop-out time (typ.) 6 ms Bounce time (typ.) 2 ms Electrical life (NO; resistive load; 23 °C) 200 x 103 switching operations Mechanical life 30 x 106 switching operations Nominal input voltage UN DC 24 V Input voltage range ±10 % Nominal input current at UN 20 mA Overvoltage category II Pollution degree 2 Dielectric strength, control/load circuit (AC, 1 min) 4 kVrms Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/6 Data sheet | Item number: 288-364 www.wago.com/288-364 Dielectric strength, control/load circuit (AC, 1 min) 4 kVrms Insulation type (control/load circuit) Reinforced insulation (safe isolation) Insulation type (adjacent devices) Reinforced insulation (safe isolation) Line-to-neutral conductor voltage AC / DC 300 V Connection data Connection technology CAGE CLAMP® WAGO Connector WAGO 236 Series Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Strip length 5 … 6 mm / 0.2 … 0.24 inch Physical data Width 13 mm / 0.512 inch Height 85 mm / 3.346 inch Depth from upper edge of DIN-rail 47 mm / 1.85 inch Mechanical data Mounting type DIN-35 rail Material data Color gray Fire load 0.31 MJ Weight 30.6 g Environmental requirements Surrounding air temperature (operation at UN) -25 … 40 °C Surrounding air temperature (storage) -25 … 70 °C Processing temperature -25 … +50 °C Max. temperature rise of connection cable 30 K Relative humidity 5 … 75 % (non-condensing) Operating altitude (max.) 2000 m Standards and specifications Standards/Specifications EN 61010-2-201 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/6 Data sheet | Item number: 288-364 www.wago.com/288-364 Commercial data Product Group 6 (Interface Electronics) PU (SPU) 15 (1) Stück Packaging type box Country of origin DE GTIN 4045454468040 Customs tariff number 85364900990 Optional accessories Marking accessories     Marking strip Item no.: 709-196 Marking strips; for laser printer; translucent www.wago.com/709-196 Item no.: 709-178 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white www.wago.com/709-178 Item no.: 709-177 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent www.wago.com/709-177 Tool     Operating tool Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Downloads Documentation Bid Text 288-364 Feb 20, 2019 docx 16.0 kB Download Feb 19, 2019 xml 3.9 kB Download pdf Download docx - Datei 288-364 X81 - Datei Instruction Leaflet Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com 1.3 MB Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/6 Data sheet | Item number: 288-364 www.wago.com/288-364 1.3 MB Additional Information Disposal; Electrical and electronic equipment, Packaging V 1.0.0 pdf 265.8 kB Download URL Download EPLAN Data Portal 288-364 URL Download WSCAD Universe 288-364 URL Download ZUKEN Portal 288-364 URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 288-364 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 288-364 Relay module; Nominal input voltage: 24 VDC; 1 make contact; Limiting continuous current: 5 A; Module width: 13 mm; 2,50 mm²; gray Installation Notes Inserting a conductor Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/6 Data sheet | Item number: 288-364 www.wago.com/288-364 Conductor termination – screwdriver actuation parallel to conductor entry Conductor termination – screwdriver actuation perpendicular to conductor entry Installation Snapping a module onto DIN-rail. Removing a module from the DIN-rail. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/6
288-364 价格&库存
很抱歉,暂时无法提供与“288-364”相匹配的价格&库存,您可以联系我们找货
