288-870/000-030
288-870/000-030
    WAGO(万可电子)
    POTENTIAL DISTRIBUTION MODULE; 4
288-870/000-030 数据手册
Data sheet | Item number: 288-870/000-030 Potential distribution module; 4 potentials; with 6 connection points each; with 22 ground clamping points www.wago.com/288-870/000-030 Item description Features: May be used with electronic circuit breakers for 24 and 0 VDC power distribution, as a substitute for rail-mount terminal blocks Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/7 Data sheet | Item number: 288-870/000-030 www.wago.com/288-870/000-030 May be used with electronic circuit breakers for 24 and 0 VDC power distribution, as a substitute for rail-mount terminal blocks Pre-wiring and electrical isolation of current paths via pluggable picoMAX® Female Headers Optional coding pins (2092-1610) protect against any inadvertent mixing of female headers Optional gripping plates with sliding connector release (2092-1601/002-000 or 2092-1602/002-000) provide conductor strain relief 0 V may be supplied to the adjancent modules via comb-style jumper bar (745-682) Data Electrical data Nominal operating voltage DC 24 V Current per connection (max.) 10 A Total current per potential (max.) 10 A Total current 0 V (max.) 40 A Connection data Total number of potentials 4 Connection type (1) Power supply 0 V Mating direction 45° Connection technology CAGE CLAMP® WAGO Connector WAGO 745 Series Solid conductor 0.2 … 16 mm² / 24 … 6 AWG Fine-stranded conductor 0.2 … 16 mm² / 24 … 6 AWG Strip length 12 … 13 mm / 0.47 … 0.51 inch Connection type 2 Power supply 24 V; Connection points Mating direction (2) 45° Connection technology 2 Push-in CAGE CLAMP® WAGO Connector 2 picoMAX® 5.0 (WAGO 2092 Series) Solid conductor 2 0.2 … 2.5 mm² / 24 … 12 AWG Fine-stranded conductor 2 0.2 … 2.5 mm² / 24 … 12 AWG Strip length 2 9 … 10 mm / 0.35 … 0.39 inch Note (conductor cross-section) 12 AWG: THHN, THWN Physical data Width 100 mm / 3.937 inch Height 85 mm / 3.346 inch Depth from upper edge of DIN-rail 49 mm / 1.929 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/7 Data sheet | Item number: 288-870/000-030 www.wago.com/288-870/000-030 Mechanical data Mounting type DIN-35 rail Housing design Mounting carrier Material data Fire load 1.29 MJ Weight 140.4 g Environmental requirements Surrounding air temperature (operation) -25 … 70 °C (without condensation) Surrounding air temperature (storage) -40 … 85 °C Commercial data PU (SPU) 1 Stück Packaging type box Country of origin DE GTIN 4055143107662 Customs tariff number 85369010000 Optional accessories Ferrule     Ferrule Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-206 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue www.wago.com/216-206 Item no.: 216-207 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; gray www.wago.com/216-207 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-209 Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; red www.wago.com/216-209 Item no.: 216-205 Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow www.wago.com/216-205 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/7 Data sheet | Item number: 288-870/000-030 www.wago.com/288-870/000-030 Item no.: 216-208 Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208 acc. to DIN 46228, Part 4/09.90; yellow Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-246 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-286 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-286 Item no.: 216-287 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/7 Data sheet | Item number: 288-870/000-030 www.wago.com/288-870/000-030 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287 acc. to DIN 46228, Part 4/09.90; gray Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-288 Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288 acc. to DIN 46228, Part 4/09.90; yellow Item no.: 216-289 Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-289 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 216-267 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267 acc. to DIN 46228, Part 4/09.90; gray Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Marking accessories     Marking strip Item no.: 210-831 Marking strips; on reel; 2.3 mm wide; plain; Self-adhesive; white www.wago.com/210-831 Item no.: 210-832 Marking strips; on reel; 3 mm wide; plain; Self-adhesive; white www.wago.com/210-832 Item no.: 709-196 Marking strips; for laser printer; translucent www.wago.com/709-196 Item no.: 709-178 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white www.wago.com/709-178 Item no.: 709-177 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent www.wago.com/709-177     Marker Item no.: 2009-145 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/7 Data sheet | Item number: 288-870/000-030 www.wago.com/288-870/000-030 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Jumpers     Jumper Item no.: 745-682 Jumper; 2-way www.wago.com/745-682 Strain relief     Strain relief plate Item no.: 2092-1601/002-000 Gripping plate with sliding connector release; light gray www.wago.com/2092-1601 /002-000 Item no.: 2092-1602/002-000 Gripping plate with sliding connector release; light gray www.wago.com/2092-1602 /002-000 Tool     Operating tool Item no.: 210-721 Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft; multicoloured www.wago.com/210-721 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Downloads Documentation Bid Text 288-870/000-030 Feb 19, 2019 xml 5.0 kB Download Jan 2, 2017 doc Download X81 - Datei 288-870/000-030 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/7 Data sheet | Item number: 288-870/000-030 www.wago.com/288-870/000-030 288-870/000-030 Jan 2, 2017 doc 30.7 kB Download pdf 1.3 MB Download pdf 265.8 kB Download URL Download EPLAN Data Portal 288-870/000-030 URL Download ZUKEN Portal 288-870/000-030 URL Download EPLAN Data Portal 288-870/000-030 URL Download URL Download doc - Datei Instruction Leaflet Additional Information Disposal; Electrical and electronic equipment, Packaging V 1.0.0 CAD/CAE-Data CAD data 2D/3D Models 288-870/000-030 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 288-870/000-030 Potential distribution module; 4 potentials; with 6 connection points each; with 22 ground clamping points Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/7
288-870/000-030
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型放大器,具有高输入阻抗和低输出阻抗,适用于长线驱动和匹配负载。
3. 引脚分配:EL817有8个引脚,1脚为输出,2脚为参考地,3脚为输入,4脚为Vcc,5脚为输出,6脚为参考地,7脚为输入,8脚为Vcc。
4. 参数特性:工作温度范围为-40℃至+85℃,输入电压范围为3V至30V,输出电流为50mA。
5. 功能详解:EL817内部包含光敏三极管和晶体管,实现电-光-电转换,隔离电压达5000V。
6. 应用信息:适用于工业控制系统、仪器仪表、医疗设备等领域。
7. 封装信息:采用DIP-8封装。
288-870/000-030 价格&库存
很抱歉,暂时无法提供与“288-870/000-030”相匹配的价格&库存,您可以联系我们找货
  • 2+517.14426
库存:2
288-870/000-030
  • 1+781.508101+101.40003
库存:2
