289-611
289-611
    WAGO(万可电子)
    10 接线板 - 接口模块 接线板 - 螺钉连接 至 矩形,公型 - DIN 41651 12-28 AWG
289-611 数据手册
Data sheet | Item number: 289-611 Interface module; Pluggable connector per DIN 41651; 10-pole; Triple-deck PCB terminal blocks; in mounting carrier; 2,50 mm² www.wago.com/289-611 i Picture differs from the item. Similar to picture Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/6 Data sheet | Item number: 289-611 www.wago.com/289-611 Data Electrical data Operating voltage ≤100 VAC; ≤125 VDC Nominal current 1  A Safety and protection Rated voltage 100 V Rated surge voltage 0.8 kV Pollution degree 2 Protection type IP20 Connection data Pole No. 10 Connection type (1) System Pluggable connectors DIN 41651 male connector Mating direction vertical Connection type 2 Field Pole number 2 10 Design 2 PCB terminal blocks (double-deck) Connection technology 2 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/6 Data sheet | Item number: 289-611 www.wago.com/289-611 Connection technology 2 CAGE CLAMP® WAGO Connector 2 WAGO 736 Series Solid conductor 2 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 2 0.08 … 2.5 mm² / 28 … 12 AWG Strip length 2 5 … 6 mm / 0.2 … 0.24 inch Note (conductor cross-section) 12 AWG: THHN, THWN Performance level 3 / 50 mating cycles Physical data Width 35 mm / 1.378 inch Height 85 mm / 3.346 inch Depth from upper edge of DIN-rail 48 mm / 1.89 inch Mechanical data Mounting type DIN-35 rail Housing design Mounting carrier Material data Contact material (connector) Au over Ni Fire load 0.608 MJ Weight 46.9 g Environmental requirements Surrounding air temperature (operation) -20 … 55 °C Surrounding air temperature (storage) -40 … 70 °C Relative humidity  85% (non-condensing) Commercial data Product Group 6 (Interface Electronics) PU (SPU) 10 (1) Stück Packaging type box Country of origin DE GTIN 4045454471200 Customs tariff number 85366990990 Optional accessories Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/6 Data sheet | Item number: 289-611 www.wago.com/289-611 Optional accessories Cables and pluggable connectors     System cable Item no.: 706-2300/201-300 System cable; for Siemens S7-300; 8 digital outputs; Length: 3 m; Conductor cross-section: 0.14 mm² www.wago.com/706-2300 /201-300 Item no.: 706-2300/201-200 System cable; for Siemens S7-300; 8 digital outputs; Length: 2 m; Conductor cross-section: 0.14 mm² www.wago.com/706-2300 /201-200 Item no.: 706-2300/201-100 System cable; for Siemens S7-300; 8 digital outputs; Length: 1 m; Conductor cross-section: 0.14 mm² www.wago.com/706-2300 /201-100 Item no.: 706-7753/300-100 System cable; for WAGO-I/O-SYSTEM, 753 Series; 8 digital inputs or outputs; Length: 1 m; Conductor cross-section: 0.14 mm² www.wago.com/706-7753 /300-100 Item no.: 706-7753/300-200 System cable; for WAGO-I/O-SYSTEM, 753 Series; 8 digital inputs or outputs; Length: 2 m; Conductor cross-section: 0.14 mm² www.wago.com/706-7753 /300-200 Item no.: 706-7753/302-200 System cable; for WAGO-I/O-SYSTEM, 750 Series; 8 digital inputs and 8 digital outputs; Length: 2 m; Conductor cross-section: 0.14 mm² www.wago.com/706-7753 /302-200 Item no.: 706-7753/302-100 System cable; for WAGO-I/O-SYSTEM, 750 Series; 8 digital inputs and 8 digital outputs; Length: 1 m; Conductor cross-section: 0.14 mm² www.wago.com/706-7753 /302-100     Connection cable Item no.: 706-100/1301-200 Connection cable; 10-pole; Pluggable connector per DIN 41651; open-ended; Length: 2 m; Conductor cross-section: 0.14 mm²; UR components www.wago.com/706-100 /1301-200 Marking accessories     Marking strip Item no.: 709-196 Marking strips; for laser printer; translucent www.wago.com/709-196 Item no.: 709-178 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white www.wago.com/709-178 Item no.: 709-177 Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent www.wago.com/709-177 Tool Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/6 Data sheet | Item number: 289-611 www.wago.com/289-611 Tool     Operating tool Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Downloads Documentation Bid Text 289-611 Nov 20, 2015 doc 26.1 kB Download Feb 19, 2019 xml 3.6 kB Download pdf 1.3 MB Download pdf 265.8 kB Download URL Download EPLAN Data Portal 289-611 URL Download WSCAD Universe 289-611 URL Download ZUKEN Portal 289-611 URL Download URL Download doc - Datei 289-611 X81 - Datei Instruction Leaflet Additional Information Disposal; Electrical and electronic equipment, Packaging V 1.0.0 CAD/CAE-Data CAD data 2D/3D Models 289-611 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 289-611 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/6 Data sheet | Item number: 289-611 www.wago.com/289-611 Environmental Product Compliance 289-611 Interface module; Pluggable connector per DIN 41651; 10-pole; Triple-deck PCB terminal blocks; in mounting carrier; 2,50 mm² URL Download Installation Notes Inserting a conductor Conductor termination – screwdriver actuation parallel to conductor entry Conductor termination – screwdriver actuation perpendicular to conductor entry Installation Snapping a module onto DIN-rail. Removing a module from the DIN-rail. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/6
289-611 价格&库存
很抱歉,暂时无法提供与“289-611”相匹配的价格&库存,您可以联系我们找货
