706-2300/501-300
706-2300/501-300
    WAGO(万可电子)
    SYSTEM CABLE; FOR SIEMENS S7-300
706-2300/501-300 数据手册
Data sheet | Item number: 706-2300/501-300 System cable; for Siemens S7-300; 4 analog outputs (voltage); Length: 3 m; Conductor cross-section: 0.25 mm² www.wago.com/706-2300/501-300 i Picture differs from the item. Data Notes Note When using more than 10 wires, the maximum current per wire must be reduced to 1 A. Electrical data Inputs/outputs 4 analog outputs; voltage Operating voltage ≤ AC/DC 35 V Current per wire (max.) 2  A Connection data Compatible PLC Modules Siemens S7-300 Compatible PLC I/O Card Types 6ES7 332-5HB01-0AB0 6ES7 332-5HB81-0AB0 6ES7 332-5HD01-0AB0 6ES7 332-7ND02-0AB0 Connection type (1) System Pole number 1 15 Pluggable connectors D-sub female connector Connection type 2 System Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/3 Data sheet | Item number: 706-2300/501-300 www.wago.com/706-2300/501-300 Connection type 2 System Pole number 2 20 Connector 2 Siemens 6ES7-392-1BJ00-0AA0 Cable type LiYCY Wire cross-section 0.25 mm² Color code per DIN VDE 47100 Physical data Cable length 3  m Material data Weight 711 g Environmental requirements Surrounding air temperature (operation) -20 … 50 °C Commercial data PU (SPU) 1 Stück Packaging type bag Country of origin FR GTIN 4055143976787 Customs tariff number 85444290900 Downloads Documentation System Description WAGO System Wiring, Selection Guide This guide will help you select the appropriate interface modules and system cables for the controller you are usng. pdf 545.9 kB Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 706-2300/501-300 System cable; for Siemens S7-300; 4 analog outputs (voltage); Length: 3 m; Conductor cross-section: 0.25 mm² Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/3 Data sheet | Item number: 706-2300/501-300 www.wago.com/706-2300/501-300 Conductor cross-section: 0.25 mm² Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/3
706-2300/501-300 价格&库存
很抱歉,暂时无法提供与“706-2300/501-300”相匹配的价格&库存,您可以联系我们找货
