706-2500/601-200
706-2500/601-200
    WAGO(万可电子)
    S-CABLE S7-1500 A6UI1
706-2500/601-200 数据手册
Data sheet | Item number: 706-2500/601-200 System cable; for Siemens S7-1500; 4 analog inputs and 2 analog outputs, voltage, current, version 1; Length: 2 m; Conductor cross-section: 0.25 mm² www.wago.com/706-2500/601-200 i Picture differs from the item. Data Notes Note When using more than 10 wires, the maximum current per wire must be reduced to 1 A. Electrical data Inputs/outputs 4 analog inputs and 2 analog outputs; voltage Operating voltage ≤ AC/DC 35 V Current per wire (max.) 2  A Connection data Compatible PLC Modules Siemens S7-1500 Compatible PLC I/O Card Types 6ES7 534-7QE00-0AB0 Connection type (1) System Pole number 1 25 Pluggable connectors D-sub female connector Connection type 2 System Pole number 2 40 Connector 2 Siemens 6ES7-592-1AM00-0XB0 Cable type LiYCY Wire cross-section 0.25 mm² Color code per DIN VDE 47100 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/2 Data sheet | Item number: 706-2500/601-200 www.wago.com/706-2500/601-200 Color code per DIN VDE 47100 Physical data Cable length 2  m Material data Weight 567 g Environmental requirements Surrounding air temperature (operation) -20 … 50 °C Commercial data PU (SPU) 1 Stück Packaging type bag Country of origin FR GTIN 4055143602266 Customs tariff number 85444290900 Downloads Documentation System Description WAGO System Wiring, Selection Guide This guide will help you select the appropriate interface modules and system cables for the controller you are usng. pdf 545.9 kB Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 706-2500/601-200 System cable; for Siemens S7-1500; 4 analog inputs and 2 analog outputs, voltage, current, version 1; Length: 2 m; Conductor cross-section: 0.25 mm² Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/2
706-2500/601-200 价格&库存
很抱歉,暂时无法提供与“706-2500/601-200”相匹配的价格&库存,您可以联系我们找货
