713-1425
713-1425
    WAGO(万可电子)
    插件,P=3.5mm
    接线端子 间距:3.50mm 2x5P 直插
713-1425 数据手册
Data sheet | Item number: 713-1425 THT male header, 2-row; 0.8 x 0.8 mm solder pin; angled; 100% protected against mismating; Pin spacing 3.5 mm; 10-pole; black www.wago.com/713-1425 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 1/8 Data sheet | Item number: 713-1425 www.wago.com/713-1425 Dimensions in mm L = [(pole no./2) – 1] x pin spacing + 5.2 mm Item description Male headers may be mounted horizontally or vertically via straight or angled solder pins Header housing is molded of THT-compatible insulation material for lead-free reflow soldering Separated pin slots prevent damage and make the headers touch-proof when unplugged 100% protected against mismating Coding option available Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 2/8 Data sheet | Item number: 713-1425 www.wago.com/713-1425 Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Variants: Other pole numbers Other solder pin lengths Gold-plated or partially gold-plated contact surfaces Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/ Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 150 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group C) 50 V Rated current UL (Use Group C) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 150 V Rated current CSA (Use Group B) 12 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 80 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 250 V Rated surge voltage (II/2) 2.5 kV Rated current 10 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Connection data Total number of potentials 10 Number of connection types 1 Number of levels 2 Pole No. 10 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 3/8 Data sheet | Item number: 713-1425 www.wago.com/713-1425 Pole No. 10 Physical data Pin spacing 3.5 mm / 0.138 inch Width 19 mm / 0.748 inch Height 17.1 mm / 0.673 inch Height from the surface 13.3 mm / 0.524 inch Depth 13.5 mm / 0.531 inch Solder pin length 3.8 mm Solder pin dimensions 0.8 x 0.8 mm Drilled hole diameter with tolerance 1.2 (+0.1) mm Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection Yes Mating direction to the PCB 0  ° Locking of plug-in connection Without PCB contact PCB Contact THT Solder pin arrangement over the entire male connector (in-line) Number of solder pins per potential 1 Material data Color black Material group I Insulation material Polyphthalamide (PPA GF) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.059 MJ Weight 2.9 g Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 4/8 Data sheet | Item number: 713-1425 www.wago.com/713-1425 Environmental requirements Limit temperature range -60 … +100 °C Commercial data Product Group 3 (Multi Conn. System) PU (SPU) 50 Stück Packaging type box Country of origin PL GTIN 4045454700164 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. IEC 61984 NL-30980 CCA DEKRA Certification B.V. EN 61984 2169947.01 CSA DEKRA Certification B.V. C22.2 2315087 UL-Approvals Logo Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1059 E45172 Counterpart Item no.713-1105 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; 100% protected against mismating; 1,50 mm²; black www.wago.com/7131105 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 5/8 Data sheet | Item number: 713-1425 www.wago.com/713-1425 Item no.713-1105/000-047 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; 100% protected against mismating; direct marking; 1,50 mm²; black www.wago.com/7131105/000-047 Item no.713-1105/000-9037 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; 100% protected against mismating; direct marking; 1,50 mm²; black www.wago.com/7131105/000-9037 Item no.713-1105/032-047 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; 100% protected against mismating; Strain relief plate; direct marking; 1,50 mm²; black www.wago.com/7131105/032-047 Item no.713-1105/032-9037 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; 100% protected against mismating; Strain relief plate; direct marking; 1,50 mm²; black www.wago.com/7131105/032-9037 Item no.713-1105/036-000 1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 10-pole; 100% protected against mismating; Strain relief plate; 1,50 mm²; black www.wago.com/7131105/036-000 Optional accessories Coding     Coding Item no.: 714-101 Coding key; orange www.wago.com/714-101 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 713-1425 PCB Design Symbol and Footprint 713-1425 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 6/8 Data sheet | Item number: 713-1425 www.wago.com/713-1425 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 713-1425 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 713-1425 THT male header, 2-row; 0.8 x 0.8 mm solder pin; angled; 100% protected against mismating; Pin spacing 3.5 mm; 10-pole; black Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 7/8 Data sheet | Item number: 713-1425 www.wago.com/713-1425 Installation Notes Coding Coding a male header by inserting a coding pin. Product family MCS MINI HD Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 14.10.2021    Page 8/8
713-1425 价格&库存
很抱歉,暂时无法提供与“713-1425”相匹配的价格&库存,您可以联系我们找货
库存:92
