Data sheet | Item number: 713-1437
THT male header, 2-row; 0.8 x 0.8 mm solder pin; angled; 100% protected
against mismating; Pin spacing 3.5 mm; 34-pole; black
www.wago.com/713-1437
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/8
Dimensions in mm
L = [(pole no./2) – 1] x pin spacing + 5.2 mm
Item description
Male headers may be mounted horizontally or vertically via straight or angled solder pins
Header housing is molded of THT-compatible insulation material for lead-free reflow soldering
Separated pin slots prevent damage and make the headers touch-proof when unplugged
100% protected against mismating
Coding option available
Hansastr. 27
32423 Minden
13.10.2021 Page 2/8
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Variants:
Other pole numbers
Other solder pin lengths
Gold-plated or partially gold-plated contact surfaces
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
150 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group C)
50 V
Rated current UL (Use Group C)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
150 V
Rated current CSA (Use Group B)
12 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
80 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
250 V
Rated surge voltage (II/2)
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Connection data
Total number of potentials
34
Number of connection types
1
Number of levels
2
Pole No.
34
Hansastr. 27
32423 Minden
13.10.2021 Page 3/8
Pole No.
34
Physical data
Pin spacing
3.5 mm / 0.138 inch
Width
61 mm / 2.402 inch
Height
17.1 mm / 0.673 inch
Height from the surface
13.3 mm / 0.524 inch
Depth
13.5 mm / 0.531 inch
Solder pin length
3.8 mm
Solder pin dimensions
0.8 x 0.8 mm
Drilled hole diameter with tolerance
1.2 (+0.1) mm
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
Yes
Mating direction to the PCB
0 °
Locking of plug-in connection
Without
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire male connector (in-line)
Number of solder pins per potential
1
Material data
Color
black
Material group
I
Insulation material
Polyphthalamide (PPA GF)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.176 MJ
Weight
9.1 g
Hansastr. 27
32423 Minden
13.10.2021 Page 4/8
Environmental requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
20 Stück
Packaging type
box
Country of origin
PL
GTIN
4045454700287
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 61984
2169947.01
CCA
IEC 61984
NL-30980
CSA
C22.2
2315087
UL-Approvals
Logo
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172
Counterpart
Item no.713-1117/000-9037
1-conductor female connector, 2-row; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 34-pole; 100%
protected against mismating; direct marking; 1,50 mm²; black
www.wago.com/7131117/000-9037
Hansastr. 27
32423 Minden
13.10.2021 Page 5/8
Item no.713-1117
protected against mismating; 1,50 mm²; black
Item no.713-1117/000-047
www.wago.com/7131117/000-047
Item no.713-1117/035-047
protected against mismating; Strain relief plate; direct marking; 1,50 mm²; black
www.wago.com/7131117/035-047
Item no.713-1117/035-9037
www.wago.com/7131117/035-9037
Optional accessories
Coding
Coding
Item no.: 714-101
Coding key; orange
www.wago.com/714-101
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 713-1437
PCB Design
Symbol and Footprint 713-1437
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Hansastr. 27
32423 Minden
13.10.2021 Page 6/8
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 713-1437
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 713-1437
THT male header, 2-row; 0.8 x 0.8 mm solder pin; angled; 100% protected against
Installation Notes
Coding
Hansastr. 27
32423 Minden
13.10.2021 Page 7/8
Coding a male header by inserting a coding
pin.
Product family
MCS MINI HD
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 8/8
很抱歉,暂时无法提供与“713-1437”相匹配的价格&库存,您可以联系我们找货
