Data sheet | Item number: 721-235/001-040
THT male header; 1.0 x 1.0 mm solder pin; straight; 100% protected against
mismating; Preceding ground contact; Pin spacing 7.5 mm; 5-pole; light gray
www.wago.com/721-235/001-040
Preceding ground contact position
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/9
Dimensions in mm
L = (pole no. – 1) x pin spacing + 8.2 mm
Hansastr. 27
32423 Minden
07.10.2021 Page 2/9
Item description
Horizontal or vertical PCB mounting via straight or angled solder pins
Pin cross-section: 1 x 1 mm
100 % protected against mismating
With coding fingers
Hansastr. 27
32423 Minden
07.10.2021 Page 3/9
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
3.8 mm pin projection for male headers with straight solder pins
Gold-plated or partially gold-plated contact surfaces
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
15 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
15 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated voltage (III/2)
630 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
12 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Rated voltage UL 1977
600 V
Rated current UL 1977
10 A
Connection data
Total number of potentials
5
Number of connection types
1
Hansastr. 27
32423 Minden
07.10.2021 Page 4/9
1
Number of levels
1
Ground function
preceding ground contact
Pole No.
5
Physical data
Pin spacing
7.5 mm / 0.295 inch
Width
38 mm / 1.496 inch
Height
17 mm / 0.669 inch
Height from the surface
12 mm / 0.472 inch
Depth
11.4 mm / 0.449 inch
Solder pin length
5 mm
Solder pin dimensions
1 x 1 mm
Drilled hole diameter with tolerance
1.4 (+0.1) mm
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
Yes
Mating direction to the PCB
90 °
Locking of plug-in connection
Without
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire male connector (in-line)
Number of solder pins per potential
1
Material data
Color
light gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.044 MJ
Weight
2.2 g
Hansastr. 27
32423 Minden
07.10.2021 Page 5/9
Environmental requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
100 Stück
Packaging type
box
Country of origin
PL
GTIN
4044918869300
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-39756
KEMA/KEUR
EN 61984
2190761.01
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
BV
Bureau Veritas S.A.
IEC 60998
11915/D0
BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
Certificate
name
UR
UL 1977
E45171
Underwriters Laboratories Inc.
Hansastr. 27
32423 Minden
07.10.2021 Page 6/9
UR
UL 1059
E45172
Counterpart
Item no.721-205/026-000
1-conductor female connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 7.5 mm; 5-pole; 100% protected
against mismating; 2,50 mm²; light gray
www.wago.com/721-205
/026-000
Optional accessories
Coding
Coding
Item no.: 231-130
Coding key; snap-on type; light gray
www.wago.com/231-130
Marking accessories
Marking strip
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Item no.: 210-834
Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white
www.wago.com/210-834
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
EPLAN Data Portal 721-235/001-040
URL
Download
EPLAN Data
Subject
to changes.
URL
Download
CAD/CAE-Data
CAE data
Hansastr. 27
32423 Minden
07.10.2021 Page 7/9
URL
Download
URL
Download
URL
Download
PCB Design
Symbol and Footprint 721-235/001-040
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 721-235/001-040
Hansastr. 27
32423 Minden
07.10.2021 Page 8/9
Installation Notes
Coding
Coding a male header – fitting coding key(s).
Product family
MCS MIDI
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 9/9
很抱歉,暂时无法提供与“721-235/001-040”相匹配的价格&库存,您可以联系我们找货
