722-136/005-000/039-000
    WAGO(万可电子)
    插件
    接线端子
722-136/005-000/039-000 数据手册
Data sheet | Item number: 722-136/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 6-pole; light gray www.wago.com/722-136/005-000/039-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/7 Data sheet | Item number: 722-136/005-000/039-000 www.wago.com/722-136/005-000/039-000 Dimensions in mm L = (pole no. x pin spacing) + 1.5 mm 2-pole female connectors – one latch only Item description Pluggable connectors for rail-mount terminal blocks equipped with CAGE CLAMP® connection Female connectors with long contact pins connect to the termination ports of 280 Series Rail-Mount Terminal Blocks Female connectors are touch-proof when unmated, providing a pluggable, live output 100 % protected against mismating With coding fingers Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/7 Data sheet | Item number: 722-136/005-000/039-000 www.wago.com/722-136/005-000/039-000 Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Variants: Other pole numbers Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/ Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 320 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 12 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Rated voltage UL 1977 600 V Rated current UL 1977 15 A Connection data Total number of potentials 6 Number of connection types 1 Number of levels 1 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/7 Data sheet | Item number: 722-136/005-000/039-000 www.wago.com/722-136/005-000/039-000 Number of levels 1 Pole No. 6 Physical data Pin spacing 5 mm / 0.197 inch Width 45.8 mm / 1.803 inch Height 36.1 mm / 1.421 inch Height from the surface 21.6 mm / 0.85 inch Depth 11.6 mm / 0.457 inch Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for front-entry rail-mount terminal block Mismating protection Yes Locking of plug-in connection locking lever Mating direction to the rail-mount terminal block 90 ° Material data Color light gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Contact material Copper alloy Contact plating tin-plated Fire load 0.103 MJ Weight 7.2 g Environmental requirements Limit temperature range -60 … +85 °C Commercial data Product Group 3 (Multi Conn. System) PU (SPU) 50 Stück Packaging type box Country of origin DE GTIN 4044918571425 Customs tariff number 85366990990 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/7 Data sheet | Item number: 722-136/005-000/039-000 www.wago.com/722-136/005-000/039-000 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CSA DEKRA Certification B.V. C22.2 1466354 Ship Approvals Logo Approval Additional Approval Text ABS American Bureau of Shipping - Certificate name 19HG1869876PDA UL-Approvals Logo Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.721-606 1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 5 mm; 6-pole; 100% protected against mismating; 2,50 mm²; light gray www.wago.com /721-606 Optional accessories Testing and measuring     Testing accessories Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 231-661 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/231-661 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 5/7 Data sheet | Item number: 722-136/005-000/039-000 www.wago.com/722-136/005-000/039-000 Item no.: 231-661 Test plugs for female connectors; for 5 mm and 5.08 mm pin spacing; 2,50 mm²; light gray www.wago.com/231-661 Mounting     Component plug housing as rail-mount terminal block Item no.: 280-835/056-000 Spacer of same profile; suitable for 4-conductor terminal blocks of horizontal type; orange www.wago.com/280-835 /056-000 Item no.: 280-902/056-000 Spacer of same profile; suitable for 2-conductor terminal blocks of horizontal type; orange www.wago.com/280-902 /056-000 Item no.: 280-650/056-000 Spacer of same profile; suitable for 3-conductor terminal blocks of horizontal type; orange www.wago.com/280-650 /056-000 Item no.: 280-654/056-000 Spacer of same profile; suitable for 3- and 4-conductor terminal blocks of angled type; orange www.wago.com/280-654 /056-000 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 722-136/005-000/039-000 CAE data EPLAN Data Portal 722-136/005-000/039-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 722-136/005-000/039-000 Female connector for rail-mount terminal blocks; 0.6 x 1 mm pins; straight; 100% protected against mismating; Locking lever; Pin spacing 5 mm; 6-pole; light gray Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 6/7 Data sheet | Item number: 722-136/005-000/039-000 www.wago.com/722-136/005-000/039-000 Installation Notes Product family MCS MIDI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 7/7
722-136/005-000/039-000 价格&库存
很抱歉,暂时无法提供与“722-136/005-000/039-000”相匹配的价格&库存,您可以联系我们找货
