727-138
727-138
    WAGO(万可电子)
    8-LEVEL SAME POTENTIAL TERMINAL
727-138 数据手册
Data sheet | Item number: 727-138 8-level same potential terminal block; without locking clips; all clamping units internally commoned; with 2.3 mm Ø test port; for 35 x 15 mounting rail; 1.5 mm²; 1,50 mm²; light gray www.wago.com/727-138 i Picture differs from the item. Color: Data Electrical data Ratings per IEC/EN Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated current 18 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Total number of connection points 32 Total number of potentials 1 Number of levels 8 Connection 1 Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Solid conductor 0.08 … 1.5 mm² / 28 … 16 AWG Fine-stranded conductor 0.08 … 1.5 mm² / 28 … 16 AWG Strip length 8 … 10 mm / 0.31 … 0.39 inch Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 1/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Strip length 8 … 10 mm / 0.31 … 0.39 inch Wiring direction Front-entry wiring Physical data Width 7.62 mm / 0.3 inch Height 226 mm / 8.898 inch Depth from upper edge of DIN-rail 58.5 mm / 2.303 inch Mechanical data Marking plain Design horizontal type Mounting type DIN-35 rail Marking level Center marking Material data Note on material data Information on material data can be found here Color light gray Insulation material Polyamide (PA66) Flammability class per UL94 V0 Fire load 1.187 MJ Weight 61.7 g Commercial data PU (SPU) 25 Stück Packaging type box Country of origin DE GTIN 4045454188399 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 CSA C22.2 No. 158 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate name NTR NL 7485 70048845 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 2/13 Data sheet | Item number: 727-138 www.wago.com/727-138 CSA DEKRA Certification B.V. C22.2 No. 158 70048845 KEMA/KEUR DEKRA Certification B.V. EN 60947 2192101.01 UL-Approvals Logo Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1059 E45172 Required accessories End plate     End plate Item no.: 727-116 8-level end plate; plain; 7.62 mm thick; light gray www.wago.com/727-116 Item no.: 727-117 8-level end plate; plain; 7.62 mm thick; orange www.wago.com/727-117 Item no.: 727-114 8-level end plate; plain; 7.62 mm thick; blue www.wago.com/727-114 Item no.: 727-113 8-level end plate; plain; 7.62 mm thick; gray www.wago.com/727-113 Item no.: 727-115 8-level end plate; plain; 7.62 mm thick; white www.wago.com/727-115 Optional accessories Tool     Operating tool Item no.: 210-647 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured www.wago.com/210-647 Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Carrier rail     Mounting accessories Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 3/13 Data sheet | Item number: 727-138 www.wago.com/727-138     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Mounting     Mounting accessories Item no.: 249-109 Wire harness support; gray www.wago.com/249-109 Item no.: 709-107 Wire commoning chain; 0.5 mm²; insulated; gray www.wago.com/709-107 Jumpers     Jumper Insulation stop Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 4/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Insulation stop     Insulation stop Item no.: 727-197 Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 8 pieces/strip; white www.wago.com/727-197 Item no.: 727-198 Insulation stop; 0.25 mm² “s”; 0.14 - 0.25 mm² “f-st”; 8 pieces/strip; light gray www.wago.com/727-198 Item no.: 727-199 Insulation stop; 0.25 - 0.5 mm² "s+f-st"; 8 pieces/strip; dark gray www.wago.com/727-199 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored www.wago.com/216-104 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored www.wago.com/216-123 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-122 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Ferrule     Ferrule Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-151 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 5/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; light turquoise www.wago.com/216-302 Marking accessories     Double marker carrier Item no.: 209-128 Adaptor; gray www.wago.com/209-128 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017     Marker Item no.: 2009-115/000-023 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-115 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 6/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-115 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 793-5501/000-007 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-007 type; gray Item no.: 793-5501/000-012 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-012 type; orange Item no.: 793-5501/000-017 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-017 type; green Item no.: 793-5501/000-023 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-023 type; light green Item no.: 793-5501/000-024 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-024 type; violet Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-012 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 7/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501/000-005 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-005 type; red Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-002 type; yellow Item no.: 793-5501/000-006 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on /000-006 type; blue Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501 type; white Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange Item no.: 2009-115/000-006 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-115 /000-012 www.wago.com/2009-115 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 8/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Testing and measuring     Testing accessories Item no.: 210-297 Step-down test plug; from 4mm socket to 2mm plug; red www.wago.com/210-297 Downloads Documentation Bid Text 727-138 Feb 21, 2019 docx 15.9 kB Download Feb 19, 2019 xml 3.7 kB Download pdf 125.0 kB Download pdf 2.2 MB Download URL Download EPLAN Data Portal 727-138 URL Download ZUKEN Portal 727-138 URL Download WSCAD Universe 727-138 URL Download URL Download docx - Datei 727-138 X81 - Datei Additional Information Technical explanations CAD/CAE-Data CAD data 2D/3D Models 727-138 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 727-138 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 9/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Environmental Product Compliance 727-138 URL Download 8-level same potential terminal block; without locking clips; all clamping units internally commoned; with 2.3 mm Ø test port; for 35 x 15 mounting rail; 1.5 mm²; 1,50 mm²; light gray Installation Notes Installation Example of matrix patching assembly Terminal blocks for DIN-35 x 7.5 mm or DIN35 x 15 mm rails are available. Snap individual 4- or 8-level terminal blocks onto the DIN-rail. Grip end plate at both sides and: Open the assembly by laterally sliding a block via operating tool (2.5 x 0.4 mm blade). Left: Main cables fed through locking clips on the field side Right: Control cables fed between locking clips Center: Wiring of both patching sides Slide terminal blocks together. push down (assembly) pull up (removal) Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 10/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Slide terminal block and remove from the rail with a levering action. Conductor termination CAGE CLAMP® connection Inserting a conductor via 210-719 Operating Tool (2.5 x 0.4 mm blade). Max. cross-section for uninsulated ferrules 1 mm² (18 AWG), for insulated ferrules 0.75 mm² (20 AWG) Testing Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 11/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Special test contact for 2.3 mm Ø test plug Ex application Blue terminal blocks for matrix patching are suitable for Ex i applications. Using terminal blocks with locking clips, the wiring space between the terminal strips can be covered with a wiring duct cover. Marking Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 12/13 Data sheet | Item number: 727-138 www.wago.com/727-138 Connection points identified via factorydirect printing Marking coordinates via WMB Multi Marking System. Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 13/13
727-138 价格&库存
很抱歉,暂时无法提供与“727-138”相匹配的价格&库存,您可以联系我们找货
