Data sheet | Item number: 727-226
4-level same potential terminal block; without locking clips; all clamping units
internally commoned; with 2.3 mm Ø test port; for 35 x 7.5 mounting rail; 1,50
mm²; orange
www.wago.com/727-226
Color:
Data
Electrical data
Nominal voltage (III/3)
250 V
Rated surge voltage (III/3)
4 kV
Rated current
18 A
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/13
Rated current
18 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
16
Total number of potentials
1
Number of levels
4
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 1.5 mm² / 28 … 16 AWG
Fine-stranded conductor
Strip length
8 … 10 mm / 0.31 … 0.39 inch
Wiring direction
Front-entry wiring
Physical data
Width
7.62 mm / 0.3 inch
Height
126 mm / 4.961 inch
Depth from upper edge of DIN-rail
44.5 mm / 1.752 inch
Mechanical data
Marking
plain
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Center marking
Material data
Color
orange
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.562 MJ
Weight
30 g
Commercial data
PU (SPU)
50 Stück
Packaging type
box
Country of origin
DE
Hansastr. 27
32423 Minden
07.10.2021 Page 2/13
Country of origin
DE
GTIN
4045454189051
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL
7485
CSA
C22.2 No. 158
70048845
KEMA/KEUR
EN 60947
2192101.01
UL-Approvals
Logo
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1059
E45172
Required accessories
End plate
End plate
Item no.: 727-217
4-level end plate; plain; 7.62 mm thick; orange
www.wago.com/727-217
Item no.: 727-213
4-level end plate; plain; 7.62 mm thick; gray/gray
www.wago.com/727-213
Item no.: 727-214
4-level end plate; plain; 7.62 mm thick; blue
www.wago.com/727-214
Optional
accessories
Hansastr. 27
32423 Minden
07.10.2021 Page 3/13
Optional accessories
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-222
Hansastr. 27
32423 Minden
07.10.2021 Page 4/13
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Item no.: 709-107
Wire commoning chain; 0.5 mm²; insulated; gray
www.wago.com/709-107
Jumpers
Jumper
Tool
Operating tool
Item no.: 210-647
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-647
Item no.: 210-719
www.wago.com/210-719
Testing and measuring
Testing accessories
Item no.: 210-297
Step-down test plug; from 4mm socket to 2mm plug; red
www.wago.com/210-297
Carrier rail
Mounting accessories
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored
www.wago.com/210-504
Item no.: 210-505
Hansastr. 27
32423 Minden
www.wago.com/210-505
07.10.2021 Page 5/13
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715;
silver-colored
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
silver-colored
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Mounting
Item no.: 249-109
Wire harness support; gray
www.wago.com/249-109
Insulation stop
Insulation stop
Item no.: 727-197
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 8 pieces/strip; white
www.wago.com/727-197
Item no.: 727-198
Insulation stop; 0.25 mm² “s”; 0.14 - 0.25 mm² “f-st”; 8 pieces/strip; light gray
www.wago.com/727-198
Item no.: 727-199
Insulation stop; 0.25 - 0.5 mm² "s+f-st"; 8 pieces/strip; dark gray
www.wago.com/727-199
Marking accessories
Double marker carrier
Item no.: 209-128
Adaptor; gray
www.wago.com/209-128
Marker
Hansastr. 27
32423 Minden
07.10.2021 Page 6/13
Marker
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
www.wago.com/2009-115
/000-002
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 793-5501/000-007
www.wago.com/793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
Item no.: 793-501/000-002
Hansastr. 27
32423 Minden
www.wago.com/793-501
07.10.2021 Page 7/13
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-006
Hansastr. 27
32423 Minden
07.10.2021 Page 8/13
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
/000-006
type; blue
Item no.: 793-5501
type; white
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Downloads
Documentation
Bid Text
727-226
Feb 21, 2019
docx
15.6 kB
Download
Feb 19, 2019
xml
3.4 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
EPLAN Data Portal 727-226
URL
Download
ZUKEN Portal 727-226
URL
Download
WSCAD Universe 727-226
URL
Download
URL
Download
docx - Datei
727-226
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAE data
CAD data
2D/3D Models 727-226
Hansastr. 27
32423 Minden
07.10.2021 Page 9/13
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 727-226
URL
Download
internally commoned; with 2.3 mm Ø test port; for 35 x 7.5 mounting rail; 1,50 mm²;
orange
Installation Notes
Installation
Example of matrix patching assembly
Terminal blocks for DIN-35 x 7.5 mm or DIN35 x 15 mm rails are available.
Snap individual 4- or 8-level terminal blocks
onto the DIN-rail.
Left: Main cables fed through locking clips
on the field side
Right: Control cables fed between locking
clips
Center: Wiring of both patching sides
Slide terminal blocks together.
Hansastr. 27
32423 Minden
07.10.2021 Page 10/13
Grip end plate at both sides and:
Open the assembly by laterally sliding a
block via operating tool (2.5 x 0.4 mm blade).
Slide terminal block and remove from the rail
with a levering action.
push down (assembly)
pull up (removal)
Conductor termination
CAGE CLAMP® connection
Inserting a conductor via 210-719 Operating
Tool (2.5 x 0.4 mm blade).
Max. cross-section for uninsulated ferrules 1
mm² (18 AWG), for insulated ferrules 0.75
mm² (20 AWG)
Testing
Hansastr. 27
32423 Minden
07.10.2021 Page 11/13
Special test contact for 2.3 mm Ø test plug
Ex application
Blue terminal blocks for matrix patching are
suitable for Ex i applications.
Using terminal blocks with locking clips, the
wiring space between the terminal strips can
be covered with a wiring duct cover.
Marking
Hansastr. 27
32423 Minden
07.10.2021 Page 12/13
Connection points identified via factorydirect printing
Marking coordinates via WMB Multi Marking
System.
Hansastr. 27
32423 Minden
07.10.2021 Page 13/13
很抱歉,暂时无法提供与“727-226”相匹配的价格&库存,您可以联系我们找货
