732-108/026-000
732-108/026-000
    WAGO(万可电子)
    P=7.5mm
    接线端子 间距:7.50mm 1x8P 自由悬挂(直插式)
732-108/026-000 数据手册
Data sheet | Item number: 732-108/026-000 1-conductor female connector, angled; CAGE CLAMP®; 2.5 mm²; Pin spacing 7.5 mm; 8-pole; 2,50 mm²; gray www.wago.com/732-108/026-000 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Dimensions in mm Total length = (pole no. – 1) x pin spacing + 5 mm + 1.5 mm + 0.9 mm Item description Universal connection for all conductor types Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation Integrated test ports With coding fingers Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Variants: Gold-plated or partially gold-plated contact surfaces Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/ Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 15 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 15 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 500 V Rated surge voltage (III/3) 6 kV Rated voltage (III/2) 630 V Rated surge voltage (III/2) 6 kV Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 6 kV Rated current 14 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Rated voltage UL 1977 600 V Rated current UL 1977 15 A Connection data Total number of connection points 8 Total number of potentials 8 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Total number of potentials 8 Number of connection types 1 Number of levels 1 Connection technology CAGE CLAMP® Actuation type Operating tool Solid conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 1.5 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 2.5 mm² Strip length 8 … 9 mm / 0.31 … 0.35 inch Pole No. 8 Conductor entry direction to mating direction 270 ° Physical data Pin spacing 7.5 mm / 0.295 inch Width 59.9 mm / 2.358 inch Height 23.9 mm / 0.941 inch Depth 22.75 mm / 0.896 inch Mechanical data Design angled Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for conductor Mismating protection No Locking of plug-in connection Without Material data Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load 0.336 MJ Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Fire load 0.336 MJ Weight 18.2 g Environmental requirements Limit temperature range -60 … +85 °C Commercial data Product Group 3 (Multi Conn. System) PU (SPU) 25 Stück Packaging type box Country of origin DE GTIN 4044918391863 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-39756 KEMA/KEUR DEKRA Certification B.V. EN 61984 2190761.01 Ship Approvals Logo Approval Additional Approval Text ABS American Bureau of Shipping - Certificate name 19HG1869876PDA UL-Approvals Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1059 E45172 UR UL 1977 Subject to changes. Please also observe the further product documentation! E45171 Logo WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 5/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 UR Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.731-608 1-conductor male connector; CAGE CLAMP®; 2.5 mm²; Pin spacing 7.5 mm; 8-pole; 2,50 mm²; gray www.wago.com/731-608 Item no.231-238/001-000 THT male header; 1.0 x 1.0 mm solder pin; straight; Pin spacing 7.5 mm; 8-pole; gray www.wago.com/231-238/001000 Item no.231-838/001-000 THT male header; 1.0 x 1.0 mm solder pin; angled; Pin spacing 7.5 mm; 8-pole; gray www.wago.com/231-838/001000 Optional accessories Testing and measuring     Testing accessories Item no.: 210-136 Test plug; 2 mm Ø; with 500 mm cable; red www.wago.com/210-136 Item no.: 231-662 Test plugs for female connectors; for 7.5 mm and 7.62 mm pin spacing; 2,50 mm²; light gray www.wago.com/231-662 Insulation stop     Insulation stop Item no.: 231-673 Insulation stop; 0.08-0.2 mm² / 0.2 mm² “s”; white www.wago.com/231-673 Item no.: 231-674 Insulation stop; 0.25 - 0.5 mm²; light gray www.wago.com/231-674 Item no.: 231-675 Insulation stop; 0.75 - 1 mm²; dark gray www.wago.com/231-675 Marking accessories     Marking strip Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 6/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000     Marking strip Item no.: 210-331/750-202 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-331 /750-202 Item no.: 210-332/750-020 Marking strips; as a DIN A4 sheet; MARKED; 1-20 (80x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /750-020 Tool     Operating tool Item no.: 231-291 Operating tool; made of insulating material; 1-way; loose; red www.wago.com/231-291 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-104 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored www.wago.com/216-104 Item no.: 216-106 Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored www.wago.com/216-106 Item no.: 216-107 Ferrule; Sleeve for 4 mm² / AWG 12; uninsulated; electro-tin plated www.wago.com/216-107 Item no.: 216-108 Ferrule; Sleeve for 6 mm² / AWG 10; uninsulated; electro-tin plated; silver-colored www.wago.com/216-108 Item no.: 216-109 Ferrule; Sleeve for 10 mm² / AWG 8; uninsulated; electro-tin plated www.wago.com/216-109 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-110 Ferrule; Sleeve for 16 mm² / AWG 6; uninsulated; electro-tin plated; metallic brown www.wago.com/216-110 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored www.wago.com/216-123 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-122 Item no.: 216-124 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated www.wago.com/216-124 Ferrule     Ferrule Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-142 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 7/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-206 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue www.wago.com/216-206 Item no.: 216-207 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; gray www.wago.com/216-207 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Item no.: 216-204 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-204 Item no.: 216-209 Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; red www.wago.com/216-209 Item no.: 216-205 Ferrule; Sleeve for 2.08 mm² / AWG 14; insulated; electro-tin plated; yellow www.wago.com/216-205 Item no.: 216-144 Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92; silver-colored www.wago.com/216-144 Item no.: 216-208 Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-208 acc. to DIN 46228, Part 4/09.90; yellow Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 8/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-210 Ferrule; Sleeve for 16 mm² / AWG 6; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-210 acc. to DIN 46228, Part 4/09.90; blue Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-224 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black www.wago.com/216-224 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-246 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-286 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-286 Item no.: 216-287 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287 acc. to DIN 46228, Part 4/09.90; gray Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-262 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 9/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-288 Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288 acc. to DIN 46228, Part 4/09.90; yellow Item no.: 216-289 Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-289 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 216-267 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-267 acc. to DIN 46228, Part 4/09.90; gray Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download EPLAN Data Portal 732-108/026-000 URL Download ZUKEN Portal 732-108/026-000 URL Download EPLAN Data Portal 732-108/026-000 URL Download URL Download CAD/CAE-Data CAE data CAD data 2D/3D Models 732-108/026-000 Environmental Product Compliance Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 10/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 732-108/026-000 URL Download 1-conductor female connector, angled; CAGE CLAMP®; 2.5 mm²; Pin spacing 7.5 mm; 8-pole; 2,50 mm²; gray Installation Notes Inserting a conductor via 3.5 mm screwdriver – CAGE CLAMP® actuation parallel to conductor entry. Inserting a conductor via 3.5 mm screwdriver – CAGE CLAMP® actuation perpendicular to conductor entry. Inserting a conductor into CAGE CLAMP® unit via operating lever (231-291). Inserting a conductor via operating tool. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 11/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Coding a female connector by removing coding finger(s). Testing – female connector with CAGE CLAMP® Integrated test ports for testing perpendicular to conductor entry via 2 or 2.3 mm Ø test plug Installation Male connector with strain relief plate Strain relief housing shown with a male connector equipped with CAGE CLAMP® Marking Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 12/13 Data sheet | Item number: 732-108/026-000 www.wago.com/732-108/026-000 Marking Labeling via direct marking or self-adhesive strips. Product family MCS MIDI Classic Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 13/13
732-108/026-000 价格&库存
很抱歉,暂时无法提供与“732-108/026-000”相匹配的价格&库存,您可以联系我们找货
