Data sheet | Item number: 734-318/019-000
1-conductor male connector; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm;
18-pole; 100% protected against mismating; clamping collar; 1,50 mm²; light
gray
www.wago.com/734-318/019-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/13
Dimensions in mm
L = (pole no. x pin spacing) + 14.8 mm
L1 = (pole no. x pin spacing) + 8.8 mm
L2 = pole no. x pin spacing
L3 = (pole no. – 1) x pin spacing + 5.9 mm
Item description
Universal connection for all conductor types
Easy cable pre-assembly and on-unit wiring via vertical and horizontal CAGE CLAMP® actuation
For wire-to-wire and board-to-wire connections
Hansastr. 27
32423 Minden
07.10.2021 Page 2/13
Strain relief plates and housings for factory and field assembly
Coding option available
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Gold-plated or partially gold-plated contact surfaces
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
160 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Hansastr. 27
32423 Minden
07.10.2021 Page 3/13
Connection data
Total number of connection points
18
Total number of potentials
18
Number of connection types
1
Number of levels
1
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.08 … 1.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 1.5 mm²
Note (conductor cross-section)
Terminating 1.5 mm² conductors is possible; however insulation
diameter does not allow clamping units to be terminated in a row.
Strip length
6 … 7 mm / 0.24 … 0.28 inch
Pole No.
18
Conductor entry direction to mating direction
0 °
Physical data
Pin spacing
3.5 mm / 0.138 inch
Width
77.8 mm / 3.063 inch
Height
13.4 mm / 0.528 inch
Depth
22.3 mm / 0.878 inch
Mechanical data
Mounting type
Mounting flange
Mounting type
Feed-through mounting
Panel mounting
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for conductor
Mismating protection
Yes
Locking of plug-in connection
Without
Hansastr. 27
32423 Minden
07.10.2021 Page 4/13
Material data
Color
light gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.293 MJ
Weight
15.5 g
Environmental requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
25 Stück
Packaging type
box
Country of origin
PL
GTIN
4055143269018
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 61984
2169534.02
CCA
EN 61984
nl-54190
CSA
C22.2
1465035
Hansastr. 27
32423 Minden
07.10.2021 Page 5/13
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
BV
Bureau Veritas S.A.
IEC 60998
11915/D0
BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1977
E45171
UR
Underwriters Laboratories Inc.
UL 1059
E45172
Counterpart
Item no.734-118
www.wago.com
1-conductor female connector; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 18-pole; 100% protected against
/734-118
mismating; 1,50 mm²; light gray
Item no.734-478
THT female header; straight; Pin spacing 3.5 mm; 18-pole; 100% protected against mismating; 0.9 x 0.9 mm
solder pin; light gray
www.wago.com
/734-478
Item no.734-548
THT female header; angled; Pin spacing 3.5 mm; 18-pole; 100% protected against mismating; 0.9 x 0.9 mm
www.wago.com
/734-548
Optional accessories
Mounting
Mounting accessories
Hansastr. 27
32423 Minden
07.10.2021 Page 6/13
Item no.: 209-147
Self-tapping screw
www.wago.com/209-147
Item no.: 231-194
Self-tapping screw; B 2.2x13, fixing hole 1.8 mm Ø
www.wago.com/231-194
Item no.: 231-195
Screw with nut; M2x12; for fixing element
www.wago.com/231-195
Item no.: 231-295
Screw with nut
www.wago.com/231-295
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Ferrule
Ferrule
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Hansastr. 27
32423 Minden
07.10.2021 Page 7/13
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Hansastr. 27
32423 Minden
07.10.2021 Page 8/13
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Testing and measuring
Testing accessories
Item no.: 735-500
Test pin; 1 mm Ø; with solder connection for test wire
www.wago.com/735-500
Tool
Operating tool
Item no.: 210-250
Operating tool; for MCS MINI & MIDI with CAGE CLAMP® connection; red
www.wago.com/210-250
Item no.: 210-251
Operating tool; for MCS MICRO & MINI with CAGE CLAMP® connection; yellow
www.wago.com/210-251
Item no.: 210-647
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-647
Item no.: 210-719
www.wago.com/210-719
Item no.: 734-230
Operating tool; made of insulating material; 1-way; white
www.wago.com/734-230
Item no.: 734-190
Combination operating tool; natural
www.wago.com/734-190
Item no.: 734-191
Operating tool; made of insulating material; 1-way; loose; black
www.wago.com/734-191
Hansastr. 27
32423 Minden
07.10.2021 Page 9/13
Item no.: 734-231
Operating tool; black
www.wago.com/734-231
Item no.: 734-420
Cover for male connectors; for 734 Series; IP20 protection; black
www.wago.com/734-420
Item no.: 734-130
Coding key; to be snapped above top level; white
www.wago.com/734-130
Cover
Cover
Coding
Coding
Marking accessories
Marking strip
Item no.: 210-332/350-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (240x); Height of marker strip: 3 mm; Strip length 182
/350-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/350-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (240x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/350-206
Item no.: 210-332/350-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (240x); Height of marker strip: 3 mm; Strip length
/350-204
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
EPLAN Data Portal 734-318/019-000
URL
Download
ZUKEN Portal 734-318/019-000
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 734-318/019-000
CAE data
Hansastr. 27
32423 Minden
07.10.2021 Page 10/13
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 734-318/019-000
1-conductor male connector; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 18-pole;
100% protected against mismating; clamping collar; 1,50 mm²; light gray
Installation Notes
Conductor termination
Inserting a conductor into CAGE CLAMP®
unit via operating tool (210-251 or 210-250).
Inserting a conductor via (2.5 x 0.4) mm
screwdriver – CAGE CLAMP® actuation
parallel to conductor entry.
perpendicular to conductor entry.
unit via operating lever (734-191).
Testing
Hansastr. 27
32423 Minden
07.10.2021 Page 11/13
Testing
Testing via 1 mm Ø test pin (735-500) –
CAGE CLAMP® connection – touch contact.
Marking
Labeling via direct marking or self-adhesive
strips.
Installation
Strain relief housing for 734 Series Male and
Female Connectors with CAGE CLAMP®
connection
Product family
Hansastr. 27
32423 Minden
07.10.2021 Page 12/13
MCS MINI
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 13/13
很抱歉,暂时无法提供与“734-318/019-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+258.899461+33.47929
- 10+186.1862710+24.07647
- 25+167.1164625+21.61048
- 50+155.8538650+20.15407
- 100+146.88474100+18.99424
- 250+137.88987250+17.83108
- 500+132.79980500+17.17286
