Data sheet | Item number: 734-432
THT double-deck male header; 1.0 x 1.0 mm solder pin; angled; 100%
protected against mismating; Pin spacing 3.81 mm; 4-pole; orange
www.wago.com/734-432
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/8
Dimensions in mm
L1 = (pole no./2 – 1) x pin spacing + 5.9 mm
Item description
Horizontal or vertical PCB mounting via straight or angled solder pins
100% protected against mismating; only mating halves with the same number of poles can be connected together
Coding option available
Hansastr. 27
32423 Minden
13.10.2021 Page 2/8
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Variants:
Other pole numbers
Gold-plated or partially gold-plated contact surfaces
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
160 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Connection data
Total number of potentials
4
Number of connection types
1
Number of levels
2
Hansastr. 27
32423 Minden
13.10.2021 Page 3/8
Number of levels
2
Pole No.
4
Physical data
Pin spacing
3.81 mm / 0.15 inch
Width
9.71 mm / 0.382 inch
Height
26.6 mm / 1.047 inch
Height from the surface
23 mm / 0.906 inch
Depth
16.8 mm / 0.661 inch
Solder pin length
3.6 mm
Solder pin dimensions
1 x 1 mm
Drilled hole diameter with tolerance
1.4 (+0.1) mm
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
Yes
Mating direction to the PCB
0 °
Locking of plug-in connection
Without
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire male connector (in-line)
Number of solder pins per potential
1
Material data
Color
orange
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.056 MJ
Weight
2.8 g
Hansastr. 27
32423 Minden
13.10.2021 Page 4/8
Environmental requirements
Limit temperature range
-60 … +100 °C
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
100 Stück
Packaging type
box
Country of origin
DE
GTIN
4044918873093
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
EN 61984
NL-54190
CSA
C22.2
1465035
KEMA/KEUR
EN 61984
71105522
Approval
LR
Lloyds Register
IEC 61984
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
UL 1977
E45171
Ship Approvals
Logo
Certificate
name
96/20035
(E5)
UL-Approvals
Logo
Hansastr. 27
32423 Minden
13.10.2021 Page 5/8
UR
UL 1059
E45172
Counterpart
Item no.734-202
www.wago.com
1-conductor female connector; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.81 mm; 2-pole; 100% protected against
/734-202
mismating; 1,50 mm²; orange
Optional accessories
Coding
Coding
Item no.: 734-159
Coding key; to be snapped above top level; black
www.wago.com/734-159
Item no.: 734-400
Coding key; to be snapped above bottom level; light gray
www.wago.com/734-400
Item no.: 734-130
Coding key; to be snapped above top level; white
www.wago.com/734-130
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
CAD/CAE-Data
PCB Design
Symbol and Footprint 734-432
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Hansastr. 27
32423 Minden
13.10.2021 Page 6/8
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 734-432
URL
Download
EPLAN Data Portal 734-432
URL
Download
URL
Download
URL
Download
CAD data
2D/3D Models 734-432
Environmental Product Compliance
Compliance Search
Environmental
Product
Compliance
734-432
Subject
to changes.
Please
also observe
Hansastr. 27
32423 Minden
13.10.2021 Page 7/8
Environmental Product Compliance 734-432
URL
Download
THT double-deck male header; 1.0 x 1.0 mm solder pin; angled; 100% protected
Installation Notes
Coding
Coding a THT double-deck male header –
lower level.
Coding a THT double-deck male header.
Product family
MCS MINI
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 8/8
很抱歉,暂时无法提供与“734-432”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+26.463591+3.43947
