734-438/001-000
734-438/001-000
    WAGO(万可电子)
    插件,P=3.81mm
    接线端子 间距:3.81mm 2x8P 直插
734-438/001-000 数据手册
Data sheet | Item number: 734-438/001-000 THT double-deck male header; 1.0 x 1.0 mm solder pin; angled; 100% protected against mismating; Pin spacing 3.81 mm; 16-pole; orange www.wago.com/734-438/001-000 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/8 Data sheet | Item number: 734-438/001-000 www.wago.com/734-438/001-000 Dimensions in mm L1 = (pole no./2 – 1) x pin spacing + 5.9 mm Item description Horizontal or vertical PCB mounting via straight or angled solder pins 100% protected against mismating; only mating halves with the same number of poles can be connected together Coding option available Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/8 Data sheet | Item number: 734-438/001-000 www.wago.com/734-438/001-000 Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole numbers Gold-plated or partially gold-plated contact surfaces Electrical data Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Rated voltage CSA (Use Group D) 300 V Rated current CSA (Use Group D) 10 A Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 160 V Rated surge voltage (III/3) 2.5 kV Rated voltage (III/2) 160 V Rated surge voltage (III/2) 2.5 kV Nominal voltage (II/2) 320 V Rated surge voltage (II/2) 2.5 kV Rated current 10 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Connection data Total number of potentials 16 Number of connection types 1 Number of levels 2 Pole No. 16 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/8 Data sheet | Item number: 734-438/001-000 www.wago.com/734-438/001-000 Pole No. 16 Physical data Pin spacing 3.81 mm / 0.15 inch Width 32.57 mm / 1.282 inch Height 26.6 mm / 1.047 inch Height from the surface 23 mm / 0.906 inch Depth 21.8 mm / 0.858 inch Solder pin length 3.6 mm Solder pin dimensions 1 x 1 mm Drilled hole diameter with tolerance 1.4 (+0.1) mm Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection Yes Mating direction to the PCB 0  ° Locking of plug-in connection Without PCB contact PCB Contact THT Solder pin arrangement over the entire male connector (in-line) Number of solder pins per potential 1 Material data Color orange Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Fire load 0.179 MJ Weight 9.7 g Environmental requirements Limit temperature range -60 … +100 °C Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/8 Data sheet | Item number: 734-438/001-000 www.wago.com/734-438/001-000 Commercial data Product Group 3 (Multi Conn. System) PU (SPU) 50 Stück Packaging type box Country of origin DE GTIN 4044918873277 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. EN 61984 NL-54190 CSA DEKRA Certification B.V. C22.2 1465035 KEMA/KEUR DEKRA Certification B.V. EN 61984 71105522 Approval Additional Approval Text Certificate name UL Underwriters Laboratories Inc. UL 1977 E45171 UL Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Counterpart Item no.734-208 www.wago.com 1-conductor female connector; CAGE CLAMP®; 1.5 mm²; Pin spacing 3.81 mm; 8-pole; 100% protected against /734-208 mismating; 1,50 mm²; orange Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/8 Data sheet | Item number: 734-438/001-000 www.wago.com/734-438/001-000 Optional accessories Coding     Coding Item no.: 734-159 Coding key; to be snapped above top level; black www.wago.com/734-159 Item no.: 734-400 Coding key; to be snapped above bottom level; light gray www.wago.com/734-400 Item no.: 734-130 Coding key; to be snapped above top level; white www.wago.com/734-130 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download EPLAN Data Portal 734-438/001-000 URL Download ZUKEN Portal 734-438/001-000 URL Download EPLAN Data Portal 734-438/001-000 URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 734-438/001-000 CAE data PCB Design Symbol and Footprint 734-438/001-000 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/8 Data sheet | Item number: 734-438/001-000 www.wago.com/734-438/001-000 Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Environmental Product Compliance Compliance Search Environmental Product Compliance 734-438/001-000 URL Download THT double-deck male header; 1.0 x 1.0 mm solder pin; angled; 100% protected against mismating; Pin spacing 3.81 mm; 16-pole; orange Installation Notes Coding Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/8 Data sheet | Item number: 734-438/001-000 www.wago.com/734-438/001-000 Coding a THT double-deck male header – lower level. Coding a THT double-deck male header. Product family MCS MINI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/8
734-438/001-000 价格&库存
很抱歉,暂时无法提供与“734-438/001-000”相匹配的价格&库存,您可以联系我们找货
  • 1+5180.00917
库存:100
