Data sheet | Item number: 737-616
Triple-deck PCB terminal block; 2.5 mm²; Pin spacing 7.62 mm; 48-pole;
CAGE CLAMP®; 2,50 mm²; orange
www.wago.com/737-616
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/12
(1) Solder pins in line
Dimensions in mm
L = (pole no. – 1) x pin spacing + 5.08 mm + 1 mm
Item description
PCB terminal strips with screwdriver-actuated CAGE CLAMP® connection
High-density, triple-deck design for space-efficient wiring of multiple conductors in confined areas
Custom marking for all termination levels
Hansastr. 27
32423 Minden
13.10.2021 Page 2/12
Data
Notes
Variants:
Other pole numbers
Other colors
Mixed-color PCB connector strips
Direct marking
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Ratings per
IEC/EN 60664-1
Ratings (note)
Between the modules
Nominal voltage (III/3)
400 V
Rated surge voltage (III/3)
6 kV
Rated voltage (III/2)
630 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
21 A
Ratings per
IEC/EN 60664-1
Ratings (note) 2
Between the decks
Rated voltage (III/3) 2
320 V
Rated surge voltage (III/3) 2
4 kV
Rated voltage (III/2) 2
320 V
Rated surge voltage (III/2) 2
4 kV
Rated voltage (II/2) 2
630 V
Rated surge voltage (II/2) 2
4 kV
Rated current 2
21 A
Hansastr. 27
32423 Minden
13.10.2021 Page 3/12
Rated current 2
21 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Connection data
Total number of connection points
48
Total number of potentials
48
Number of connection types
1
Number of levels
3
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 2.5 mm²
Note (conductor cross-section)
12 AWG: THHN, THWN
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Conductor connection direction to PCB
45 °
Pole No.
48
Physical data
Pin spacing
7.62 mm / 0.3 inch
Width
120.3 mm / 4.736 inch
Height
44 mm / 1.732 inch
Height from the surface
40 mm / 1.575 inch
Depth
31 mm / 1.22 inch
Solder pin length
4 mm
Solder pin dimensions
0.7 x 0.7 mm
Drilled hole diameter with tolerance
1.3 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
within the terminal block (in-line)
Number of solder pins per potential
1
Material data
Color
orange
Material group
I
Hansastr. 27
32423 Minden
13.10.2021 Page 4/12
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
1.238 MJ
Weight
75.6 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
8 Stück
Packaging type
box
Country of origin
PL
GTIN
4045454022488
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7150
CCA
EN 60947-7-4
2169331.28
CSA
C22.2 No. 158
70049157
Ship Approvals
Certificate
Logo
Approval
Hansastr. 27
32423 Minden
name
13.10.2021 Page 5/12
Logo
Approval
name
ABS
American Bureau of Shipping
19HG1869876PDA
BV
Bureau Veritas S.A.
IEC 60998
11915/D0
BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172
Optional accessories
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Hansastr. 27
32423 Minden
13.10.2021 Page 6/12
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
www.wago.com/216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
Hansastr. 27
32423 Minden
www.wago.com/216-221
13.10.2021 Page 7/12
Item no.: 216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Marking accessories
Marking strip
Item no.: 210-332/762-020
Marking strips; as a DIN A4 sheet; MARKED; 1-20 (80x); Height of marker strip: 3 mm; Strip length 182
mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-332
/762-020
Tool
Operating tool
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
Hansastr. 27
32423 Minden
www.wago.com/210-720
13.10.2021 Page 8/12
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
EPLAN Data Portal 737-616
URL
Download
ZUKEN Portal 737-616
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 737-616
CAE data
PCB Design
Symbol and Footprint 737-616
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Hansastr. 27
32423 Minden
13.10.2021 Page 9/12
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 737-616
URL
Download
Triple-deck PCB terminal block; 2.5 mm²; Pin spacing 7.62 mm; 48-pole; CAGE
Installation Notes
Conductor termination
Inserting a conductor via 3.5 mm
screwdriver.
Screwdriver actuation parallel to conductor
entry
Application
Hansastr. 27
32423 Minden
13.10.2021 Page 10/12
Low space requirements due to high-density
design
Double-deck PCB terminal strip – 736 Series
Possible combination:
Double- (736 Series) and triple-deck PCB
terminal strips (737 Series) upon request
Double- (737 Series) and quadruple-deck
PCB terminal strips (738 Series) upon
request
request
Marking
Testing
Hansastr. 27
32423 Minden
13.10.2021 Page 11/12
Testing via contact area above the
conductors.
Hansastr. 27
32423 Minden
13.10.2021 Page 12/12
很抱歉,暂时无法提供与“737-616”相匹配的价格&库存,您可以联系我们找货
