Data sheet | Item number: 750-354/000-002
Fieldbus Coupler EtherCAT; ID Switch; 100 Mbit/s; Diagnostics
www.wago.com/750-354/000-002
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/6
Item description
The EtherCAT® Fieldbus Coupler connects EtherCAT® to the modular WAGO I/O System.
The fieldbus coupler detects all connected I/O modules and creates a local process image. This process image may include a mixed arrangement of
analog (word-by-word data transfer) and digital (bit-by-bit data transfer) modules.
The upper EtherCAT® interface connects the coupler to the network. The lower RJ-45 socket may connect additional EtherCAT ® devices to the
same line.
EtherCAT® (Ethernet Control Automation Technology) is a real-time ETHERNET solution designed for industrial automation applications and
characterized by high performance, flexible topology and simple configuration. With EtherCAT®, the costly ETHERNET star topology can be replaced
with a simple line or tree structure.
The address selection switch is used to set an Explicit Device ID (EDI), which allows a fixed address to be assigned to an EtherCAT® slave.
Data
Technical data
Communication
EtherCAT
Baud rate
100 Mbit/s
Transmission medium
Shielded twisted pair S/FTP, F/FTP or SF/FTP; 100 Ω; Cat. 6
Transmission performance
Class D per EN 50173
Number of modules per node (max.)
64
Input and output (fieldbus) process image (max.)
1024 Byte/1024 Byte
Supply voltage (system)
24 VDC (-25 … +30 %); via pluggable connector
Power consumption (5 V system supply)
300 mA
Total current (system supply)
700 mA
Input current (typ.) at nominal load (24 V)
250 mA
Power supply efficiency (typ.) at nominal load (24 V)
85 %
Isolation
500 V system/field
Hansastr. 27
32423 Minden
07.10.2021 Page 2/6
Connection data
Connection technology: communication/fieldbus
EtherCAT: 2 x RJ-45
Connection technology: system supply
2 x CAGE CLAMP®
Connection technology: device configuration
1 x Male connector; 4-pole
Connection type (1)
System supply
Solid conductor
0.08 … 1.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Physical data
Width
49.5 mm / 1.949 inch
Height
96.8 mm / 3.811 inch
Depth
71.9 mm / 2.831 inch
Depth from upper edge of DIN-rail
64.7 mm / 2.547 inch
Mechanical data
Mounting type
DIN-35 rail
Material data
Color
light gray
Housing material
Polycarbonate; polyamide 6.6
Fire load
1.375 MJ
Weight
109 g
Conformity marking
CE
Environmental requirements
Surrounding air temperature (operation)
0 … 55 °C
Surrounding air temperature (storage)
-40 … 85 °C
Protection type
IP20
Pollution degree (5)
2 per IEC 61131-2
Operating altitude
0 … 2000 m
Mounting position
horizontal (standing/lying); vertical
Relative humidity (without condensation)
95 %
Vibration resistance
per IEC 60068-2-6
Shock resistance
15g per IEC 60068-2-27
EMC immunity to interference
per EN 61000-6-2
Hansastr. 27
32423 Minden
07.10.2021 Page 3/6
per EN 61000-6-2
EMC emission of interference
per EN 61000-6-3
Exposure to pollutants
Per IEC 60068-2-42 and IEC 60068-2-43
Permissible H2S contaminant concentration at a relative humidity 75
10 ppm
Permissible SO2 contaminant concentration at a relative humidity 75
25 ppm
Commercial data
PU (SPU)
1 Stück
Packaging type
box
Country of origin
DE
GTIN
4055143825719
Customs tariff number
85176200000
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
ATEX
TUEV Nord Cert GmbH
EN 60079
TUEV_14_ATEX_148929_X
CCCEx
CQST/CNEx
CNCA-C23-01
2020312310000213
IECEx
TUEV Nord Cert GmbH
IEC 60079-0
IECEx_TUN_14.0035_X
UL
Underwriters Laboratories Inc. (HAZARDOUS
LOCATIONS)
UL 121201
E198726 Sec.1
UL-Approvals
Logo
Approval
UL
Underwriters Laboratories Inc. (ORDINARY
UL 508
Certificate
name
E175199
Sec.1
LOCATIONS)
Hansastr. 27
32423 Minden
07.10.2021 Page 4/6
LOCATIONS)
Downloads
Documentation
Manual
EtherCAT Fieldbus Coupler, ID Switch
V 1.0.0
pdf
8.2 MB
Download
V 3.0.2
Apr 27, 2021
pdf
6.6 MB
Download
URL
Download
Feb 19, 2019
xml
6.0 kB
Download
Dec 17, 2018
docx
18.0 kB
Download
V 1.0.0
pdf
265.8 kB
Download
V 1.0.0
pdf
1.0 MB
Download
750/753 Series I/O-System ‒ General Product Information
pdf
1.7 MB
Download
Overview on WAGO-I/O-SYSTEM 750 approvals
pdf
780.2 kB
Download
100 Mbit/s; digital und analog signals
System Manual WAGO I/O System 750 / 753
Decentralized Automation Technology
System Manual Series 750/753
Online HTML
Bid Text
750-354/000-002
X81 - Datei
750-354/000-002
docx - Datei
Additional Information
Disposal; Electrical and electronic equipment, Packaging
System Description
Use in Hazardous Environments
Term definition, marking and installation regulations
CAD/CAE-Data
Hansastr. 27
32423 Minden
07.10.2021 Page 5/6
CAD/CAE-Data
CAD data
2D/3D Models 750-354/000-002
URL
Download
URL
Download
zip
216.9 kB
Download
URL
Download
CAE data
ZUKEN Portal 750-354/000-002
Device Files
Device Description File
(750-909) ESI file for EtherCAT 750 Series and 765 Series
23
Jul 9, 2021
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 750-354/000-002
Installation Notes
Product family
WAGO I/O System 750/753
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 6/6
很抱歉,暂时无法提供与“750-354/000-002”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6356.442441+823.38161
- 10+5358.4233910+694.10324
- 国内价格
- 1+3399.50620
- 4+3244.98319
- 8+3103.94165
- 国内价格 香港价格
- 1+4804.038491+622.29100
- 4+4585.776204+594.01840
- 8+4386.182238+568.16400
- 国内价格 香港价格
- 1+4012.429891+519.75000
- 4+3830.046714+496.12500
- 8+3663.551138+474.55800
