750-537/040-000
750-537/040-000
    WAGO(万可电子)
    输出模块 DIN 轨道 24VDC
750-537/040-000 数据手册
Data sheet | Item number: 750-537/040-000 8-channel digital output; 24 VDC; 0.5 A; Diagnostics; Extreme www.wago.com/750-537/040-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 Item description This digital output module transmits control signals from the automation device to the connected actuators. All outputs are short-circuit-protected. The module detects the following errors: overload, short circuit and wire break. Status and diagnostics are displayed via LEDs. This module has eight output channels and eight actuators may be connected to it. Field and system levels are electrically isolated. The device is ideal for operation in extreme environments thanks to: Extended temperature range Greater immunity to impulse voltages and electromagnetic interference Higher vibration and shock resistance Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 Data Technical data Number of digital outputs 8 Total number of channels (module) 8 Signal type Voltage Voltage signal type 24 VDC Actuator connection 8 x (1-wire) Output characteristic high-side switching Output current per channel 0.5 A Output current short-circuit-protected Switching frequency (max.) 1 kHz Load type Resistive, inductive, lamp load Diagnostics Open circuit, overload and short circuit Open-circuit detection 0.1 mA Short-circuit limitation (typ.) PWM 12 A Input data width (internal) (max.) 8 bits Output (internal) data width (max.) 8 bits Supply voltage (system) 5 VDC; via data contacts Power consumption (5 V system supply) 50 mA Supply voltage (field) 24 VDC (-25 … +30 %); via power jumper contacts (power supply via blade contact; transmission via spring contact); Derating must be observed! Power consumption, field supply (module with no external load) 16 mA Dielectric strength 510 VAC/775 VDC; per EN 60870-2-1 Interference-free with safety function Yes Rated surge voltage 1 kV Number of incoming power jumper contacts 2 Number of outgoing power jumper contacts 2 Current carrying capacity (power jumper contacts) 10 A Derating Derating (supply voltage): Surrounding air temperatures under laboratory conditions: (-25 … +30 %); for -40 … +55 °C: 24 V (-25 … +20 %); for +55 … +70 °C: 24 V (-25 … +10 %); Lower limit in all temperature ranges: −27.5 % (including 15 % residual ripple) Connection data Connection technology: inputs/outputs 8 x CAGE CLAMP® Connection type (1) Inputs/Outputs Solid conductor 0.25 … 2.5 mm² / 24 … 14 AWG Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 Connection type (1) Inputs/Outputs Solid conductor 0.25 … 2.5 mm² / 24 … 14 AWG Fine-stranded conductor 0.25 … 2.5 mm² / 24 … 14 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Physical data Width 12 mm / 0.472 inch Height 100 mm / 3.937 inch Depth 67.8 mm / 2.669 inch Depth from upper edge of DIN-rail 60.6 mm / 2.386 inch Mechanical data Mounting type DIN-35 rail Material data Color dark gray Housing material Polycarbonate; polyamide 6.6 Fire load 0.147 MJ Weight 50.2 g Conformity marking CE Environmental requirements Surrounding air temperature (operation) -40 … 70 °C Surrounding air temperature (storage) -40 … 85 °C Protection type IP20 Pollution degree (5) 2 per IEC 61131-2 Operating altitude without temperature derating: 0 … 2000 m; with temperature derating: 2000 … 5000 m (0.5 K/100 m); 5000 m (max.) Mounting position horizontal (standing/lying); vertical Relative humidity (without condensation) 95 % Relative humidity (with condensation) Short-term condensation per Class 3K7/IEC EN 60721-3-3 and EDIN 40046-721-3 (except for wind-driven precipitation, water and ice formation) Vibration resistance per IEC 60068-2-6 (acceleration: 5g), EN 60870-2-2, IEC 60721-3-1, -3, EN 50155; EN 61373 Shock resistance per IEC 60068-2-27 (15g/11 ms/half-sine/1,000 shocks; 25g/6 ms/1, 000 shocks), EN 50155, EN 61373 EMC immunity to interference Per EN 61000-6-1, -2; EN 61131-2; marine applications; EN 50121-32; EN 50121-4, -5; EN 60255-26; EN 60870-2-1; EN 61850-3; IEC 61000-6-5; IEEE 1613; VDEW: 1994 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 EN 60870-2-1; EN 61850-3; IEC 61000-6-5; IEEE 1613; VDEW: 1994 EMC emission of interference per EN 61000-6-3, -4, EN 61131-2, EN 60255-26, marine applications, EN 60870-2-1, EN 61850-3, EN 50121-3-2, EN 501214, -5 Exposure to pollutants Per IEC 60068-2-42 and IEC 60068-2-43 Permissible H2S contaminant concentration at a relative humidity 75 10 ppm % Permissible SO2 contaminant concentration at a relative humidity 75 25 ppm % Commercial data PU (SPU) 1 Stück Packaging type box Country of origin DE GTIN 4055143673266 Customs tariff number 85371098990 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name ATEX TUEV Nord Cert GmbH EN 60079-0 TUEV 17 ATEX 193969X CCCEx CQST/CNEx CNCA-C23-01 2020312310000214 IECEx TUEV Nord Cert GmbH IEC 60079-0 IECEx TUN 16.0046 X UL Underwriters Laboratories Inc. (HAZARDOUS LOCATIONS) UL 121201 E198726 Sec.1 Ship Approvals Logo Approval Additional Approval Text ABS Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate name 18- Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 5/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 ABS American Bureau of Shipping - 18HG1778162PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAA00000Y7 LR Lloyds Register - 17/20073 LR PRS Polski Rejestr Statków - TE/2215 /880590/18 UL-Approvals Logo Approval Additional Approval Text UL Underwriters Laboratories Inc. (ORDINARY LOCATIONS) UL 61010-2-201 Certificate name E175199 Sec10 Optional accessories System housing     System enclosure Item no.: 850-814/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (200x120x200 mm); without flange plate www.wago.com/850-814 /002-000 Item no.: 850-815/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (300x120x200 mm); without flange plate www.wago.com/850-815 /002-000 Item no.: 850-816/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (400x120x200 mm); without flange plate www.wago.com/850-816 /002-000 Item no.: 850-817/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (600x120x200 mm); without flange plate www.wago.com/850-817 /002-000 Item no.: 850-825 IP65 enclosure; Aluminium (RAL 7032); WxHxD (160x100x160 mm); 9 x M12, 4 x M20 www.wago.com/850-825 Item no.: 850-826 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 6/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 Item no.: 850-826 IP65 enclosure; Aluminium (RAL 7032); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-826 Item no.: 850-827 IP65 enclosure; Aluminium (RAL 7032); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-827 Item no.: 850-827/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-827 /002-000 Item no.: 850-826/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-826 /002-000 Item no.: 850-828/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable grip www.wago.com/850-828 /002-000 Item no.: 850-828 IP65 enclosure; Aluminium (RAL 7032); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable grip www.wago.com/850-828 Item no.: 850-834 IP65 enclosure; Polyester (RAL 7032); WxHxD (164x100x164 mm); 9 x M12, 4 x M20 www.wago.com/850-834 Item no.: 850-835 IP65 enclosure; Polyester (RAL 7032); WxHxD (244x100x164 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-835 Item no.: 850-836 IP65 enclosure; Polyester (RAL 7032); WxHxD (324x100x164 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-836 Shield termination     Shield clamping saddle Item no.: 790-116 Shield clamping saddle; 19 mm wide; diameter of compatible conductor; 7 ... 16 mm www.wago.com/790-116 Item no.: 790-124 Shield clamping saddle; 27 mm wide; diameter of compatible conductor; 6 ... 24 mm www.wago.com/790-124 Item no.: 790-108 Shield clamping saddle; 11 mm wide; diameter of compatible conductor; 3 ... 8 mm www.wago.com/790-108 Item no.: 790-140 Shield clamping saddle; diameter of compatible conductor www.wago.com/790-140 Item no.: 790-216 Shield clamping saddle; 21.8 mm wide; 6 ... 16 mm www.wago.com/790-216 Item no.: 790-220 Shield clamping saddle; 30 mm wide; 6 ... 20 mm www.wago.com/790-220 Item no.: 790-208 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/790-208 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 7/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 Item no.: 790-208 Shield clamping saddle; 12.4 mm wide; 3 ... 8 mm www.wago.com/790-208 Marking accessories     Marker carrier Item no.: 750-103 Group marker carrier www.wago.com/750-103     Marker Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-002 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/248-501 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 8/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023     Group marker carrier Item no.: 750-107 Group marker carrier www.wago.com/750-107 Carrier rail     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silverSubject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-506 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 9/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Downloads Documentation Manual 8-channel, 24VDC, 0.5A /XTR short-circuit protected, high-side switching, diagnostics V 1.1.1 Jun 2, 2020 pdf 3.0 MB Download Feb 12, 2018 doc 33.3 kB Download Feb 19, 2019 xml 7.5 kB Download V 1.0.0 pdf 265.8 kB Download Bid Text 750-537/040-000 doc - Datei 750-537/040-000 X81 - Datei Additional Information Disposal; Electrical and electronic equipment, Packaging Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 10/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 System Description System Manual XTR V 1.3.0 Feb 1, 2021 pdf 6.3 MB Download Overview on WAGO-I/O-SYSTEM 750 approvals pdf 780.2 kB Download 750 XTR Series I/O-System ‒ General Product Information pdf 1.1 MB Download EPLAN Data Portal 750-537/040-000 URL Download ZUKEN Portal 750-537/040-000 URL Download EPLAN Data Portal 750-537/040-000 URL Download URL Download URL Download Basic conditions and recommendations for higher operational safety CAD/CAE-Data CAE data CAD data 2D/3D Models 750-537/040-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 750-537/040-000 8-channel digital output; 24 VDC; 0.5 A; Diagnostics; Extreme Installation Notes Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 11/12 Data sheet | Item number: 750-537/040-000 www.wago.com/750-537/040-000 Product family WAGO I/O System 750 XTR I/O-System 750 XTR: Dort automatisieren, wo jedes andere System an seine Grenzen stößt – und das zuverlässig und wirtschaftlich! XTR – dieses Kürzel im Systemnamen steht für extremen Schutz vor klimatischen Einflüssen, Schwingungen, Erschütterungen und Überspannungen. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 12/12
750-537/040-000 价格&库存
很抱歉,暂时无法提供与“750-537/040-000”相匹配的价格&库存,您可以联系我们找货
