753-604
753-604
    WAGO(万可电子)
    COMMUNICATIONS MODULE 0-24V
753-604 数据手册
Data sheet | Item number: 753-604 Potential Distribution; 8-way 0 V www.wago.com/753-604 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/12 Data sheet | Item number: 753-604 www.wago.com/753-604 Item description The field side connection module provides 0 V potential for the outputs of the 8-channel output module (750-530). This module eliminates the need for additional rail-mount terminal blocks. The 24 V supply and 0 V potential are derived from the internal power jumper contacts of an adjacent upstream I/O module. A connection of the potentials to the downstream I/O modules is made automatically via the power jumper contacts when snapping the I/O modules together. The 0 V power is provided to all eight field side CAGE CLAMP® connections and the 24 V potential passed through without being used by the module. Data Notes Note Pluggable connectors and coding fingers (753 Series) are not included. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/12 Data sheet | Item number: 753-604 www.wago.com/753-604 Technical data Signal type Voltage Voltage signal type 0 VDC Supply voltage (system) 5 VDC; via data contacts Supply voltage (field) 24 VDC (-25 … +30 %); via power jumper contacts (power supply via blade contact; transmission via spring contact) Number of incoming power jumper contacts 2 Number of outgoing power jumper contacts 2 Current carrying capacity (power jumper contacts) 10 A Connection data Connection type (1) Field supply Solid conductor 0.08 … 2.5 mm² / 28 … 14 AWG Fine-stranded conductor 0.08 … 2.5 mm² / 28 … 14 AWG Strip length 9 … 10 mm / 0.35 … 0.39 inch Physical data Width 12 mm / 0.472 inch Height 100 mm / 3.937 inch Depth 69.8 mm / 2.748 inch Depth from upper edge of DIN-rail 62.6 mm / 2.465 inch Mechanical data Mounting type DIN-35 rail Wiring interface Pluggable Material data Color light gray Housing material Polycarbonate; polyamide 6.6 Fire load 0.766 MJ Weight 37.4 g Conformity marking CE Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/12 Data sheet | Item number: 753-604 www.wago.com/753-604 Environmental requirements Surrounding air temperature (operation) 0 … 55 °C Surrounding air temperature (storage) -40 … 85 °C Protection type IP20 Pollution degree (5) 2 per IEC 61131-2 Operating altitude 0 … 2000 m Mounting position horizontal (standing/lying); vertical Relative humidity (without condensation) 95 % Vibration resistance 4g per IEC 60068-2-6 Shock resistance 15g per IEC 60068-2-27 EMC immunity to interference per EN 61000-6-2, marine applications EMC emission of interference per EN 61000-6-4, marine applications Exposure to pollutants Per IEC 60068-2-42 and IEC 60068-2-43 Permissible H2S contaminant concentration at a relative humidity 75 10 ppm % Permissible SO2 contaminant concentration at a relative humidity 75 25 ppm % Commercial data Product Group 15 (Remote I/O) PU (SPU) 1 Stück Packaging type box Country of origin DE GTIN 4050821867678 Customs tariff number 85389091890 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name CCCEx CQST/CNEx CNCA-C23-01 2020312310000215 EAC Brjansker Zertifizierungsstelle TP TC 012/2011 EAC RU C-DE.AM02. B.00163/19 IECEx IEC 60079-0 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com IECEx TUN 09.0001 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/12 Data sheet | Item number: 753-604 www.wago.com/753-604 IECEx TUEV Nord Cert GmbH IEC 60079-0 IECEx TUN 09.0001 X TUEV Nord TUEV Nord Cert GmbH EN 60079-0 TÜV 07 ATEX 554086 X en. UL Underwriters Laboratories Inc. (HAZARDOUS LOCATIONS) UL 121201 E198726 Sec.1 Country specific Approvals Logo Approval Additional Approval Text KC National Radio Research Agency Article 58-2, Clause 3 Certificate name MSIPREM-W43FSC750 Ship Approvals Logo Approval Additional Approval Text Certificate name BV Bureau Veritas S.A. - 30389/B0 BV KR Korean Register of Shipping - KR HMB05880AC001 LR Lloyds Register EMEA - 02/20026 (E6) RINA RINA Germany GmbH - ELE066419XG UL-Approvals Logo Approval Additional Approval Text Certificate name UL UL 508 E175199 UL International Netherlands B.V. (ORDINARY Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Sec.1 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 5/12 Data sheet | Item number: 753-604 www.wago.com/753-604 UL International Netherlands B.V. (ORDINARY LOCATIONS) Sec.1 Required accessories Pluggable connector     Male connector/plug Item no.: 753-110 Plug www.wago.com/753-110 Optional accessories Pluggable connector     Coding Item no.: 753-150 753 Series coding elements www.wago.com/753-150 Shield termination     Shield clamping saddle Item no.: 790-116 Shield clamping saddle; 19 mm wide; diameter of compatible conductor; 7 ... 16 mm www.wago.com/790-116 Item no.: 790-124 Shield clamping saddle; 27 mm wide; diameter of compatible conductor; 6 ... 24 mm www.wago.com/790-124 Item no.: 790-108 Shield clamping saddle; 11 mm wide; diameter of compatible conductor; 3 ... 8 mm www.wago.com/790-108 Item no.: 790-140 Shield clamping saddle; diameter of compatible conductor www.wago.com/790-140 Item no.: 790-216 Shield clamping saddle; 21.8 mm wide; 6 ... 16 mm www.wago.com/790-216 Item no.: 790-220 Shield clamping saddle; 30 mm wide; 6 ... 20 mm www.wago.com/790-220 Item no.: 790-208 Shield clamping saddle; 12.4 mm wide; 3 ... 8 mm www.wago.com/790-208 System housing     System enclosure Item no.: 850-814/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (200x120x200 mm); without flange plate www.wago.com/850-814 /002-000 Item no.: 850-815/002-000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 6/12 Data sheet | Item number: 753-604 www.wago.com/753-604 Item no.: 850-815/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (300x120x200 mm); without flange plate www.wago.com/850-815 /002-000 Item no.: 850-816/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (400x120x200 mm); without flange plate www.wago.com/850-816 /002-000 Item no.: 850-817/002-000 IP65 enclosure; Sheet steel (RAL 7035); WxHxD (600x120x200 mm); without flange plate www.wago.com/850-817 /002-000 Item no.: 850-825 IP65 enclosure; Aluminium (RAL 7032); WxHxD (160x100x160 mm); 9 x M12, 4 x M20 www.wago.com/850-825 Item no.: 850-826 IP65 enclosure; Aluminium (RAL 7032); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-826 Item no.: 850-827 IP65 enclosure; Aluminium (RAL 7032); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-827 Item no.: 850-827/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-827 /002-000 Item no.: 850-826/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-826 /002-000 Item no.: 850-828/002-000 IP65 enclosure; Aluminium (RAL 7035); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable grip www.wago.com/850-828 /002-000 Item no.: 850-828 IP65 enclosure; Aluminium (RAL 7032); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable grip www.wago.com/850-828 Item no.: 850-834 IP65 enclosure; Polyester (RAL 7032); WxHxD (164x100x164 mm); 9 x M12, 4 x M20 www.wago.com/850-834 Item no.: 850-835 IP65 enclosure; Polyester (RAL 7032); WxHxD (244x100x164 mm); 4 x M20, 4 x M16, 14 x M12 cable grip www.wago.com/850-835 Item no.: 850-836 IP65 enclosure; Polyester (RAL 7032); WxHxD (324x100x164 mm); 4 x M20, 8 x M16, 17 x M12 cable grip www.wago.com/850-836 Marking accessories     Marker carrier Item no.: 750-103 Group marker carrier www.wago.com/750-103     Marker Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 7/12 Data sheet | Item number: 753-604 www.wago.com/753-604     Marker Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/248-501 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 8/12 Data sheet | Item number: 753-604 www.wago.com/753-604 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023 Item no.: 750-100 Marker card; as a DIN A4 sheet; plain www.wago.com/750-100     Group marker carrier Item no.: 750-106 Group marker carrier www.wago.com/750-106 Carrier rail     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silverSubject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-508 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 9/12 Data sheet | Item number: 753-604 www.wago.com/753-604 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Supply module     Supply module Item no.: 750-601 Power Supply; 24 VDC; fuse holder www.wago.com/750-601 Item no.: 750-610 Power Supply; 24 VDC; fuse holder; Diagnostics www.wago.com/750-610 Item no.: 750-602 Power Supply; 24 VDC www.wago.com/750-602 Item no.: 750-612 Power Supply; 0 … 230 V AC/DC www.wago.com/750-612 Item no.: 753-612 Power Supply; 0 … 230 V AC/DC www.wago.com/753-612 Item no.: 753-602 Power Supply; 24 VDC www.wago.com/753-602 Downloads Documentation Manual Field-side connection module 0 VDC V 1.1.0 pdf 2.2 MB Download Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 10/12 Data sheet | Item number: 753-604 www.wago.com/753-604 V 3.0.2 Apr 27, 2021 pdf 6.6 MB Download URL Download Oct 6, 2017 doc 27.6 kB Download Feb 19, 2019 xml 4.6 kB Download V 1.0.0 pdf 265.8 kB Download Overview on WAGO-I/O-SYSTEM 750 approvals pdf 780.2 kB Download 750/753 Series I/O-System ‒ General Product Information pdf 1.7 MB Download URL Download EPLAN Data Portal 753-604 URL Download ZUKEN Portal 753-604 URL Download WSCAD Universe 753-604 URL Download System Manual WAGO I/O System 750 / 753 Decentralized Automation Technology System Manual Series 750/753 Online HTML Bid Text 753-604 doc - Datei 753-604 X81 - Datei Additional Information Disposal; Electrical and electronic equipment, Packaging System Description CAD/CAE-Data CAD data 2D/3D Models 753-604 CAE data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 11/12 Data sheet | Item number: 753-604 www.wago.com/753-604 Environmental Product Compliance Compliance Search Environmental Product Compliance 753-604 URL Download Potential Distribution; 8-way 0 V Installation Notes Product family WAGO I/O System 750/753 Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 12/12
753-604 价格&库存
很抱歉,暂时无法提供与“753-604”相匹配的价格&库存,您可以联系我们找货
    • 1+465.60266
    库存:2
    753-604
      库存:20000
