Data sheet | Item number: 753-474
2-channel analog input; 4 … 20 mA; Single-ended; 16 bits
www.wago.com/753-474
Color:
Subject to changes. Please also observe the further product documentation!
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
02.12.2021 Page 1/13
Item description
This analog input module powers field-side signal conditioners and transmits electrically isolated analog signals to the bus system.
The 24 V field supply is derived from the module's power jumper contacts.
The shield directly connects to the DIN-rail.
At approximately 25 mA, overload protection switches the measurement input to a high-resistance state. Once normal operating conditions
resume, the measurement input will automatically switch back.
This module supplies the voltage for 2-wire signal conditioners that have no power supply of their own.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 2/13
Data
Notes
Note
Pluggable connectors and coding fingers (753 Series) are not
included.
Technical data
Number of analog inputs
2
Total number of channels (module)
2
Signal type
Current
Signal type (current)
4 … 20 mADC
Sensor connection
2 x (2-wire, 3-wire)
Input filter frequency (analog)
50 Hz
Input voltage (max.)
24 V
Input voltage (note)
Non-linear, overload protected U = 1.2 V + 160 Ω x I meas
Signal characteristic
Single-ended
Resolution [bit]
15 bits
Input resistance (max.)
220 Ω
Data width
2 x 16-bit data; 2 x 8-bit control/status (optional)
Overvoltage protection
30 V, reverse polarity protected
Noise rejection at sampling frequency
-100 dB
Noise rejection above sampling frequency
-40 dB
Conversion time (typ.)
80 ms
Measurement error (reference temperature)
25 °C
Measurement error – deviation (max.) from the upper-range value
0.1 %
Temperature error (max.) of the upper-range value
0.01 %/K
Supply voltage (system)
5 VDC; via data contacts
Power consumption (5 V system supply)
75 mA
Supply voltage (field)
24 VDC (-25 … +30 %); via power jumper contacts (power supply via
blade contact; transmission via spring contact)
Isolation
500 V system/field
Number of incoming power jumper contacts
2
Number of outgoing power jumper contacts
2
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 3/13
Connection data
Connection technology: inputs/outputs
8 x CAGE CLAMP®
Connection type (1)
Inputs/Outputs
Solid conductor
0.08 … 2.5 mm² / 28 … 14 AWG
Fine-stranded conductor
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Physical data
Width
12 mm / 0.472 inch
Height
100 mm / 3.937 inch
Depth
69.8 mm / 2.748 inch
Depth from upper edge of DIN-rail
62.6 mm / 2.465 inch
Mechanical data
Mounting type
DIN-35 rail
Wiring interface
Pluggable
Material data
Color
light gray
Housing material
Polycarbonate; polyamide 6.6
Fire load
0.863 MJ
Weight
45 g
Conformity marking
CE
Environmental requirements
Surrounding air temperature (operation)
0 … 55 °C
Surrounding air temperature (storage)
-40 … 85 °C
Protection type
IP20
Pollution degree (5)
2 per IEC 61131-2
Operating altitude
0 … 2000 m
Mounting position
horizontal (standing/lying); vertical
Relative humidity (without condensation)
95 %
Vibration resistance
4g per IEC 60068-2-6
Shock resistance
15g per IEC 60068-2-27
EMC immunity to interference
per EN 61000-6-2, marine applications
EMC emission
of interference
Subject
to changes.
Please also observe the further product documentation!per EN 61000-6-4, marine applications
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 4/13
EMC emission of interference
Exposure to pollutants
Per IEC 60068-2-42 and IEC 60068-2-43
Permissible H2S contaminant concentration at a relative humidity 75
10 ppm
Permissible SO2 contaminant concentration at a relative humidity 75
25 ppm
Commercial data
Product Group
15 (Remote I/O)
PU (SPU)
1 Stück
Packaging type
box
Country of origin
DE
GTIN
4045454394523
Customs tariff number
85389099990
Approvals / Certificates
Ex-Approvals
Logo
Approval
Additional Approval Text
Certificate name
ATEX
TUEV Nord Cert GmbH
EN 60079-0
TUEV_14_ATEX_148929_X
(II 3 G Ex ex IIC T4 Gc)
CCCEx
CQST/CNEx
CNCA-C23-01
2020312310000215 (Ex
nA IIC T4 Gc)
EAC
Brjansker Zertifizierungsstelle
TP TC 012/2011
EAC RU C-DE.AM02.B.
00163/19 (2Ex nA IIC T4
Gc X)
IECEx
TUEV Nord Cert GmbH
IEC 60079-0
IECEx_TUN_14.0035_X (Ex
ec IIC T4 Gc)
UL
Underwriters Laboratories Inc. (HAZARDOUS
LOCATIONS)
UL 121201
E198726 Sec.1
Country specific Approvals
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Certificate
02.12.2021 Page 5/13
Logo
Approval
KC
National Radio Research Agency
Article 58-2, Clause 3
Certificate
name
MSIPREM-W43AIM750
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1821926
BV
Bureau Veritas S.A.
13453/DO BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAA0000194
KR
Korean Register of Shipping
KR
HMB05880AC001
LR
Lloyds Register EMEA
02/20026 (E6)
PRS
Polski Rejestr Statków
TE/2236
/880590/19
RINA
RINA Germany GmbH
ELE066419XG
UL-Approvals
Logo
Approval
UL
UL International Netherlands B.V. (ORDINARY
LOCATIONS)
UL 508
Certificate
name
E175199
Sec.1
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 6/13
Required accessories
Pluggable connector
Male connector/plug
Item no.: 753-110
Plug
www.wago.com/753-110
Optional accessories
System housing
System enclosure
Item no.: 850-814/002-000
IP65 enclosure; Sheet steel (RAL 7035); WxHxD (200x120x200 mm); without flange plate
www.wago.com/850-814
/002-000
Item no.: 850-815/002-000
IP65 enclosure; Sheet steel (RAL 7035); WxHxD (300x120x200 mm); without flange plate
www.wago.com/850-815
/002-000
Item no.: 850-816/002-000
IP65 enclosure; Sheet steel (RAL 7035); WxHxD (400x120x200 mm); without flange plate
www.wago.com/850-816
/002-000
Item no.: 850-817/002-000
IP65 enclosure; Sheet steel (RAL 7035); WxHxD (600x120x200 mm); without flange plate
www.wago.com/850-817
/002-000
Item no.: 850-825
IP65 enclosure; Aluminium (RAL 7032); WxHxD (160x100x160 mm); 9 x M12, 4 x M20
www.wago.com/850-825
Item no.: 850-826
IP65 enclosure; Aluminium (RAL 7032); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable
grip
www.wago.com/850-826
Item no.: 850-827
IP65 enclosure; Aluminium (RAL 7032); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable
grip
www.wago.com/850-827
Item no.: 850-827/002-000
IP65 enclosure; Aluminium (RAL 7035); WxHxD (320x100x160 mm); 4 x M20, 8 x M16, 17 x M12 cable
grip
/002-000
Item no.: 850-826/002-000
IP65 enclosure; Aluminium (RAL 7035); WxHxD (240x100x160 mm); 4 x M20, 4 x M16, 14 x M12 cable
grip
/002-000
Item no.: 850-828/002-000
IP65 enclosure; Aluminium (RAL 7035); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable
grip
www.wago.com/850-828
/002-000
Item no.: 850-828
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 7/13
Item no.: 850-828
IP65 enclosure; Aluminium (RAL 7032); WxHxD (480x100x160 mm); 4 x M20, 10 x M16, 35 x M12 cable
grip
Item no.: 850-834
IP65 enclosure; Polyester (RAL 7032); WxHxD (164x100x164 mm); 9 x M12, 4 x M20
www.wago.com/850-834
Item no.: 850-835
IP65 enclosure; Polyester (RAL 7032); WxHxD (244x100x164 mm); 4 x M20, 4 x M16, 14 x M12 cable
grip
www.wago.com/850-835
Item no.: 850-836
IP65 enclosure; Polyester (RAL 7032); WxHxD (324x100x164 mm); 4 x M20, 8 x M16, 17 x M12 cable
grip
www.wago.com/850-836
Shield termination
Shield clamping saddle
Item no.: 790-116
Shield clamping saddle; 19 mm wide; diameter of compatible conductor; 7 ... 16 mm
www.wago.com/790-116
Item no.: 790-124
Shield clamping saddle; 27 mm wide; diameter of compatible conductor; 6 ... 24 mm
www.wago.com/790-124
Item no.: 790-108
Shield clamping saddle; 11 mm wide; diameter of compatible conductor; 3 ... 8 mm
www.wago.com/790-108
Item no.: 790-140
Shield clamping saddle; diameter of compatible conductor
www.wago.com/790-140
Item no.: 790-216
Shield clamping saddle; 21.8 mm wide; 6 ... 16 mm
www.wago.com/790-216
Item no.: 790-220
Shield clamping saddle; 30 mm wide; 6 ... 20 mm
www.wago.com/790-220
Item no.: 790-208
Shield clamping saddle; 12.4 mm wide; 3 ... 8 mm
www.wago.com/790-208
Supply module
Supply module
Item no.: 750-601
Power Supply; 24 VDC; fuse holder
www.wago.com/750-601
Item no.: 750-610
Power Supply; 24 VDC; fuse holder; Diagnostics
www.wago.com/750-610
Item no.: 750-602
www.wago.com/750-602
Item no.: 750-612
Power Supply; 0 … 230 V AC/DC
www.wago.com/750-612
Item no.: 753-612
www.wago.com/753-612
Item no.: 753-602
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 8/13
Item no.: 753-602
www.wago.com/753-602
Carrier rail
Mounting accessories
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715;
silver-colored
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored
www.wago.com/210-508
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-113
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored
www.wago.com/210-118
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112
silver-colored
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115
silver-colored
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Marking accessories
Marker carrier
Item no.: 750-103
Group marker carrier
www.wago.com/750-103
Marker
Item no.: 2009-145/000-006
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
www.wago.com/2009-145
02.12.2021 Page 9/13
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006
Item no.: 2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-145/000-002
yellow
/000-002
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-012
orange
/000-012
Item no.: 2009-145/000-023
green
/000-023
Item no.: 2009-145/000-024
violet
/000-024
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
www.wago.com/248-501
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white
Item no.: 248-501/000-017
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 10/13
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 750-100
Marker card; as a DIN A4 sheet; plain
www.wago.com/750-100
Item no.: 750-106
www.wago.com/750-106
Pluggable connector
Coding
Item no.: 753-150
753 Series coding elements
www.wago.com/753-150
Downloads
Documentation
Manual
System Manual WAGO I/O System 750 / 753
pdf
6.6 MB
Download
Decentralized Automation Technology
V 3.0.3
Nov 17, 2021
2-channel, 4-20mA, single-ended
V 1.0.3
Download
16 bits
pdf
431.4 kB
System Manual Series 750/753
URL
Download
Feb 19, 2019
xml
5.2 kB
Download
Oct 17, 2017
doc
Download
Online HTML
Bid Text
753-474
X81 - Datei
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 11/13
Oct 17, 2017
doc
29.2 kB
Download
750/753 Series I/O-System ‒ General Product Information
pdf
1.7 MB
Download
Overview on WAGO-I/O-SYSTEM 750 approvals
pdf
780.2 kB
Download
pdf
265.8 kB
Download
pdf
572.7 kB
Download
URL
Download
EPLAN Data Portal 753-474
URL
Download
WSCAD Universe 753-474
URL
Download
ZUKEN Portal 753-474
URL
Download
URL
Download
753-474
doc - Datei
System Description
Additional Information
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
CAD/CAE-Data
CAD data
2D/3D Models 753-474
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 753-474
Installation Notes
Product
family
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 12/13
Product family
WAGO I/O System 750/753
Show all products from the family
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
02.12.2021 Page 13/13
很抱歉,暂时无法提供与“753-474”相匹配的价格&库存,您可以联系我们找货
