Data sheet | Item number: 756-1505/060-020
System bus cable for drag chain; M12B socket; straight; M12B plug; straight;
5-pole; Length: 2 m
www.wago.com/756-1505/060-020
i
Picture differs from the item.
Color:
Item description
Short description:
PUR, halogen-free
Suitable for drag chains
Silicon- and CFC-free
High resistance to microbes, hydrolysis, oil, chemicals and UV radiation High chemical resistance
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/3
Data
Technical data
Connection type
M12 socket - M12 plug
Pole No.
5
Cable connection direction to mating direction
0 °
Cable connection direction to mating direction (2)
0 °
Connector interface coding (cable/adapter) 1 1
B-coded
Connector interface coding (cable/adapter) 2 1
B-coded
Cable length
2 m
PLC Manufacturer
WAGO
Operating voltage
60 V
Operating current
4 A
Rated surge voltage
1.5 kV per IEC 61076-2-101
Contact resistance
10 mΩ
Insulation resistance
5000 MΩ
Conductor resistance
≤ 130 Ω/km
Mechanical data
Bending radius
5 x cable diameter (min.)
Bending cycles
5 Mio.
Drag chain suitability
yes
Sheathed cable diameter
6.8 mm
Type code
KS-6Y3GC11Y 4x2xAWG26/19 shielded
Shield
Tinned copper braid, optical coverage approx. 90 %
Conductor design
Bare copper wire (AWG 26/19)
Conductor insulation
FEP; Core Ø: 1.0 mm (max.)
Housing material
TPU/TPU, black (~ RAL 9005)
Contact material
CuZn
Contact plating
CuNi/Au
Material properties of the connections
Hexagon knurled nut: CuZn; Knurled nut surface: nickel-plated;
Sealing ring: FPM (Viton)
Mating cycles (max.)
100
Tightening torque
1 Nm
Weight
10 g
Color
yellow
Environmental
requirements
Hansastr. 27
32423 Minden
13.10.2021 Page 2/3
Environmental requirements
Surrounding air (operating) temperature (dynamic)
0 … +50 °C
Surrounding air (operating) temperature (static)
-30 … +50 °C
Protection type
IP67
Pollution degree (5)
3/2 per IEC 60664-1
Commercial data
PU (SPU)
1 Stück
Packaging type
box
Country of origin
DE
GTIN
4050821130901
Customs tariff number
85444290900
Downloads
Documentation
System Description
I/O-SYSTEM ‒ SPEEDWAY, General Product Information
pdf
1.1 MB
Download
WSCAD Universe 756-1505/060-020
URL
Download
URL
Download
URL
Download
CAD/CAE-Data
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 756-1505/060-020
System bus cable for drag chain; M12B socket; straight; M12B plug; straight; 5-pole;
Length: 2 m
Installation Notes
Hansastr. 27
32423 Minden
13.10.2021 Page 3/3
很抱歉,暂时无法提供与“756-1505/060-020”相匹配的价格&库存,您可以联系我们找货
