Data sheet | Item number: 769-609/004-000
1-conductor male connector; CAGE CLAMP®; 4 mm²; Pin spacing 5 mm; 9pole; Feedthrough flange; 4,00 mm²; gray
www.wago.com/769-609/004-000
i
Picture differs from the item.
Color:
Data
Electrical data
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
32 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
9
Total number of potentials
9
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Nominal cross-section
4 mm²
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/7
4 mm²
Solid conductor
0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Pole No.
9
Wiring direction
Front-entry wiring
Physical data
Pin spacing
5 mm / 0.197 inch
Width
59.7 mm / 2.35 inch
Height from the surface
18.3 mm / 0.72 inch
Depth
40.2 mm / 1.583 inch
Mechanical data
Mounting type
Feedthrough flange
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for conductor
Material data
Color
gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.56 MJ
Weight
27.7 g
Commercial data
Product Group
18 (X-COM-System)
PU (SPU)
25 Stück
Packaging type
box
Country of origin
PL
GTIN
4044918521482
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Hansastr. 27
32423 Minden
Certificate
07.10.2021 Page 2/7
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7626
CCA
EN 61984
2190419.02
CCA
IEC 61984
NL-47799
/A1
CSA
C22.2 No. 158
1101144
KEMA/KEUR
EN 60947
2190419.01
Approval
Certificate
name
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Ship Approvals
Logo
UL-Approvals
Logo
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1977
E45171
UR
UL 1059
E45172
Optional accessories
Insulation stop
Insulation stop
Item no.: 769-470
Hansastr. 27
32423 Minden
07.10.2021 Page 3/7
Item no.: 769-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/769-470
Item no.: 769-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/769-471
Item no.: 769-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray
www.wago.com/769-472
Marking accessories
Marking strip
Item no.: 210-831
Marking strips; on reel; 2.3 mm wide; plain; Self-adhesive; white
www.wago.com/210-831
Item no.: 210-833
Marking strips; on reel; 6 mm wide; plain; Self-adhesive; white
www.wago.com/210-833
Item no.: 210-834
Marking strips; on reel; 5 mm wide; plain; Self-adhesive; white
www.wago.com/210-834
Item no.: 210-832
Marking strips; on reel; 3 mm wide; plain; Self-adhesive; white
www.wago.com/210-832
Item no.: 248-501
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/248-501
Marker
Tool
Operating tool
Item no.: 210-490
Operating tool
www.wago.com/210-490
Item no.: 769-434
Push-button; loose
www.wago.com/769-434
Item no.: 769-435
Coding pin; for coding of female plugs; for carrier terminal blocks / male connectors; orange
www.wago.com/769-435
Item no.: 769-413
Strain relief plate; gray
www.wago.com/769-413
Coding
Coding
Strain relief
Strain relief
Ferrule
Ferruleto changes. Please also observe the further product documentation!
Subject
Hansastr. 27
32423 Minden
07.10.2021 Page 4/7
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Protective warning marker
Cover
Item no.: 280-415
Protective warning marker; for 5 terminal blocks; with high-voltage symbol, black; yellow
www.wago.com/280-415
Downloads
Documentation
Bid Text
769-609/004-000
Oct 4, 2017
doc
25.6 kB
Download
Feb 19, 2019
xml
3.3 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
doc - Datei
769-609/004-000
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
Hansastr. 27
32423 Minden
07.10.2021 Page 5/7
CAD/CAE-Data
CAD data
2D/3D Models 769-609/004-000
URL
Download
EPLAN Data Portal 769-609/004-000
URL
Download
WSCAD Universe 769-609/004-000
URL
Download
ZUKEN Portal 769-609/004-000
URL
Download
URL
Download
URL
Download
URL
Download
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 769-609/004-000
1-conductor male connector; CAGE CLAMP®; 4 mm²; Pin spacing 5 mm; 9-pole;
Installation Notes
Conductor termination
Hansastr. 27
32423 Minden
07.10.2021 Page 6/7
Operating tool
Inserting a conductor via operating tool
(example shows a male connector).
Marking
Labeling a male connector with CAGE
CLAMP® connection via Mini-WSB Quick
Markers.
Product family
X-COM
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 7/7
很抱歉,暂时无法提供与“769-609/004-000”相匹配的价格&库存,您可以联系我们找货
