770-883
770-883
    WAGO(万可电子)
    插件,P=10mm
    接线端子 间距:10.00mm 1x3P 直插
770-883 数据手册
Data sheet | Item number: 770-883 Socket for PCBs; straight; 3-pole; Cod. B; pink www.wago.com/770-883 Color: Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 1/7 Data sheet | Item number: 770-883 www.wago.com/770-883 Item description Protected against mismating and maintenance-free Push-in CAGE CLAMP® spring pressure connection technology allows solid conductors to be simply pushed into a unit. Two wire connections per pole for loops or bridges Additional variable coding is possible. Components can be clearly printed on and color-coded to meet custom requirements. Data Notes Variants: Other pole markings Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/ Electrical data Note on contact resistance approx. 1 mΩ of contact resistance approx. 0.25 mΩ contact transition plug/socket Ratings per IEC/EN Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated current 25 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Ratings per UL Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 2/7 Data sheet | Item number: 770-883 www.wago.com/770-883 Ratings per UL Hinweis für den amerikanischen Markt Some versions may also be used for current interruption in accordance with the UL certificate in select applications with currents below 16 A and voltages up to 600 V. For further information, please contact your local sales office. Rated voltage UL 1977 600 V Rated current UL 1977 23 A Connection data Total number of potentials 3 Number of levels 1 Connection 1 Pole No. 3 Physical data Pin spacing 10 mm / 0.394 inch Width 27 mm / 1.063 inch Height 29.5 mm / 1.161 inch Height from the surface 26 mm / 1.024 inch Depth 14.6 mm / 0.575 inch Solder pin length 3.5 mm Solder pin dimensions 1 x 0.8 mm Drilled hole diameter with tolerance 1.5 (-0.1 … +0.1) mm Mechanical data Application Measurement and regulation technology Coding B Marking 123 Potentialkennzeichnung 123 Mating force of a plug-in connection approx. 20 … 70 N (depending on pole number) Retention force of a plug-in connection Locked: > 80 N Unmating force of a plug-in connection Unlocked: approx. 20 … 70 N (depending on pole number) Number of mating cycles 200, without resistive load Design straight Plug-in connection Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 3/7 Data sheet | Item number: 770-883 www.wago.com/770-883 Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for PCB Mismating protection Yes Note on mismating protection All WINSTA® components are 100% protected against mismating when: a.) plugging different numbers of poles b.) plugging while rotated 180  c.) plugging while laterally staggered d.) plugging one pole Mating direction to the PCB 90 ° Locking lever yes Locking of plug-in connection locking lever Hinweis zur Verriegelung All connectors for mounted installations (snap-in versions for lighting fixtures or devices, all types of PCB and distribution connectors) are factory-equipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for flying leads (plug/socket). PCB contact PCB Contact THT Solder pin arrangement 2 in-line solder pins/pole Number of solder pins per potential 2 Material data Note on material data Information on material data can be found here Color pink Insulation material Polyamide (PA66) Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper or copper alloy (surface-treated) Fire load 0.12 MJ Weight 6.4 g Environmental requirements Processing temperature -5 … +40 °C Continuous operating temperature -35 … +85 °C Note on continuous operating temperature Insulating parts for temperatures ≤ 105 °C Commercial data Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 4/7 Data sheet | Item number: 770-883 www.wago.com/770-883 Commercial data Product Group 20 (WINSTA) PU (SPU) 100 Stück Packaging type box Country of origin PL GTIN 4050821446279 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. IEC 61984 NL-32104 CCA DEKRA Certification B.V. EN 61984 2173495.01 Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1868589PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001Z6 LR Lloyds Register IEC 61984 02/20050 (E6) Ship Approvals Logo Certificate name UL-Approvals Logo Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1977 E45171 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 5/7 Data sheet | Item number: 770-883 www.wago.com/770-883 Counterpart Item no.770-293 Plug; 3-pole; 4,00 mm²; pink www.wago.com/770-293 Item no.771-9993/205-107 pre-assembled connecting cable; Eca; Plug/open-ended; 3-pole; Cod. B; 1 m; 1,00 mm²; pink www.wago.com/771-9993/205-107 Item no.771-9993/005-107 pre-assembled interconnecting cable; Eca; Socket/plug; 3-pole; Cod. B; 1 m; 1,00 mm²; pink www.wago.com/771-9993/005-107 Required accessories Cover     Cover Item no.: 770-201 Lockout cap; 12-pole, separable; 12-pole; for sockets; black www.wago.com/770-201 Item no.: 770-221 Lockout cap; for socket; 12-pole; separable; white www.wago.com/770-221 Downloads Documentation Additional Information pdf 125.0 kB Download URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 770-883 PCB Design Symbol and Footprint 770-883 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 6/7 Data sheet | Item number: 770-883 www.wago.com/770-883 Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 770-883 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 770-883 Socket for PCBs; straight; 3-pole; Cod. B; pink Installation Notes Product family WINSTA® MIDI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 7/7
770-883 价格&库存
很抱歉,暂时无法提供与“770-883”相匹配的价格&库存,您可以联系我们找货
