770-883/081-000
770-883/081-000
    WAGO(万可电子)
    插件,P=10mm
    接线端子 间距:10.00mm 1x3P 直插
770-883/081-000 数据手册
Data sheet | Item number: 770-883/081-000 Socket for PCBs; straight; 3-pole; Cod. B; pink www.wago.com/770-883/081-000 i Picture differs from the item. Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/7 Data sheet | Item number: 770-883/081-000 www.wago.com/770-883/081-000 Item description Female connector/socket WINSTA® MIDI 3-pole WAGO has various connection solutions for any challenge in building installation, for example, the WINSTA® MIDI female connector/socket. Our remarkable number of pluggable PCB connectors with various insertion directions and operating variants offers you the perfect solution for your application at all times. The coding options reduce installation errors, allowing fast, secure wiring of all components. B coding enables the WINSTA® MIDI pcb connectors to be used for application control in automation, robotics, and mechanical engineering. This pcb connector can be employed for a voltage load of up to 25 A. As a result, pcb connector can also be used for high power loads. WINSTA® MIDI with Push-in CAGE CLAMP® spring pressure connection technology is found in can be found in a variety of projects you can use for quick, easy, flexible, and secure installation. Push-in CAGE CLAMP® spring pressure connection technology – pluggable installation instead of laborious screw connections! WINSTA® is the pluggable connection system that is optimally tailored to the strict requirements of electrical installation. It allows error-free installation of cables and components, quickly and reliably. Choose quality and durability – the WINSTA® MIDI pcb connector with protection against mismating from WAGO makes the installation of electrical components noticeably easier. pcb connectors with protection against mismating simple circuits with B coding for use in process automation, such as lighting technology fast, secure installation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/7 Data sheet | Item number: 770-883/081-000 www.wago.com/770-883/081-000 Data Notes Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole markings Electrical data Note on contact resistance approx. 1 mΩ of contact resistance approx. 0.25 mΩ contact transition plug/socket Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated current 25 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Hinweis für den amerikanischen Markt Application note for the U.S. market (USR): Some versions may also be used for current interruption in accordance with the UL certificate in select applications with currents below 16 A and voltages up to 600 V. For further information, please contact your local sales office. Rated voltage UL 1977 600 V Rated current UL 1977 23 A Connection data Total number of potentials 3 Number of levels 1 Pole No. 3 Physical data Pin spacing 10 mm / 0.394 inch Width 27 mm / 1.063 inch Height 29.5 mm / 1.161 inch Height from the surface 26 mm / 1.024 inch Depth 14.6 mm / 0.575 inch Solder pin length 3.5 mm Solder pin dimensions 1 x 0.8 mm Drilled hole diameter with tolerance 1.5 (-0.1 … +0.1) mm Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/7 Data sheet | Item number: 770-883/081-000 www.wago.com/770-883/081-000 Mechanical data Application Measurement and regulation technology Coding B Marking 125 Potentialkennzeichnung 125 Mating force of a plug-in connection approx. 20 … 70 N (depending on pole number) Retention force of a plug-in connection Locked: > 80 N Unmating force of a plug-in connection Unlocked: approx. 20 … 70 N (depending on pole number) Number of mating cycles 200, without resistive load Design straight Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for PCB Mismating protection Yes Note on mismating protection All WINSTA® components are 100% protected against mismating when: a.) plugging different numbers of poles b.) plugging while rotated 180  c.) plugging while laterally staggered d.) plugging one pole Mating direction to the PCB 90 ° Locking lever yes Locking of plug-in connection locking lever Hinweis zur Verriegelung All connectors for mounted installations (snap-in versions for lighting fixtures or devices, all types of PCB and distribution connectors) are factory-equipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for flying leads (plug/socket). PCB contact PCB Contact THT Solder pin arrangement 2 in-line solder pins/pole Number of solder pins per potential 2 Material data Color pink Insulation material Polyamide (PA66) Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/7 Data sheet | Item number: 770-883/081-000 www.wago.com/770-883/081-000 Insulation material Polyamide (PA66) Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper or copper alloy (surface-treated) Fire load 0.12 MJ Weight 6.4 g Environmental requirements Processing temperature -5 … +40 °C Continuous operating temperature -35 … +85 °C Note on continuous operating temperature Insulating parts for temperatures ≤ 105 °C Commercial data PU (SPU) 100 Stück Packaging type box Country of origin PL GTIN 4050821553519 Customs tariff number 85366990990 Approvals / Certificates UL-Approvals Logo Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.770-293/081-000 Plug; 3-pole; 4,00 mm²; pink www.wago.com/770-293/081-000 Required accessories Cover     Cover Item no.: 770-201 Lockout cap; 12-pole, separable; 12-pole; for sockets; black Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/770-201 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/7 Data sheet | Item number: 770-883/081-000 www.wago.com/770-883/081-000 Item no.: 770-201 Lockout cap; 12-pole, separable; 12-pole; for sockets; black www.wago.com/770-201 Item no.: 770-221 Lockout cap; for socket; 12-pole; separable; white www.wago.com/770-221 Downloads CAD/CAE-Data CAD data 2D/3D Models 770-883/081-000 URL Download URL Download PCB Design Symbol and Footprint 770-883/081-000 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/7 Data sheet | Item number: 770-883/081-000 www.wago.com/770-883/081-000 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 770-883/081-000 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 770-883/081-000 Socket for PCBs; straight; 3-pole; Cod. B; pink Installation Notes Product family WINSTA® MIDI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/7
770-883/081-000 价格&库存
很抱歉,暂时无法提供与“770-883/081-000”相匹配的价格&库存,您可以联系我们找货
