770-893/011-000
770-893/011-000
    WAGO(万可电子)
    插件,P=10mm
    接线端子 间距:10.00mm 插件
770-893/011-000 数据手册
Data sheet | Item number: 770-893/011-000 Plug for PCBs; angled; 3-pole; Cod. B; pink www.wago.com/770-893/011-000 Color: Item description Male connector/plug WINSTA® MIDI B coding The WINSTA® MIDI male connector/plug 3-pole offers secure, easy handling to support drive and control technology tasks. Our pluggable PCB Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/7 Data sheet | Item number: 770-893/011-000 www.wago.com/770-893/011-000 The WINSTA® MIDI male connector/plug 3-pole offers secure, easy handling to support drive and control technology tasks. Our pluggable PCB connectors give you a universal pluggable connection system for your devices that meets all the conditions for a stable device connection that is easy to put into operation. For greater protection in electrical installations, the pcb connector is provided with mechanical protection against mismating. Pcb connectors with B coding from the WINSTA® MIDI line are available in grey, light grey, or pink, allowing you to distinguish different circuits, for example for light, pumps or, sun blinds. Customer-specific pole marking is possible, too. This pcb connector is designed for a load of up to 25 A. Therefore, pcb connector can also be used for high power loads. Our WINSTA® MIDI product line guarantees flexibility for the installation of applications. Through its Push-in CAGE CLAMP® spring pressure connection technology, it guarantees error-free, time-saving installation and offers flexibility and customization for meeting various installation requirements. Push-in CAGE CLAMP® spring pressure connection technology – pluggable installation instead of laborious screw connections! The WINSTA® Pluggable Connection System allows pluggable electrical installation. This significantly reduces the need for servicing and lowers costs. Now you can also reduce installation costs without compromising quality and safety: The WINSTA® MIDI pcb connector with protection against mismating eliminates the need for servicing and prevents unnecessary downtime. pcb connectors with protection against mismating for automation controllers with B coding for controllers such as sun blinds and lighting fixtures convenient installation and commissioning Data Notes Variants: Other pole markings Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/ Electrical data Note on contact resistance approx. 1 mΩ of contact resistance approx. 0.25 mΩ contact transition plug/socket Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated current 25 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Hinweis für den amerikanischen Markt Application note for the U.S. market (USR): Some versions may also be used for current interruption in accordance with the UL Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/7 Data sheet | Item number: 770-893/011-000 www.wago.com/770-893/011-000 be used for current interruption in accordance with the UL certificate in select applications with currents below 16 A and voltages up to 600 V. For further information, please contact your local sales office. Rated voltage UL 1977 600 V Rated current UL 1977 23 A Connection data Total number of potentials 3 Number of levels 1 Pole No. 3 Physical data Pin spacing 10 mm / 0.394 inch Width 27 mm / 1.063 inch Height 18.1 mm / 0.713 inch Height from the surface 14.6 mm / 0.575 inch Depth 26 mm / 1.024 inch Solder pin length 3.5 mm Solder pin dimensions 1 x 0.8 mm Drilled hole diameter with tolerance 1.5 (-0.1 … +0.1) mm Mechanical data Application Measurement and regulation technology Coding B Marking 123 Potentialkennzeichnung 123 Mating force of a plug-in connection approx. 20 … 70 N (depending on pole number) Retention force of a plug-in connection Locked: > 80 N Unmating force of a plug-in connection Unlocked: approx. 20 … 70 N (depending on pole number) Number of mating cycles 200, without resistive load Design angled Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection Yes Note on mismating protection Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/7 Data sheet | Item number: 770-893/011-000 www.wago.com/770-893/011-000 Note on mismating protection All WINSTA® components are 100% protected against mismating when: a.) plugging different numbers of poles b.) plugging while rotated 180  c.) plugging while laterally staggered d.) plugging one pole Mating direction to the PCB 0  ° Locking lever yes Locking of plug-in connection locking lever Hinweis zur Verriegelung All connectors for mounted installations (snap-in versions for lighting fixtures or devices, all types of PCB and distribution connectors) are factory-equipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for flying leads (plug/socket). PCB contact PCB Contact THT Solder pin arrangement 2 in-line solder pins/pole Number of solder pins per potential 2 Material data Color pink Insulation material Polyamide (PA66) Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper or copper alloy (surface-treated) Fire load 0.145 MJ Weight 6.6 g Environmental requirements Processing temperature -5 … +40 °C Continuous operating temperature -35 … +85 °C Note on continuous operating temperature Insulating parts for temperatures ≤ 105 °C Commercial data PU (SPU) 100 Stück Packaging type box Country of origin PL GTIN 4050821446361 Customs tariff number 85366990990 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/7 Data sheet | Item number: 770-893/011-000 www.wago.com/770-893/011-000 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. IEC 61984 NL-32104 CCA DEKRA Certification B.V. EN 61984 2173495.01 Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1868589PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001Z6 LR Lloyds Register IEC 61984 02/20050 (E6) Ship Approvals Logo Certificate name UL-Approvals Logo Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.771-9993/005-107 pre-assembled interconnecting cable; Eca; Socket/plug; 3-pole; Cod. B; 1 m; 1,00 mm²; pink www.wago.com/771-9993/005-107 Item no.771-9993/105-107 www.wago.com/771-9993/105-107 pre-assembled connecting cable; Eca; Socket/open-ended; 3-pole; Cod. B; 1 m; 1,00 mm²; pink Item no.770-283 Socket; 3-pole; Cod. B; 4,00 mm²; pink www.wago.com/770-283 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 5/7 Data sheet | Item number: 770-893/011-000 www.wago.com/770-893/011-000 Required accessories Cover     Cover Item no.: 770-360 Lockout cap; for plugs; 5-pole; separable; yellow www.wago.com/770-360 Optional accessories Coding     Coding Item no.: 770-401 Coding pin; for plugs; Plastic; gray www.wago.com/770-401 Downloads CAD/CAE-Data CAD data 2D/3D Models 770-893/011-000 URL Download URL Download PCB Design Symbol and Footprint 770-893/011-000 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 6/7 Data sheet | Item number: 770-893/011-000 www.wago.com/770-893/011-000 PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian CAE data ZUKEN Portal 770-893/011-000 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 770-893/011-000 Plug for PCBs; angled; 3-pole; Cod. B; pink Installation Notes Product family WINSTA® MIDI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 7/7
770-893/011-000 价格&库存
很抱歉,暂时无法提供与“770-893/011-000”相匹配的价格&库存,您可以联系我们找货
