Data sheet | Item number: 770-895/080-000
Plug for PCBs; straight; 5-pole; Cod. B; pink
www.wago.com/770-895/080-000
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/7
Item description
Male connector/plug WINSTA® MIDI B coding
The WINSTA® MIDI male connectors/plugs rated current 25 A are compact but powerful PCB terminal blocks. They offer easy operation and the
greatest flexibility for installation. Our extensive selection of pluggable PCB connectors with various insertion directions and operating variants
offers you the right solution for your application at all times.
The coding options reduce installation errors, allowing fast, secure wiring of all components. The harmonised interface for motor control allows
easy installation and activation of sun protection and shading systems. Solutions like the WINSTA® MIDI pcb connectors with B coding are suitable
for process control, such as for lighting or within data networks. The rated current and voltage are important criteria for selecting a pcb connector:
They tell us about the product's domains of use. This product has a current rating of 25 A – therefore it is also suitable for high power loads. WINSTA
® MIDI with Push-in CAGE CLAMP® spring pressure connection technology is used in a broad range of individual products you can use for quick,
easy and maximally flexible electrical installation.
WINSTA® MIDI solutions for your electrical installation – protected against mismating and maintenance-free
WINSTA® is the pluggable connection system that is ideally tailored to the strict requirements of electrical installation. It offers fast, secure and,
above all, error-free installation of components and cables. Choose durability and quality – the WINSTA® MIDI pcb connector with locking lever from
WAGO makes the installation of electrical components noticeably easier.
protection against mismating eliminates errors
for automation controllers
fast, secure installation
Data
Notes
Variants:
Other pole markings
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Note on contact resistance
approx. 1 mΩ of contact resistance
approx. 0.25 mΩ contact transition plug/socket
Ratings per
IEC/EN 60664-1
Hansastr. 27
32423 Minden
13.10.2021 Page 2/7
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
400 V
Rated surge voltage (III/3)
6 kV
Rated current
25 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Hinweis für den amerikanischen Markt
Application note for the U.S. market (USR): Some versions may also
be used for current interruption in accordance with the UL
certificate in select applications with currents below 16 A and
voltages up to 600 V. For further information, please contact your
local sales office.
Rated voltage UL 1977
600 V
Rated current UL 1977
23 A
Connection data
Total number of potentials
5
Number of levels
1
Pole No.
5
Physical data
Pin spacing
10 mm / 0.394 inch
Width
47 mm / 1.85 inch
Height
29.5 mm / 1.161 inch
Height from the surface
26 mm / 1.024 inch
Depth
14.6 mm / 0.575 inch
Solder pin length
3.5 mm
Solder pin dimensions
1 x 0.8 mm
Drilled hole diameter with tolerance
1.5 (-0.1 … +0.1) mm
Mechanical data
technology
SMI
Application
Measurement and regulation technology
Coding
B
Marking
N ⏚ L I- I+
Potentialkennzeichnung
N ⏚ L I- I+
Mating force of a plug-in connection
approx. 20 … 70 N (depending on pole number)
Retention force of a plug-in connection
Locked: > 80 N
Unmating force of a plug-in connection
Unlocked: approx. 20 … 70 N (depending on pole number)
Number of mating cycles
200, without resistive load
Design
straight
Hansastr. 27
32423 Minden
13.10.2021 Page 3/7
Design
straight
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
Yes
Note on mismating protection
All WINSTA® components are 100% protected against mismating
when:
a.) plugging different numbers of poles
b.) plugging while rotated 180
c.) plugging while laterally staggered
d.) plugging one pole
Mating direction to the PCB
90 °
Locking lever
yes
Locking of plug-in connection
locking lever
Hinweis zur Verriegelung
All connectors for mounted installations (snap-in versions for
lighting fixtures or devices, all types of PCB and distribution
connectors) are factory-equipped with locking levers to ensure
plugs and sockets are securely locked. Additional locking levers are
only required for flying leads (plug/socket).
PCB contact
PCB Contact
THT
Solder pin arrangement
2 in-line solder pins/pole
Number of solder pins per potential
2
Material data
Color
pink
Insulation material
Polyamide (PA66)
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Copper or copper alloy (surface-treated)
Fire load
0.231 MJ
Weight
10.8 g
Environmental requirements
Processing temperature
-5 … +40 °C
Continuous operating temperature
-35 … +85 °C
Note on continuous operating temperature
Insulating parts for temperatures ≤ 105 °C
Hansastr. 27
32423 Minden
13.10.2021 Page 4/7
Commercial data
PU (SPU)
50 Stück
Packaging type
box
Country of origin
PL
GTIN
4050821553939
Customs tariff number
85366990990
Other
technology
SMI
Approvals / Certificates
UL-Approvals
Logo
Approval
Additional Approval Text
Certificate
name
cURus
Underwriters Laboratories Inc.
UL 1977
E45171
Counterpart
Item no.770-285/080-000
Socket; 5-pole; Cod. B; 4,00 mm²; pink
www.wago.com/770-285/080-000
Item no.771-9935/006-107/080-000
www.wago.com/771-9935/006-107
pre-assembled interconnecting cable; Eca; Socket/plug; 5-pole; Cod. B; H05VV-F 5G 1.5 mm²;
/080-000
1 m; 1,50 mm²; pink
Item no.771-9935/106-107/080-000
pre-assembled connecting cable; Eca; Socket/open-ended; 5-pole; Cod. B; H05VV-F 5G 1.5
mm²; 1 m; 1,50 mm²; pink
www.wago.com/771-9935/106-107
/080-000
Required accessories
Cover
Cover
Item no.: 770-360
Lockout cap; for plugs; 5-pole; separable; yellow
www.wago.com/770-360
Optional
accessories
Hansastr. 27
32423 Minden
13.10.2021 Page 5/7
Optional accessories
Coding
Coding
Item no.: 770-401
Coding pin; for plugs; Plastic; gray
www.wago.com/770-401
Downloads
CAD/CAE-Data
CAD data
2D/3D Models 770-895/080-000
URL
Download
URL
Download
PCB Design
Symbol and Footprint 770-895/080-000
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Hansastr. 27
32423 Minden
13.10.2021 Page 6/7
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 770-895/080-000
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 770-895/080-000
Installation Notes
Product family
WINSTA® MIDI
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 7/7
很抱歉,暂时无法提供与“770-895/080-000”相匹配的价格&库存,您可以联系我们找货
