Data sheet | Item number: 804-109
PCB terminal block; push-button; 2.5 mm²; Pin spacing 5 mm; 9-pole; Pushin CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/804-109
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/12
Dimensions in mm
L = (pole no. x pin spacing) + 1.5 mm
Item description
PCB terminal strips with push-buttons and Push-in CAGE CLAMP® connection
Push-in termination of solid and ferruled, fine-stranded conductors
A large conductor entry accommodates conductors with a cross-section up to 12 AWG with an insulation diameter up to 4.2 mm
Terminal strips with spacers to increase pin spacing
Versions available with custom internal commoning (factory assembly), e.g., commoning ground conductor
Hansastr. 27
32423 Minden
13.10.2021 Page 2/12
Data
Notes
Variants:
Other pole numbers
Other colors
Mixed-color PCB connector strips
10 mm pin spacing version with spacers
Direct marking
Versions for Ex i
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
250 V
Rated surge voltage (III/3)
4 kV
Rated voltage (III/2)
320 V
Rated surge voltage (III/2)
4 kV
Nominal voltage (II/2)
630 V
Rated surge voltage (II/2)
4 kV
Rated current
24 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
10 A
Rated voltage UL (Use Group D)
300 V
Rated current UL (Use Group D)
10 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Total number of connection points
9
Total number of potentials
9
Number of connection types
1
Number of levels
1
Connection technology
Hansastr. 27
32423 Minden
13.10.2021 Page 3/12
Push-in CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.25 … 2.5 mm² / 20 … 12 AWG
Fine-stranded conductor
0.25 … 2.5 mm² / 22 … 12 AWG
Fine-stranded conductor; with insulated ferrule
0.25 … 1.5 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 … 2.5 mm²
Strip length
10 … 11 mm / 0.39 … 0.43 inch
Conductor connection direction to PCB
0 °
Pole No.
9
Physical data
Pin spacing
5 mm / 0.197 inch
Width
46.5 mm / 1.831 inch
Height
18.1 mm / 0.713 inch
Height from the surface
14.5 mm / 0.571 inch
Depth
15 mm / 0.591 inch
Solder pin length
3.6 mm
Solder pin dimensions
0.8 x 0.6 mm
Drilled hole diameter with tolerance
1.1 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (staggered)
Number of solder pins per potential
2
Material data
Color
gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.117 MJ
Weight
9.1 g
Environmental
requirements
Hansastr. 27
32423 Minden
13.10.2021 Page 4/12
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
100 (25) Stück
Packaging type
box
Country of origin
CH
GTIN
4044918515153
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947-7-4
NTR NL
7781
CCA
EN 60947-7-4
71110710
ENEC 15
UL International Germany GmbH
EN 60998
ENEC00096
Approval
Certificate
name
UL
UL 1059
E45172
UL
UL 1977
E45171
UL-Approvals
Logo
Hansastr. 27
32423 Minden
13.10.2021 Page 5/12
Optional accessories
Marking accessories
Marking strip
Item no.: 210-332/500-202
www.wago.com/210-332
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182
/500-202
mm; Horizontal marking; Self-adhesive; white
Item no.: 210-332/500-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length
182 mm; Horizontal marking; Self-adhesive; white
/500-206
Item no.: 210-332/500-205
Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182
/500-205
Item no.: 210-332/500-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length
/500-204
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-106
Ferrule; Sleeve for 2.5 mm² / AWG 14; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-106
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Item no.: 216-122
www.wago.com/216-122
Item no.: 216-124
www.wago.com/216-124
Item no.: 216-142
Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92
www.wago.com/216-142
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Ferrule
Ferrule
Item no.: 216-121
Hansastr. 27
32423 Minden
www.wago.com/216-121
13.10.2021 Page 6/12
Item no.: 216-121
Item no.: 216-143
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-143
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-141
Item no.: 216-152
www.wago.com/216-152
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-151
www.wago.com/216-151
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-144
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 1/08.92; silver-colored
www.wago.com/216-144
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-223
www.wago.com/216-223
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-222
www.wago.com/216-222
Item no.: 216-221
www.wago.com/216-221
Item no.: 216-224
www.wago.com/216-224
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Hansastr. 27
32423 Minden
13.10.2021 Page 7/12
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-284
www.wago.com/216-284
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-321
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 216-302
www.wago.com/216-302
Tool
Operating tool
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 804-109
Hansastr. 27
32423 Minden
13.10.2021 Page 8/12
URL
Download
EPLAN Data Portal 804-109
URL
Download
ZUKEN Portal 804-109
URL
Download
URL
Download
CAE data
PCB Design
Symbol and Footprint 804-109
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental
Product Compliance
Hansastr. 27
32423 Minden
13.10.2021 Page 9/12
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 804-109
URL
Download
PCB terminal block; push-button; 2.5 mm²; Pin spacing 5 mm; 9-pole; Push-in CAGE
Installation Notes
Conductor termination
Terminating solid conductors: Simply push in
stripped conductor until it hits the backstop.
Inserting/removing fine-stranded
conductors:
Open the clamping unit via push-button and
insert a stripped conductor until it hits the
backstop.
Application
Hansastr. 27
32423 Minden
13.10.2021 Page 10/12
WAGO's 804 Series Terminal Strips provide
“internal commoning” to meet requirements
than ban routing the ground conductor over
the board. This enables custom terminal
strips to be commoned and marked at the
factory upon request.
Installation
Mixed-color terminal strips are available
upon request.
Installation
Hansastr. 27
32423 Minden
13.10.2021 Page 11/12
Terminal strips with spacer are available
upon request.
Marking
Labeling via self-adhesive marking strips or
factory direct marking.
Testing
Testing via 1 mm Ø test pin.
Touch contact with current bar.
Hansastr. 27
32423 Minden
13.10.2021 Page 12/12
很抱歉,暂时无法提供与“804-109”相匹配的价格&库存,您可以联系我们找货
