750-484/040-000
750-484/040-000
    WAGO(万可电子)
    I/O MODULE 2 ANALOG 0-24V
750-484/040-000 数据手册
Data sheet | Item number: 750-484/040-000 2-channel analog input; 4 … 20 mA HART; Intrinsically safe; Extreme www.wago.com/750-484/040-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 Item description This analog input module connects two field-side signal conditioners equipped with a HART interface that are to be used in hazardous areas of Zone 0+1. The module supplies signal conditioners, reads process values via analog interface, and enables HART communication for configuring and importing dynamic variables. The WAGO I/O System 750 XTR must be installed either in Zone 2 or in a non-hazardous area. The 24 V supply is supplied to the field contacts (HART +) from the power jumper contacts via multipliers. The shield directly connects to the DIN-rail. The measurement input is equipped with current limitation, which limits the current to 25 mA. This module powers 2-wire signal conditioners. Up to 4 HART dynamic variables (PV, SV, TV, QV) per channel can be mapped in the cyclic process image of the coupler or controller (parameterizable). For HART communication with connected intelligent HART field devices, the HART protocol can be mapped in the cyclic process image of the coupler or controller (parameterizable). FDT/DTM device drivers are available for select (programmable) couplers, allowing HART tool routing to the connected HART device. The device is ideal for operation in extreme environments thanks to: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 The device is ideal for operation in extreme environments thanks to: Extended temperature range Greater immunity to impulse voltages and electromagnetic interference Higher vibration and shock resistance Data Notes Note The analog output module must only be operated via 24 VDC Ex i XTR power supply (750-606/040-000)! General information (e.g., installation regulations) on explosion protection is available in the WAGO I/O System 750 XTR manuals! Technical data Number of analog inputs 2 Total number of channels (module) 2 Signal type Current Signal type (current) 4 … 20 mADC Supply voltage (sensor) 16.5 VDC; Transmitter supply UV at 20 mA Sensor connection 2 x (2-wire) Input filter parameterizable Input filter: parametrizable (channel by channel) yes Signal characteristic Single-ended Diagnostics Wire break, measurement range overflow Resolution [bit] 12 bits Power consumption Pmax. 1.60 W (with slaves (20 mA)) Data width 2 x 2-byte data; 2 x 2-byte data + 2n x 4-byte data (n = number of dynamic variables); 2 x 2-byte data + 6-byte mailbox Overvoltage protection 30 V, reverse polarity protected Conversion time (typ.) 10 ms Measurement error (reference temperature) 25 °C Measurement error – deviation (max.) from the upper-range value 0.2 % Temperature error (max.) of the upper-range value 0.01 %/K Intrinsic safety Ex i yes Supply voltage (system) 5 VDC; via data contacts Power consumption (5 V system supply) 25 mA Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 Power consumption (5 V system supply) 25 mA Supply voltage (field) 24 VDC; (Ex i XTR power supply: UO = max. 26.8 V); via power jumper contacts (power supply via blade contact; transmission via spring contact) Power consumption, field supply (module with no external load) 26 mA HART devices per channel One device (single-drop, no multi-drop) HART modems per channel One modem (no multiplex) Power loss Pl 0.62 W (without slaves) Isolation 300 VAC system/field Dielectric strength 510 VAC/775 VDC; per EN 60870-2-1 Rated surge voltage 1 kV; Rated surge voltage between intrinsically safe and nonintrinsically safe circuits: 1.5 kV (EN 60079-11) Number of incoming power jumper contacts 2 Number of outgoing power jumper contacts 2 Current carrying capacity (power jumper contacts) 1  A Ex guideline EN/IEC 60079-0, -7, -11 Safety-relevant data (circuit) Uo = 26.8 V; Io = 90.07 mA; Po = 603.5 mW; Linear characteristic curve Reactances Ex ia IIC Lo = 1.8 mH; Co = 0.092 μF Reactances Ex ia IIB Lo = 16 mH; Co = 0.72 μF Reactances Ex ia IIA Lo = 27 mH; Co = 2.37 μF Reactances Ex ia I Lo = 38 mH; Co = 3.85 µF Reactances (note) Reactances without accounting for the concurrence of L and C Marking ATEX/IECEx: II 3 (1) G Ex ec [ia Ga] IIC T4 Gc; II (1) D [Ex ia Da] IIIC; I (M1) [Ex ia Ma] I Connection data Connection technology: inputs/outputs 16 x CAGE CLAMP® Connection type (1) Inputs/Outputs Solid conductor 0.25 … 2.5 mm² / 24 … 14 AWG Fine-stranded conductor 0.25 … 2.5 mm² / 24 … 14 AWG Strip length 8 … 9 mm / 0.31 … 0.35 inch Physical data Width 24 mm / 0.945 inch Height 100 mm / 3.937 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 Height 100 mm / 3.937 inch Depth 67.8 mm / 2.669 inch Depth from upper edge of DIN-rail 60.6 mm / 2.386 inch Mechanical data Mounting type DIN-35 rail Material data Color blue Housing material Polycarbonate; polyamide 6.6 Fire load 1.248 MJ Weight 92.9 g Conformity marking CE Environmental requirements Surrounding air temperature (operation) -40 … 70 °C Surrounding air temperature (storage) -40 … 85 °C Protection type IP20 Pollution degree (5) 2 per IEC 61131-2 Operating altitude without temperature derating: 0 … 2000 m; with temperature derating: 2000 … 5000 m (0.5 K/100 m); 5000 m (max.) Mounting position horizontal (standing/lying); vertical Relative humidity (without condensation) 95 % Relative humidity (with condensation) Short-term condensation per Class 3K7/IEC EN 60721-3-3 and EDIN 40046-721-3 (except for wind-driven precipitation, water and ice formation) Vibration resistance per IEC 60068-2-6 (acceleration: 5g), EN 60870-2-2, IEC 60721-3-1, -3 Shock resistance per IEC 60068-2-27 (15g/11 ms/half-sine/1,000 shocks; 25g/6 ms/1, 000 shocks), EN 61373 EMC immunity to interference per EN 61000-6-1, -2, EN 61131-2, marine applications, EN 6025526, EN 60870-2-1, EN 61850-3, IEC 61000-6-5, IEEE 1613, VDEW: 1994 EMC emission of interference per EN 61000-6-3, -4, EN 61131-2, EN 60255-26, marine applications, EN 60870-2-1, EN 61850-3 Exposure to pollutants Per IEC 60068-2-42 and IEC 60068-2-43 Permissible H2S contaminant concentration at a relative humidity 75 10 ppm % Permissible SO2 contaminant concentration at a relative humidity 75 25 ppm % Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 % Commercial data PU (SPU) 1 Stück Packaging type box Country of origin DE GTIN 4055143649506 Customs tariff number 85389099990 Approvals / Certificates Ex-Approvals Logo Approval Additional Approval Text Certificate name ATEX TUEV Nord Cert GmbH EN 60079-0 TUEV_17_ATEX_196484X CCCEx CQST/CNEx CNCA-C23-01 2020312310000212 EAC Brjansker Zertifizierungsstelle TP TC 012/2011 EAC RU C-DE.AM02.B. 00163/19 IECEx TUEV Nord Cert GmbH IEC 60079-0 IECEx TUN 17.0005X UL Underwriters Laboratories Inc. (HAZARDOUS LOCATIONS) UL 121201 E198726 Sec.1 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping - 18HG1778162PDA DNV GL - TAA00000Y7 Det Norske Veritas, Germanischer Lloyd Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 Det Norske Veritas, Germanischer Lloyd LR Lloyds Register - 17/20073 LR PRS Polski Rejestr Statków - TE/2215 /880590/18 UL-Approvals Logo Approval Additional Approval Text UL Underwriters Laboratories Inc. (ORDINARY LOCATIONS) UL 61010-2-201 Certificate name E175199 Sec10 Optional accessories Marking accessories     Marker carrier Item no.: 750-103 Group marker carrier www.wago.com/750-103     Marker Item no.: 2009-145/000-006 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006 Item no.: 2009-145 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-007 www.wago.com/2009-145 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red Item no.: 2009-145/000-012 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/2009-145 /000-005 www.wago.com/2009-145 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/248-501 /000-007 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/248-501 /000-012 Item no.: 248-501 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/248-501 /000-017 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/248-501 /000-005 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/248-501 /000-024 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/248-501 /000-023     Group marker carrier Item no.: 750-107 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 Item no.: 750-107 Group marker carrier www.wago.com/750-107 Shield termination     Shield clamping saddle Item no.: 790-116 Shield clamping saddle; 19 mm wide; diameter of compatible conductor; 7 ... 16 mm www.wago.com/790-116 Item no.: 790-124 Shield clamping saddle; 27 mm wide; diameter of compatible conductor; 6 ... 24 mm www.wago.com/790-124 Item no.: 790-108 Shield clamping saddle; 11 mm wide; diameter of compatible conductor; 3 ... 8 mm www.wago.com/790-108 Item no.: 790-140 Shield clamping saddle; diameter of compatible conductor www.wago.com/790-140 Item no.: 790-216 Shield clamping saddle; 21.8 mm wide; 6 ... 16 mm www.wago.com/790-216 Item no.: 790-220 Shield clamping saddle; 30 mm wide; 6 ... 20 mm www.wago.com/790-220 Item no.: 790-208 Shield clamping saddle; 12.4 mm wide; 3 ... 8 mm www.wago.com/790-208 Carrier rail     Mounting accessories Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715; silver-colored www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715; silvercolored www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715; silver-colored www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715; silvercolored www.wago.com/210-508 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-113 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; silver-colored www.wago.com/210-118 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm; www.wago.com/210-112 silver-colored Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm; www.wago.com/210-115 silver-colored Item no.: 210-196 www.wago.com/210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored Power supplies     Supply module Item no.: 750-606/040-000 Power Supply; 24 VDC; Diagnostics; Intrinsically safe; Extreme www.wago.com/750-606 /040-000 Downloads Documentation Data sheet 750-484/040-000, 2AI 4-20mA HART Ex i XTR pdf 216.9 kB Download V 1.1.0 Jun 8, 2020 pdf 4.8 MB Download Sep 13, 2018 doc 37.9 kB Download Feb 19, 2019 xml 10.5 kB Download V 1.0.0 pdf 265.8 kB Download Manual 2-channel, 4-20mA, HART, Ex i, single ended /XTR Bid Text 750-484/040-000 doc - Datei 750-484/040-000 X81 - Datei Additional Information Disposal; Electrical and electronic equipment, Packaging Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 10/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 System Description Overview on WAGO-I/O-SYSTEM 750 approvals pdf 780.2 kB Download Intrinsically Safe XTR Modules ‒ General Product Information pdf 401.8 kB Download V 1.3.0 Feb 1, 2021 pdf 6.3 MB Download 1.0.0 Mar 22, 2019 pdf 5.3 MB Download 1.0.0 Mar 22, 2019 pdf 3.9 MB Download 1.0.0 Mar 22, 2019 pdf 2.9 MB Download System Manual XTR Basic conditions and recommendations for higher operational safety Application Notes Application Note CoDeSys 2.3 HART Tool Routing via PROFIBUS with 750-833 and 750-333 (a116140) This application note describes how to set up asset management systems, which facilitate simple, efficient configuration of HART field devices. Using the Cerabar PMC51 (Endress+Hauser) as an example, connecting any HART sensor to a WAGO PROFIBUS controller and a WAGO PROFIBUS Coupler is explained. The cyclic PROFIBUS Master (750-8208) realizes the data exchange. As an acyclic master, a TH LINK PROFIBUS provides access for the plant asset management applications WAGOframe, PACTware and FieldCare. HART Tool Routing via ETHERNET with 750-820x/750-88x and CODESYS 2.3 (a116120) This application note describes how to set up asset management systems, which facilitate simple, efficient configuration of HART field devices. With the Cerabar PMC51 (Endress+Hauser) as an example, a connection is established from any HART sensor to a WAGO PROFIBUS Controller and a WAGO ETHERNET Fieldbus Coupler. The configuration is made with the asset management software WAGOframe, PACTware und FieldCare. Application Note e!COCKPIT HART Tool Routing via ETHERNET with 750-820x and e!RUNTIME (a116130) This application note describes how to set up asset management systems, which facilitate simple, efficient configuration of HART field devices. With the Cerabar PMC51 (Endress+Hauser) as an example, a connection is established from any HART sensor to a WAGO PROFIBUS Controller and a WAGO ETHERNET fieldbus coupler. The configuration is made with the asset management software WAGOframe, PACTware und FieldCare. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 11/12 Data sheet | Item number: 750-484/040-000 www.wago.com/750-484/040-000 CAD/CAE-Data CAD data 2D/3D Models 750-484/040-000 URL Download EPLAN Data Portal 750-484/040-000 URL Download ZUKEN Portal 750-484/040-000 URL Download EPLAN Data Portal 750-484/040-000 URL Download CAE data Installation Notes Product family WAGO I/O System 750 XTR I/O-System 750 XTR: Dort automatisieren, wo jedes andere System an seine Grenzen stößt – und das zuverlässig und wirtschaftlich! XTR – dieses Kürzel im Systemnamen steht für extremen Schutz vor klimatischen Einflüssen, Schwingungen, Erschütterungen und Überspannungen. Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 12/12
750-484/040-000 价格&库存
很抱歉,暂时无法提供与“750-484/040-000”相匹配的价格&库存,您可以联系我们找货
    库存:100
