806-207
806-207
    WAGO(万可电子)
    插件,P=5mm
    接线端子 间距:5.00mm 每排针脚数:7 排数:单排
806-207 数据手册
Data sheet | Item number: 806-207 2-conductor female connector; 1.5 mm²; Pin spacing 5 mm; 7-pole; 1,50 mm²; gray www.wago.com/806-207 i Picture differs from the item. Color: Dimensions in mm L = (pole no. x pin spacing) + 1.5 mm Item description 2-conductor female connector with Push-in CAGE CLAMP® connection and screwdriver-actuation Push-in termination of solid and ferruled conductors Double entries for power supply and potential distribution Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/9 Data sheet | Item number: 806-207 www.wago.com/806-207 Double entries for power supply and potential distribution Quick and easy PCB replacement, without disrupting looped-through potentials Data Notes Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole numbers Other colors Mixed-color PCB connector strips Direct marking Electrical data Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated voltage (III/2) 320 V Rated surge voltage (III/2) 4 kV Nominal voltage (II/2) 630 V Rated surge voltage (II/2) 4 kV Rated current 10 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group B) 300 V Rated current UL (Use Group B) 10 A Rated voltage UL (Use Group D) 300 V Rated current UL (Use Group D) 10 A Approvals per CSA Rated voltage CSA (Use Group B) 300 V Rated current CSA (Use Group B) 10 A Connection data Total number of connection points 14 Total number of potentials 7 Number of connection types 1 Number of levels 1 Connection technology Push-in CAGE CLAMP® Actuation type Operating tool Solid conductor 0.2 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor 0.2 … 1.5 mm² / 24 … 16 AWG Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/9 Data sheet | Item number: 806-207 www.wago.com/806-207 Fine-stranded conductor 0.2 … 1.5 mm² / 24 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 1 mm² Fine-stranded conductor; with uninsulated ferrule 0.25 … 1 mm² Strip length 9 … 10 mm / 0.35 … 0.39 inch Conductor connection direction to PCB 45 ° Pole No. 7 Physical data Pin spacing 5 mm / 0.197 inch Width 36.5 mm / 1.437 inch Height 23.3 mm / 0.917 inch Depth 19.8 mm / 0.78 inch Solder pin diameter 1 mm Plug-in connection Contact type (pluggable connector) Female connector/socket Connector (connection type) for PCB Mating direction to the PCB 90 ° Material data Color gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper alloy Contact plating tin-plated Fire load 0.18 MJ Weight 9  g Environmental requirements Limit temperature range -60 … +105 °C Commercial data Product Group 4 (Printed Circuit) PU (SPU) 220 Stück Packaging type box Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/9 Data sheet | Item number: 806-207 www.wago.com/806-207 Packaging type box Country of origin PL GTIN 4045454077136 Customs tariff number 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947-7-4 71112254 CCA DEKRA Certification B.V. EN 60947-7-4 NTR NL7808 CSA DEKRA Certification B.V. C22.2 1132097 Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Required accessories Male connector     Solder pin Item no.: 806-907 THT male header; straight; Pin spacing 5 mm; 7-pole; black www.wago.com/806-907 Optional accessories Tool     Operating tool Item no.: 210-657 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/9 Data sheet | Item number: 806-207 www.wago.com/806-207 Item no.: 210-657 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured www.wago.com/210-657 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured www.wago.com/210-720 Item no.: 216-101 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-101 Item no.: 216-102 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-102 Item no.: 216-103 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated www.wago.com/216-103 Item no.: 216-123 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored www.wago.com/216-123 Item no.: 216-122 Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored www.wago.com/216-122 Item no.: 216-142 Ferrule; Sleeve for 0.75 mm² / 18 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-142 Item no.: 216-132 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-132 Item no.: 216-121 Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored www.wago.com/216-121 Item no.: 216-143 Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-143 Item no.: 216-131 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored www.wago.com/216-131 Item no.: 216-141 Ferrule; Sleeve for 0.5 mm² / 20 AWG; uninsulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 1/08.92 www.wago.com/216-141 Item no.: 216-152 Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-152 Item no.: 216-203 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-203 Item no.: 216-202 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-202 Item no.: 216-151 Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated www.wago.com/216-151 Ferrule     Ferrule Item no.: 216-201 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/216-201 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/9 Data sheet | Item number: 806-207 www.wago.com/806-207 Item no.: 216-201 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-201 Item no.: 216-223 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red www.wago.com/216-223 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-222 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray www.wago.com/216-222 Item no.: 216-221 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white www.wago.com/216-221 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-263 acc. to DIN 46228, Part 4/09.90; red Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-301 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-301 Item no.: 216-321 Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow www.wago.com/216-321 Item no.: 216-322 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-322 Item no.: 216-302 Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green www.wago.com/216-302 Marking accessories     Marking strip Item no.: 210-332/500-202 www.wago.com/210-332 Marking strips; as a DIN A4 sheet; MARKED; 1-16 (160x); Height of marker strip: 3 mm; Strip length 182 /500-202 mm; Horizontal marking; Self-adhesive; white Item no.: 210-332/500-206 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/210-332 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/9 Data sheet | Item number: 806-207 www.wago.com/806-207 Item no.: 210-332/500-206 Marking strips; as a DIN A4 sheet; MARKED; 33-48 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /500-206 Item no.: 210-332/500-205 Marking strips; as a DIN A4 sheet; MARKED; 1-32 (80x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /500-205 Item no.: 210-332/500-204 Marking strips; as a DIN A4 sheet; MARKED; 17-32 (160x); Height of marker strip: 3 mm; Strip length 182 mm; Horizontal marking; Self-adhesive; white www.wago.com/210-332 /500-204 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download URL Download EPLAN Data Portal 806-207 URL Download ZUKEN Portal 806-207 URL Download URL Download CAD/CAE-Data CAD data 2D/3D Models 806-207 CAE data PCB Design Symbol and Footprint 806-207 CAx data for your PCB design, consisting of "schematic symbols and PCB footprints", allow easy integration of the WAGO component into your development environment. Supported formats: Accel EDA 14 & 15 Altium 6 to current version Cadence Allegro DesignSpark Eagle Libraries KiCad Mentor Graphics BoardStation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/9 Data sheet | Item number: 806-207 www.wago.com/806-207 Mentor Graphics BoardStation Mentor Graphics Design Architect Mentor Graphics Design Expedition 99 and 2000 OrCAD 9.X PCB and Capture PADS PowerPCB 3, 3.5, 4.X, and 5.X PADS PowerPCB and PowerLogic 3.0 PCAD 2000, 2001, 2002, 2004, and 2006 Pulsonix 8.5 or newer STL 3D STEP TARGET 3001! View Logic ViewDraw Quadcept Zuken CadStar 3 and 4 Zuken CR-5000 and CR-8000 PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian Environmental Product Compliance Compliance Search Environmental Product Compliance 806-207 URL Download 2-conductor female connector; 1.5 mm²; Pin spacing 5 mm; 7-pole; 1,50 mm²; gray Installation Notes Conductor termination Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/9 Data sheet | Item number: 806-207 www.wago.com/806-207 Inserting solid conductors via push-in termination. Conductor termination directly on the PCB or wiring prior to mounting on PCB Inserting/removing fine-stranded conductors: Open the clamping unit using a screwdriver and insert a stripped conductor until it hits the backstop. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/9
806-207 价格&库存
很抱歉,暂时无法提供与“806-207”相匹配的价格&库存,您可以联系我们找货
