831-3607/108-000
831-3607/108-000
    WAGO(万可电子)
    插件,P=7.62mm
    接线端子 间距:7.62mm 1x7P 直插
831-3607/108-000 数据手册
Data sheet | Item number: 831-3607/108-000 THT male header; 1.0 x 1.2 mm solder pin; straight; 100% protected against mismating; Threaded flange; Pin spacing 7.62 mm; 7-pole; light gray www.wago.com/831-3607/108-000 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/6 Data sheet | Item number: 831-3607/108-000 www.wago.com/831-3607/108-000 Dimensions in mm L = pole no. x pin spacing +2.9 mm L1 = L + 6.5 mm Item description Male headers may be mounted horizontally or vertically via straight or angled solder pins Three solder pins per pole provide high electrical and mechanical stability 100 % protected against mismating Coding via coding fingers Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/6 Data sheet | Item number: 831-3607/108-000 www.wago.com/831-3607/108-000 Data Notes Safety information 1 The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capacity in accordance with DIN EN 61984. When used as intended, these connectors must not be connected /disconnected when live or under load. The circuit design should ensure header pins, which can be touched, are not live when unmated. Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole numbers Protection against PCB mounting errors Electrical data Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 500 V Rated surge voltage (III/3) 6 kV Rated voltage (III/2) 630 V Rated surge voltage (III/2) 6 kV Nominal voltage (II/2) 1000 V Rated surge voltage (II/2) 6 kV Rated current 41 A Legend (ratings) (III / 2) ≙ Overvoltage category III / Pollution degree 2 Approvals per UL 1059 Rated voltage UL (Use Group C) 300 V Rated current UL (Use Group C) 42 A Rated voltage UL (Use Group D) 600 V Rated current UL (Use Group D) 5  A Approvals per CSA Rated voltage CSA (Use Group C) 300 V Rated current CSA (Use Group C) 41 A Rated voltage CSA (Use Group D) 600 V Rated current CSA (Use Group D) 5  A Connection data Total number of potentials 7 Number of connection types 1 Number of levels 1 Pole No. 7 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/6 Data sheet | Item number: 831-3607/108-000 www.wago.com/831-3607/108-000 Pole No. 7 Physical data Pin spacing 7.62 mm / 0.3 inch Width 68.9 mm / 2.714 inch Height 33 mm / 1.299 inch Height from the surface 29 mm / 1.142 inch Depth 14.8 mm / 0.583 inch Solder pin length 4 mm Solder pin dimensions 1 x 1.2 mm Drilled hole diameter with tolerance 1.7 (+0.1) mm Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for PCB Mismating protection Yes Mating direction to the PCB 90 ° Locking of plug-in connection Threaded flange PCB contact PCB Contact THT Solder pin arrangement over the entire male connector (in-line) Number of solder pins per potential 3 Material data Color light gray Material group I Insulation material Polyamide (PA66) Flammability class per UL94 V0 Contact material Electrolytic copper (ECu) Contact plating tin-plated Weight 22.4 g Environmental requirements Limit temperature range -60 … +105 °C Commercial data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/6 Data sheet | Item number: 831-3607/108-000 www.wago.com/831-3607/108-000 Commercial data PU (SPU) 12 Stück Country of origin PL GTIN 4055144037531 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CB DEKRA Certification B.V. IEC 61984 NL-61360 /M1 KEMA/KEUR DEKRA Certification B.V. EN 61984 71116057 Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Counterpart Item no.831-3107/107-000 1-conductor female connector; Push-in CAGE CLAMP®; 10 mm²; Pin spacing 7.62 mm; 7-pole; 100% protected against mismating; Screw flange; 10,00 mm²; light gray www.wago.com/8313107/107-000 Downloads Documentation Additional Information Technical explanations Apr 3, 2019 pdf 2.0 MB Download Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/6 Data sheet | Item number: 831-3607/108-000 www.wago.com/831-3607/108-000 CAD/CAE-Data CAD data 2D/3D Models 831-3607/108-000 URL Download URL Download URL Download CAE data ZUKEN Portal 831-3607/108-000 Environmental Product Compliance Compliance Search Environmental Product Compliance 831-3607/108-000 THT male header; 1.0 x 1.2 mm solder pin; straight; 100% protected against mismating; Threaded flange; Pin spacing 7.62 mm; 7-pole; light gray Installation Notes Coding Break or cut off coding pin from female connector. Insert coding pin into male header (break first) until it engages. Coding a THT male header by inserting a coding pin. Product family MCS MAXI 6 Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/6
831-3607/108-000 价格&库存
很抱歉,暂时无法提供与“831-3607/108-000”相匹配的价格&库存,您可以联系我们找货
