Data sheet | Item number: 831-3628
THT male header; 1.0 x 1.2 mm solder pin; angled; 100% protected against
mismating; Pin spacing 7.62 mm; 8-pole; light gray
www.wago.com/831-3628
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/8
Dimensions in mm
L = (pole no. – 1) x pin spacing + 10.5 mm
Item description
Male headers may be mounted horizontally or vertically via straight or angled solder pins
Three solder pins per pole provide high electrical and mechanical stability
100 % protected against mismating
Coding via coding fingers
Hansastr. 27
32423 Minden
07.10.2021 Page 2/8
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Protection against PCB mounting errors
Electrical data
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated voltage (III/2)
630 V
Rated surge voltage (III/2)
6 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
6 kV
Rated current
41 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per
UL 1059
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
42 A
Rated voltage UL (Use Group D)
600 V
Rated current UL (Use Group D)
5 A
Approvals per
CSA
Rated voltage CSA (Use Group C)
300 V
Rated current CSA (Use Group C)
41 A
Rated voltage CSA (Use Group D)
600 V
Rated current CSA (Use Group D)
5 A
Connection data
Total number of potentials
8
Number of connection types
1
Number of levels
1
Pole No.
8
Hansastr. 27
32423 Minden
07.10.2021 Page 3/8
Pole No.
8
Physical data
Pin spacing
7.62 mm / 0.3 inch
Width
63.84 mm / 2.513 inch
Height
18.8 mm / 0.74 inch
Height from the surface
14.8 mm / 0.583 inch
Depth
29 mm / 1.142 inch
Solder pin length
4 mm
Solder pin dimensions
1 x 1.2 mm
Drilled hole diameter with tolerance
1.7 (+0.1) mm
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
Yes
Mating direction to the PCB
0 °
Locking of plug-in connection
Without
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire male connector (in-line)
Number of solder pins per potential
3
Material data
Color
light gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Weight
20.4 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial
data
Hansastr. 27
32423 Minden
07.10.2021 Page 4/8
Commercial data
Product Group
3 (Multi Conn. System)
PU (SPU)
12 Stück
Packaging type
box
Country of origin
PL
GTIN
4055144069037
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CB
DEKRA Certification B.V.
IEC 61984
NL-61360
/M1
CSA
C22.2
1466354
KEMA/KEUR
EN 61984
71116057
Approval
LR
Lloyds Register
IEC 61984
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172
Ship Approvals
Logo
Certificate
name
96/20035
(E5)
UL-Approvals
Logo
Hansastr. 27
32423 Minden
07.10.2021 Page 5/8
Counterpart
Item no.831-3108
1-conductor female connector; Push-in CAGE CLAMP®; 10 mm²; Pin spacing 7.62 mm; 8-pole; 100%
protected against mismating; 10,00 mm²; light gray
www.wago.com/8313108
Item no.831-3108/037-000
protected against mismating; Lateral locking levers; 10,00 mm²; light gray
www.wago.com/8313108/037-000
Item no.831-3108/000-9037
protected against mismating; direct marking; 10,00 mm²; light gray
www.wago.com/8313108/000-9037
Item no.831-3108/136-000
protected against mismating; Gripping plate; 10,00 mm²; light gray
www.wago.com/8313108/136-000
Item no.831-3108/037-9037
protected against mismating; Lateral locking levers; direct marking; 10,00 mm²; light gray
www.wago.com/8313108/037-9037
Item no.831-1108
1-conductor female connector; lever; Push-in CAGE CLAMP®; 10 mm²; Pin spacing 7.62 mm; 8-pole; 100%
www.wago.com/8311108
Item no.831-1108/037-000
www.wago.com/8311108/037-000
Item no.831-1108/038-000
www.wago.com/8311108/038-000
Item no.831-1108/322-000
protected against mismating; Centered locking levers; 10,00 mm²; light gray
www.wago.com/8311108/322-000
Optional accessories
Coding
Coding
Item no.: 831-500
Hansastr. 27
32423 Minden
www.wago.com/831-500
07.10.2021 Page 6/8
Item no.: 831-500
Coding pin carrier with six coding pins; orange
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
EPLAN Data Portal 831-3628
URL
Download
ZUKEN Portal 831-3628
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 831-3628
CAE data
PCB Design
Symbol and Footprint 831-3628
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
Hansastr. 27
32423 Minden
07.10.2021 Page 7/8
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 831-3628
URL
Download
Installation Notes
Coding
Break or cut off coding pin from female
connector.
Insert coding pin into male header (break
first) until it engages.
Coding a THT male header by inserting a
coding pin.
Product family
MCS MAXI 6
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 8/8
很抱歉,暂时无法提供与“831-3628”相匹配的价格&库存,您可以联系我们找货
