Data sheet | Item number: 832-3645
THT male header; 1.2 x 1.2 mm solder pin; straight; 100% protected against
mismating; Silver-plated contacts; Pin spacing 10.16 mm; 5-pole; light gray
www.wago.com/832-3645
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
13.10.2021 Page 1/9
Dimensions in mm
L = (pole no. x pin spacing) + 1.3 mm
Hansastr. 27
32423 Minden
13.10.2021 Page 2/9
Dimensions in mm
Item description
Male header may be mounted horizontally or vertically via straight or angled solder pins
Three solder pins per pole provide high electrical and mechanical stability
Mating face (IP2XB) with higher protection against accidental contact
100% protected against mismating
Coding via coding fingers
Hansastr. 27
32423 Minden
13.10.2021 Page 3/9
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Variants:
Other pole numbers
Protection against PCB mounting errors
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
800 V
Rated surge voltage (III/3)
8 kV
Rated voltage (III/2)
1000 V
Rated surge voltage (III/2)
8 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
8 kV
Rated current
76 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per
UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
66 A
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
66 A
Rated voltage UL (Use Group D)
600 V
Rated current UL (Use Group D)
5 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
66 A
Rated voltage CSA (Use Group C)
300 V
Rated current CSA (Use Group C)
66 A
Rated voltage CSA (Use Group D)
600 V
Rated current CSA (Use Group D)
5 A
Rated voltage UL 1977
600 V
Hansastr. 27
32423 Minden
13.10.2021 Page 4/9
600 V
Rated current UL 1977
85 A
Connection data
Total number of potentials
5
Number of connection types
1
Number of levels
1
Pole No.
5
Physical data
Pin spacing
10.16 mm / 0.4 inch
Width
52.1 mm / 2.051 inch
Height
20.5 mm / 0.807 inch
Height from the surface
16.5 mm / 0.65 inch
Depth
32 mm / 1.26 inch
Solder pin length
4 mm
Solder pin dimensions
1.2 x 1.2 mm
Drilled hole diameter with tolerance
1.7 (+0.1) mm
Plug-in connection
Contact type (pluggable connector)
Male connector/plug
Connector (connection type)
for PCB
Mismating protection
Yes
Mating direction to the PCB
180 °
Locking of plug-in connection
Without
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire male connector (in-line)
Number of solder pins per potential
3
Material data
Color
light gray
Material group
I
Insulation material
Polybutylene terephthalate (PBT)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Hansastr. 27
32423 Minden
13.10.2021 Page 5/9
Contact material
Electrolytic copper (ECu)
Contact plating
silver-plated
Weight
26.8 g
Environmental requirements
Limit temperature range
-60 … +120 °C
Commercial data
PU (SPU)
20 Stück
Packaging type
box
Country of origin
DE
GTIN
4055143735445
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-53084
CSA
C22.2
70180346
KEMA/KEUR
EN 61984
71104731
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
C22.2 No. 158
E45172
UL-Approvals
Logo
Counterpart
Hansastr. 27
32423 Minden
13.10.2021 Page 6/9
Counterpart
Item no.832-1105
1-conductor female connector; lever; Push-in CAGE CLAMP®; 16 mm²; Pin spacing 10.16 mm; 5-pole; 100%
protected against mismating; Silver-plated contacts; 16,00 mm²; light gray
www.wago.com
/832-1105
Item no.832-1105/037-000
protected against mismating; Lateral locking levers; Silver-plated contacts; 16,00 mm²; light gray
www.wago.com
/832-1105/037000
Item no.832-1105/315-000
protected against mismating; Lateral locking levers; Strain relief plate; Silver-plated contacts; 16,00 mm²; light
gray
www.wago.com
/832-1105/315000
Item no.832-1105/323-000
protected against mismating; Centered locking levers; Silver-plated contacts; 16,00 mm²; light gray
www.wago.com
/832-1105/323000
Item no.832-1105/335-000
protected against mismating; Strain relief plate; Silver-plated contacts; 16,00 mm²; light gray
www.wago.com
/832-1105/335000
Item no.832-1105/345-000
protected against mismating; Centered locking levers; Strain relief plate; Silver-plated contacts; 16,00 mm²; light
gray
www.wago.com
/832-1105/345000
Optional accessories
Coding
Coding
Item no.: 832-500
Coding key carrier; orange
www.wago.com/832-500
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
CAD/CAE-Data
CAD
data
Subject
Hansastr. 27
32423 Minden
13.10.2021 Page 7/9
CAD data
2D/3D Models 832-3645
URL
Download
URL
Download
URL
Download
PCB Design
Symbol and Footprint 832-3645
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 832-3645
Environmental
Product Compliance
Hansastr. 27
32423 Minden
13.10.2021 Page 8/9
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 832-3645
URL
Download
Installation Notes
Coding
Coding a THT male header by inserting a
coding pin.
Product family
MCS MAXI 16
Show all products from the family
Hansastr. 27
32423 Minden
13.10.2021 Page 9/9
很抱歉,暂时无法提供与“832-3645”相匹配的价格&库存,您可以联系我们找货
