Data sheet | Item number: 832-1106/037-000
1-conductor female connector; lever; Push-in CAGE CLAMP®; 16 mm²; Pin
spacing 10.16 mm; 6-pole; 100% protected against mismating; Lateral
locking levers; Silver-plated contacts; 16,00 mm²; light gray
www.wago.com/832-1106/037-000
Color:
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/9
Dimensions in mm
L = (pole no. x pin spacing) + 1.3 mm
Item description
Intuitive and tool-free lever actuation
Universal connection for all conductor types
Push-in termination of solid or ferruled conductors
Test slot 0° and 90° to conductor entry
Coding option available
Data
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors
without breaking capacity in accordance with DIN EN 61984. When
used as intended, these connectors must not be connected
/disconnected when live or under load. The circuit design should
ensure header pins, which can be touched, are not live when
unmated.
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/.
Other pole numbers
Hansastr. 27
32423 Minden
07.10.2021 Page 2/9
Electrical data
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
1000 V
Rated surge voltage (III/3)
8 kV
Rated voltage (III/2)
1000 V
Rated surge voltage (III/2)
8 kV
Nominal voltage (II/2)
1000 V
Rated surge voltage (II/2)
8 kV
Rated current
76 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Approvals per
UL 1059
Rated voltage UL (Use Group B)
600 V
Rated current UL (Use Group B)
66 A
Rated voltage UL (Use Group C)
600 V
Rated current UL (Use Group C)
66 A
Approvals per
CSA
Rated voltage CSA (Use Group B)
600 V
Rated current CSA (Use Group B)
66 A
Rated voltage CSA (Use Group C)
600 V
Rated current CSA (Use Group C)
66 A
Rated voltage UL 1977
600 V
Rated current UL 1977
85 A
Connection data
Total number of connection points
6
Total number of potentials
6
Number of connection types
1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Lever
Solid conductor
0.75 … 16 mm² / 18 … 4 AWG
Fine-stranded conductor
0.75 … 25 mm² / 18 … 4 AWG
Fine-stranded conductor; with insulated ferrule
0.75 … 16 mm²
Fine-stranded conductor; with uninsulated ferrule
0.75 … 16 mm²
Strip length
18 … 20 mm / 0.71 … 0.79 inch
Pole No.
6
Conductor entry direction to mating direction
0 °
Hansastr. 27
32423 Minden
07.10.2021 Page 3/9
0 °
Physical data
Pin spacing
10.16 mm / 0.4 inch
Width
74.26 mm / 2.924 inch
Height
29.1 mm / 1.146 inch
Depth
49.8 mm / 1.961 inch
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Mismating protection
Yes
Locking of plug-in connection
lateral locking lever
Material data
Color
light gray
Material group
I
Insulation material
Polybutylene terephthalate (PBT)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
Material of the additional spring for socket contact
Contact material
Electrolytic copper (ECu)
Contact plating
silver-plated
Color of actuator
orange
Weight
81.6 g
Environmental requirements
Limit temperature range
-60 … +120 °C
Commercial data
PU (SPU)
10 Stück
Packaging type
box
Country of origin
DE
GTIN
4055143736817
Customs tariff number
85366990990
Approvals
/ Certificates
Hansastr. 27
32423 Minden
07.10.2021 Page 4/9
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CB
DEKRA Certification B.V.
IEC 61984
NL-53084
CSA
C22.2
70180346
KEMA/KEUR
EN 61984
71104731
Approval
Certificate
name
UL
Underwriters Laboratories Inc.
C22.2 No. 158
E45172
UL-Approvals
Logo
Counterpart
Item no.832-1206
1-conductor male connector; lever; Push-in CAGE CLAMP®; 16 mm²; Pin spacing 10.16 mm; 6-pole; 100%
protected against mismating; Silver-plated contacts; 16,00 mm²; light gray
www.wago.com
/832-1206
Item no.832-3646
THT male header; 1.2 x 1.2 mm solder pin; straight; 100% protected against mismating; Silver-plated contacts; Pin
spacing 10.16 mm; 6-pole; light gray
www.wago.com
/832-3646
Item no.832-3626
THT male header; 1.2 x 1.2 mm solder pin; angled; 100% protected against mismating; Silver-plated contacts; Pin
www.wago.com
/832-3626
Item no.832-3606
www.wago.com
/832-3606
Optional
accessories
Hansastr. 27
32423 Minden
07.10.2021 Page 5/9
Optional accessories
Ferrule
Ferrule
Item no.: 216-210
Ferrule; Sleeve for 16 mm² / AWG 6; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-210
acc. to DIN 46228, Part 4/09.90; blue
Item no.: 216-284
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-284
Item no.: 216-286
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-286
Item no.: 216-287
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-287
acc. to DIN 46228, Part 4/09.90; gray
Item no.: 216-288
Ferrule; Sleeve for 6 mm² / AWG 10; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-288
acc. to DIN 46228, Part 4/09.90; yellow
Item no.: 216-289
Ferrule; Sleeve for 10 mm² / AWG 8; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-289
acc. to DIN 46228, Part 4/09.90; red
Coding
Coding
Item no.: 832-500
Coding key carrier; orange
www.wago.com/832-500
Strain relief
Strain relief plate
Item no.: 832-534
Strain relief plate; Pin spacing 10.16 mm; light gray
www.wago.com/832-534
Mounting adapter
Mounting accessories
Item no.: 832-1032
Mounting adapter; for DIN-35 rail/panel mounting; Pin spacing 10.16 mm; light gray
www.wago.com/832-1032
Item no.: 832-1038
www.wago.com/832-1038
Downloads
Documentation
Hansastr. 27
32423 Minden
07.10.2021 Page 6/9
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 832-1106/037-000
PCB Design
Symbol and Footprint 832-1106/037-000
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
Hansastr. 27
32423 Minden
07.10.2021 Page 7/9
CAE data
ZUKEN Portal 832-1106/037-000
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 832-1106/037-000
1-conductor female connector; lever; Push-in CAGE CLAMP®; 16 mm²; Pin spacing
10.16 mm; 6-pole; 100% protected against mismating; Lateral locking levers; Silverplated contacts; 16,00 mm²; light gray
Installation Notes
Conductor termination
Insert solid or ferruled conductors via pushin termination
Insert fine-stranded conductors and remove
all conductors via lever
Product family
Hansastr. 27
32423 Minden
07.10.2021 Page 8/9
MCS MAXI 16
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 9/9
很抱歉,暂时无法提供与“832-1106/037-000”相匹配的价格&库存,您可以联系我们找货
