855-3001/125-003
855-3001/125-003
    WAGO(万可电子)
    SPLIT-CORE CURRENT TRANSFORMER;
855-3001/125-003 数据手册
Data sheet | Item number: 855-3001/125-003 Split-core current transformer; Primary rated current: 125 A; Secondary rated current: 1 A; Rated power: 0.2 VA; Accuracy class: 3 www.wago.com/855-3001/125-003 i Picture differs from the item. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/4 Data sheet | Item number: 855-3001/125-003 www.wago.com/855-3001/125-003 Item description Short description: WAGO‘s compact split-core current transformers are ideal for retrofitting existing systems. They are perfect for applications in which the current path must not be disrupted. The transformer’s accuracy permits extremely precise current measurements. The split-core current transformers are capable of supplying the specified rated power at the end of the secondary cable. All transformers are supplied with color-coded cables. Two UV-resistant cable ties are also included for secure and easy mounting. Features: Current ratios from 125 A (primary side) and 1 A (secondary side) No measuring cable interruption Ideal for use in very confined spaces Rapid mounting For use around insulated cables up to 18 mm diameter Compact and hinged Color-coded connecting cable 3 m Data Technical data Accuracy class 3 Primary rated current 125 A Rated continuous thermal current Icth 100 % Rated short-time thermal current Ith 60 x IN / 1 s Rated surge current Idyn 2.5 x Ith Rated frequency 50 … 60 Hz Secondary rated current 1  A Rated power Sr 0.2 VA Safety and protection Highest voltage for equipment Um AC 720 Vrms Protection type IP20 Test voltage AC 3 kV; 50 Hz; 1 min Connection data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/4 Data sheet | Item number: 855-3001/125-003 www.wago.com/855-3001/125-003 Connection data Feedthrough for measurement conductor Ø 18 mm Cable type 2 x 0.5 mm²; fine-stranded Color code brown = S1; blue = S2 Physical data Cable length 3  m Mechanical data Mounting type Split-core current transformer (suspended) Material data Flammability class per UL94 V2 Weight 225 g Environmental requirements Surrounding air temperature (operation) -10 … 55 °C Surrounding air temperature (storage) -20 … 70 °C Relative humidity 5 … 85 % (without condensation) Operating altitude (max.) 2000 m Standards and specifications Standards/Specifications EN 61869-1 EN 61869-2 Commercial data PU (SPU) 1 Stück Packaging type box Country of origin NL GTIN 4055143950732 Customs tariff number 85043180888 Downloads Documentation Bid Text docx - Datei Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com docx Download Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/4 Data sheet | Item number: 855-3001/125-003 www.wago.com/855-3001/125-003 docx - Datei docx 15.4 kB Download X81 - Datei xml 5.3 kB Download pdf 832.5 kB Download 1.0.7.9 The full setup, in addition to the WAGO Interface Configuration Software G2, includes Apr 8, 2021 the installation for the Microsoft .NET Framework. exe 114.0 MB Download WAGO Interface Configuration Software G2 SMALL exe 30.0 MB Download URL Download Instruction Leaflet Kabelumbau-Stromwandler V 1.1.0 Jan 15, 2020 Engineering-Software Software for Interface-Products WAGO Interface Configuration Software G2 FULL The full setup only includes the WAGO Interface Configuration Software G2. 1.0.7.9 Apr 8, 2021 Environmental Product Compliance Compliance Search Environmental Product Compliance 855-3001/125-003 Split-core current transformer; Primary rated current: 125 A; Secondary rated current: 1 A; Rated power: 0.2 VA; Accuracy class: 3 Installation Notes Installation Simple termination! Quick and easy mounting! Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/4
855-3001/125-003 价格&库存
很抱歉,暂时无法提供与“855-3001/125-003”相匹配的价格&库存,您可以联系我们找货
