Data sheet | Item number: 858-517
Relay module; Nominal input voltage: 115 VAC; 4 changeover contacts;
Limiting continuous current: 5 A; with gold contacts; with manual operation;
Red status indicator; Module width: 31 mm
www.wago.com/858-517
i
Picture differs from the item.
DC load limit curve
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/8
Data
Notes
Note
To prevent damaging the gold layer, 30 VDC switching voltages and
50 mA currents must not be exceeded. Higher switching power
eventually evaporates the gold layer. The resulting deposits in the
housing may reduce service life.
Technical data
Number of changeover/switchover contacts
4
Contact material (relay)
AgCe + Au
5 A
Inrush current (resistive) (max.)
(AC) 15 A / 4 s
Switching voltage (max.)
AC 250 V
Switching power (resistive) (max.)
AC 1250 VA; DC (see load limit curve)
Switching capacity
AC-15: 1 A / AC 240 V; DC-13: 2 A / DC 24 V
Recommended minimum load
5 V / 1 mA / 50 mW
Pull-in time (typ.)
25 ms
Drop-out time (typ.)
35 ms
Bounce time (typ.)
4 ms
Electrical life (NO; resistive load; 23 °C)
100 x 103 switching operations
Mechanical life
20 x 106 switching operations
Nominal input voltage UN
AC 115 V
Input voltage range
-20 … +10 %
Nominal input current at UN
10 mA
Rated voltage
300 V
Rated surge voltage
2.5 kV
Pollution degree
2
Dielectric strength, control/load circuit (AC, 1 min)
1.5 kVrms
Dielectric strength, open contact (AC, 1 min)
1 kVrms
Dielectric strength, load/load circuit (AC, 1 min)
1.5 kVrms
Insulation type (control/load circuit)
Basic insulation
Insulation type (load/load circuit)
Basic insulation
Insulation type (adjacent devices)
Reinforced insulation (safe isolation)
Protection type
IP20
Hansastr. 27
32423 Minden
07.10.2021 Page 2/8
Protection type
IP20
Status indicator
Red LED
Mechanical
Connection data
Connection technology
Push-in CAGE CLAMP®
Solid conductor
0.34 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor
Strip length
9 … 10 mm / 0.35 … 0.39 inch
Note (conductor cross-section)
2 x 0.34 … 2 x 1.5 mm² / 1 x 2.5 mm² / 2 x 22 … 2 x 16 AWG
Physical data
Width
31 mm / 1.22 inch
Height
97 mm / 3.819 inch
Depth from upper edge of DIN-rail
73 mm / 2.874 inch
Mechanical data
Mounting type
DIN-35 rail
Mounting position
horizontal (standing/lying); vertical
Material data
Fire load
1.226 MJ
Weight
95.3 g
Environmental requirements
Surrounding air temperature (operation at UN)
-25 … 70 °C
Surrounding air (operating) temperature for UL
-25 … 50 °C
Surrounding air temperature (storage)
-40 … 70 °C
Processing temperature
-25 … +50 °C
Relative humidity
5 … 85 %
Operating altitude (max.)
2000 m
Standards and specifications
Standards/Specifications
EN 61010-2-201
EN 61810-1
EN 61373
Hansastr. 27
32423 Minden
07.10.2021 Page 3/8
EN 61373
UL 508 (max. 50 °C)
Commercial data
Product Group
6 (Interface Electronics)
PU (SPU)
5 Stück
Packaging type
box
Country of origin
DE
GTIN
4055143567855
Customs tariff number
85364900990
Approvals / Certificates
UL-Approvals
Logo
Approval
Additional Approval Text
UL
UL International Netherlands B.V. (ORDINARY
LOCATIONS)
UL 508
Certificate
name
E175199
Sec.6
Optional accessories
Indicators
Operation status indicator
Item no.: 788-124
Accessories for relay modules; Operation status indicator: red
www.wago.com/788-124
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Ferrule
Ferrule
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; www.wago.com/216-243
acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
Tool
Operating tool
Hansastr. 27
32423 Minden
07.10.2021 Page 4/8
Operating tool
Item no.: 210-719
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft
www.wago.com/210-719
Marking accessories
Marking strip
Item no.: 2009-110
Marking strips; for Smart Printer; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Marking device
Item no.: 210-110
Fiber-tip pen
www.wago.com/210-110
Double marker carrier
Item no.: 209-128
Adaptor; gray
www.wago.com/209-128
Protective marker cover
Item no.: 209-184
Protection cover; transparent
www.wago.com/209-184
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 209-183
Marker card; white
www.wago.com/209-183
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-502
WMB marking card; as card; MARKED; 1 ... 10 (10x); not stretchable; Horizontal marking; snap-on type;
white
www.wago.com/793-502
Marker
Item no.: 793-503
WMB marking card; as card; MARKED; 11 ... 20 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-503
white
Item no.: 793-504
WMB marking card; as card; MARKED; 21 ... 30 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-504
white
Item no.: 793-505
WMB marking card; as card; MARKED; 31 ... 40 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-505
white
Item no.: 793-506
WMB marking card; as card; MARKED; 41 ... 50 (10x); not stretchable; Horizontal marking; snap-on type; www.wago.com/793-506
white
Item no.: 793-566
Hansastr. 27
32423 Minden
07.10.2021 Page 5/8
Item no.: 793-566
WMB marking card; as card; MARKED; 1 ... 50 (2x); not stretchable; Horizontal marking; snap-on type;
white
www.wago.com/793-566
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
type; white
Group marker carrier
Item no.: 209-145
Group marker carrier; white
www.wago.com/209-145
Item no.: 249-105
Group marker carrier; gray
www.wago.com/249-105
Item no.: 858-402
Jumper
www.wago.com/858-402
Jumpers
Jumper
Downloads
Documentation
Bid Text
858-517
Feb 20, 2019
docx
17.8 kB
Download
Feb 19, 2019
xml
5.2 kB
Download
pdf
2.6 MB
Download
pdf
265.8 kB
Download
docx - Datei
858-517
X81 - Datei
Instruction Leaflet
Stecksockel für Elementarrelais
Additional Information
Disposal; Electrical and electronic equipment, Packaging
V 1.0.0
CAD/CAE-Data
CAE data
Hansastr. 27
32423 Minden
07.10.2021 Page 6/8
EPLAN Data Portal 858-517
URL
Download
WSCAD Universe 858-517
URL
Download
ZUKEN Portal 858-517
URL
Download
URL
Download
URL
Download
CAD data
2D/3D Models 858-517
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 858-517
Relay module; Nominal input voltage: 115 VAC; 4 changeover contacts; Limiting
continuous current: 5 A; with gold contacts; with manual operation; Red status
Installation Notes
Commoning
Removing a jumper via screwdriver.
Marking
Hansastr. 27
32423 Minden
07.10.2021 Page 7/8
Marking using WMB Multi markers and group
marker carriers.
Hansastr. 27
32423 Minden
07.10.2021 Page 8/8
很抱歉,暂时无法提供与“858-517”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+260.585151+33.77680
- 5+241.242745+31.26966
