770-715
770-715
    WAGO(万可电子)
    P=10mm
    接线端子 间距:10.00mm 1x5P 面板安装,卡入式
770-715 数据手册
Data sheet | Item number: 770-715 Snap-in plug; 5-pole; Cod. A; 4,00 mm²; black www.wago.com/770-715 Color: Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 1/8 Data sheet | Item number: 770-715 www.wago.com/770-715 Item description Protected against mismating and maintenance-free Push-in CAGE CLAMP® spring pressure connection technology allows solid conductors to be simply pushed into a unit. Two wire connections per pole for loops or bridges Additional variable coding is possible. Data Electrical data Note on contact resistance approx. 1 mΩ of contact resistance approx. 0.25 mΩ contact transition plug/socket Ratings per IEC/EN Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 400 V Rated surge voltage (III/3) 6 kV Rated current 25 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Ratings per UL Hinweis für den amerikanischen Markt Some versions may also be used for current interruption in accordance with the UL certificate in select applications with currents below 16 A and voltages up to 600 V. For further information, please contact your local sales office. Rated voltage UL 1977 600 V Rated current UL 1977 23 A Connection data Total number of connection points 10 Total number of potentials 5 Ground function preceding ground contact Connection 1 Connection technology Push-in CAGE CLAMP® Actuation type Operating tool Push-in Nominal cross-section 4 mm² Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 2/8 Data sheet | Item number: 770-715 www.wago.com/770-715 Nominal cross-section 4 mm² Solid conductor 0.5 … 4 mm² / 20 … 12 AWG Solid conductor; push-in termination 1.5 … 4 mm² / 16 … 12 AWG Stranded conductor 0.5 … 2.5 mm² / 20 … 14 AWG Fine-stranded conductor 0.5 … 4 mm² / 20 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 1.5 mm² / 20 … 16 AWG Fine-stranded conductor; with uninsulated ferrule 0.25 … 2.5 mm² / 20 … 14 AWG Fine-stranded conductor; with ferrule; push-in termination 1.5 mm² / 16 AWG Strip length 9 mm / 0.35 inch Pole No. 5 Conductor entry direction to mating direction 0  ° Physical data Pin spacing 10 mm / 0.394 inch Width 55.5 mm / 2.185 inch Height 18.5 mm / 0.728 inch Depth 36 mm / 1.417 inch Mechanical data Application General mains applications Coding A Marking N ⏚ L1 L2 L3 Potentialkennzeichnung N ⏚ L1 L2 L3 Mating force of a plug-in connection approx. 20 … 70 N (depending on pole number) Retention force of a plug-in connection Locked: > 80 N Unmating force of a plug-in connection Unlocked: approx. 20 … 70 N (depending on pole number) Number of mating cycles 200, without resistive load Housing sheet thickness 0.5 … 2 mm / 0.02 … 0.079 inch Mounting type Snap-in Protection class IP20; When mated: IP2xC (These compact connectors are not designed for use in open, easily accessible areas!) Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for conductor Mismating protection Yes Note on mismating protection All WINSTA® components are 100% protected against mismating when: Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 3/8 Data sheet | Item number: 770-715 www.wago.com/770-715 All WINSTA® components are 100% protected against mismating when: a.) plugging different numbers of poles b.) plugging while rotated 180  c.) plugging while laterally staggered d.) plugging one pole Locking lever yes Locking of plug-in connection locking lever Hinweis zur Verriegelung All connectors for mounted installations (snap-in versions for lighting fixtures or devices, all types of PCB and distribution connectors) are factory-equipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for flying leads (plug/socket). Material data Note on material data Information on material data can be found here Color black Insulation material Polyamide (PA66) Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper or copper alloy (surface-treated) Fire load 0.402 MJ Weight 19.3 g Environmental requirements Processing temperature -5 … +40 °C Continuous operating temperature -35 … +85 °C Note on continuous operating temperature Insulating parts for temperatures ≤ 105 °C Commercial data Product Group 20 (WINSTA) PU (SPU) 50 Each Packaging type box Country of origin DE GTIN 4055143375870 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text CCA EN 61535 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate name 2173495.02 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 4/8 Data sheet | Item number: 770-715 www.wago.com/770-715 CCA DEKRA Certification B.V. EN 61535 2173495.02 CCA DEKRA Certification B.V. IEC 61535 NL-32105 Approval Additional Approval Text ABS American Bureau of Shipping - 19HG1868589PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001Z6 LR Lloyds Register IEC 61984 02/20050 (E6) Ship Approvals Logo Certificate name UL-Approvals Logo Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.770-105 Socket; with strain relief housing; 5-pole; Cod. A; 4,00 mm²; black www.wago.com/770-105 Item no.770-205 Socket; 5-pole; Cod. A; 4,00 mm²; black www.wago.com/770-205 Item no.770-405 Socket; 5-pole; Cod. A; 4,00 mm²; black www.wago.com/770-405 Item no.771-9995/006-101 pre-assembled interconnecting cable; Eca; Socket/plug; 5-pole; Cod. A; H05VV-F 5G 1.5 mm²; 1 m; 1,50 mm²; black www.wago.com/771-9995 /006-101 Item no.770-305 Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/770-305 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 5/8 Data sheet | Item number: 770-715 www.wago.com/770-715 Item no.770-305 Socket; with strain relief housing; 5-pole; Cod. A; 4,00 mm²; black www.wago.com/770-305 Item no.771-9995/106-101 pre-assembled connecting cable; Eca; Socket/open-ended; 5-pole; Cod. A; H05VV-F 5G 1.5 mm²; 1 m; 1,50 mm²; black www.wago.com/771-9995 /106-101 Optional accessories Tool     Operating tool Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Downloads Documentation Bid Text 770-715 Feb 19, 2019 xml 3.0 kB Download Jun 8, 2015 doc 23.6 kB Download pdf 126.2 kB Download URL Download ZUKEN Portal 770-715 URL Download WSCAD Universe 770-715 URL Download EPLAN Data Portal 770-715 URL Download X81 - Datei 770-715 doc - Datei Additional Information CAD/CAE-Data CAD data 2D/3D Models 770-715 CAE data Environmental Product Compliance Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 6/8 Data sheet | Item number: 770-715 www.wago.com/770-715 Environmental Product Compliance Compliance Search Environmental Product Compliance 770-715 URL Download Snap-in plug; 5-pole; Cod. A; 4,00 mm²; black Installation Notes Conductor termination 1. Strip length, outer insulation = 35 mm (2pole), 55 mm (3- to 5-pole) 2. Strip length = 9 mm To terminate fine-stranded conductors, open the clamping unit via screwdriver (2.5 mm blade width) and insert a stripped conductor until it hits the backstop. Insert the stripped solid conductor until it hits the backstop. 3. Extended ground conductor = 8 mm To terminate fine-stranded conductors, open the clamping unit via screwdriver (2.5 mm blade width) and insert a stripped conductor until it hits the backstop. Conductor removal Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 7/8 Data sheet | Item number: 770-715 www.wago.com/770-715 To remove the conductor, actuate the clamp via screwdriver (2.5 mm blade width) and pull out the conductor. Seal unused cutout with lockout cap. Product family WINSTA® MIDI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 02.12.2021    Page 8/8
770-715 价格&库存
很抱歉,暂时无法提供与“770-715”相匹配的价格&库存,您可以联系我们找货
  • 1+53.172511+6.90684
