Data sheet | Item number: 769-106/022-000
1-conductor female connector, angled; CAGE CLAMP®; 4 mm²; Pin spacing
5 mm; 6-pole; 4,00 mm²; gray
www.wago.com/769-106/022-000
i
Picture differs from the item.
Color:
Item description
According to EN 61984, pluggable connectors without current interrupting capacity must not be mated or unmated when live or under load.
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/8
Data
Notes
Safety information 1
under load.
Electrical data
Ratings per
IEC/EN 61984
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
32 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
6
Total number of potentials
6
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Nominal cross-section
4 mm²
Solid conductor
0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Pole No.
6
Wiring direction
Front-entry wiring
Physical data
Width
30 mm / 1.181 inch
Height
37.1 mm / 1.461 inch
Depth
26.5 mm / 1.043 inch
Module width
5 mm / 0.197 inch
Mechanical data
Marking level
Side marking
Plug-in
connection
Hansastr. 27
32423 Minden
07.10.2021 Page 2/8
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Material data
Color
gray
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Fire load
0.263 MJ
Weight
14 g
Commercial data
Product Group
18 (X-COM-System)
PU (SPU)
25 Stück
Packaging type
box
Country of origin
DE
GTIN
4044918547581
Customs tariff number
85366990990
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7626
CCA
EN 61984
2190419.02
CCA
IEC 61984
NL-47799
/A1
CSA
C22.2 No. 158
1101144
KEMA/KEUR
EN 60947
2190419.01
Hansastr. 27
32423 Minden
07.10.2021 Page 3/8
Ship Approvals
Logo
Approval
ABS
American Bureau of Shipping
EN 60947
Certificate
name
20HG1941090PDA
UL-Approvals
Logo
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172
UR
UL 1977
E45171
Optional accessories
Ferrule
Ferrule
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-101
Item no.: 216-104
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-104
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-206
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; blue
www.wago.com/216-206
Item no.: 216-202
Hansastr. 27
32423 Minden
www.wago.com/216-202
07.10.2021 Page 4/8
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
Item no.: 216-204
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-204
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Marking accessories
Marker
Item no.: 2009-145
www.wago.com/2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 248-501
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/248-501
Testing and measuring
Testing accessories
Item no.: 210-136
Test plug; 2 mm Ø; with 500 mm cable; red
www.wago.com/210-136
Item no.: 769-1606
Strain relief housing; gray
www.wago.com/769-1606
Item no.: 769-413
Strain relief plate; gray
www.wago.com/769-413
Strain relief
Strain relief
Tool
Operating tool
Item no.: 769-434
Push-button; loose
www.wago.com/769-434
Protective warning marker
Cover
Item no.: 280-415
Protective warning marker; for 5 terminal blocks; with high-voltage symbol, black; yellow
www.wago.com/280-415
Insulation stop
Insulation stop
Hansastr. 27
32423 Minden
07.10.2021 Page 5/8
Insulation stop
Item no.: 769-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/769-470
Item no.: 769-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/769-471
Item no.: 769-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray
www.wago.com/769-472
Downloads
Documentation
Bid Text
769-106/022-000
Oct 4, 2017
doc
26.6 kB
Download
Feb 19, 2019
xml
3.2 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 769-106/022-000
URL
Download
WSCAD Universe 769-106/022-000
URL
Download
ZUKEN Portal 769-106/022-000
URL
Download
URL
Download
URL
Download
doc - Datei
769-106/022-000
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 769-106/022-000
CAE data
Hansastr. 27
32423 Minden
07.10.2021 Page 6/8
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 769-106/022-000
URL
Download
1-conductor female connector, angled; CAGE CLAMP®; 4 mm²; Pin spacing 5 mm; 6pole; 4,00 mm²; gray
Installation Notes
Coding
Coding a female plug by removing coding
finger(s) via cutting tool. Do not remove the
first and last coding fingers or use an
additional locking lever.
Locking system
Locking/releasing a lever.
Marking
Hansastr. 27
32423 Minden
07.10.2021 Page 7/8
Labeling a female plug with CAGE CLAMP®
connection via Mini-WSB Quick Markers.
Product family
X-COM
Show all products from the family
Hansastr. 27
32423 Minden
07.10.2021 Page 8/8
很抱歉,暂时无法提供与“769-106/022-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+175.648811+22.83919
