Data sheet | Item number: 869-155
2-conductor terminal strip; without push-buttons; with snap-in mounting
feet; 5-pole; for plate thickness 0.6 - 1.2 mm; Fixing hole 3.5 + 0.1 mm Ø; 2.5
mm²; CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/869-155
i
Picture differs from the item.
Color:
Data
Notes
Safety information 1
Max. insulation diameter: 4.4 mm
Electrical data
Nominal voltage (III/3)
500 V
Rated surge voltage (III/3)
6 kV
Rated current
24 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Connection data
Total number of connection points
10
Total number of potentials
5
Number of levels
1
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
07.10.2021 Page 1/14
Number of levels
1
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor
0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor; with insulated ferrule
0.08 … 1.5 mm² / 28 … 14 AWG
Strip length
6 … 7 mm / 0.24 … 0.28 inch
Pole No.
5
Wiring direction
Front-entry wiring
Physical data
Width
27.5 mm / 1.083 inch
Height from the surface
27.6 mm / 1.087 inch
Depth
33.4 mm / 1.315 inch
Module width
5 mm / 0.197 inch
Mechanical data
Design
horizontal type
Mounting type
Snap-in foot
Marking level
Side marking
Material data
Color
gray
Flammability class per UL94
V0
Fire load
0.409 MJ
Weight
22 g
Commercial data
PU (SPU)
100 Stück
Packaging type
box
Country of origin
DE
GTIN
4044918481175
Customs tariff number
85369010000
Hansastr. 27
32423 Minden
07.10.2021 Page 2/14
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2143311.02
CCA
EN 60947
NTR NL
6827/A1
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1059
E45172
Optional accessories
Protective warning marker
Cover
Item no.: 280-405
Protective warning marker; for 5 terminal blocks; with high-voltage symbol, black; yellow
www.wago.com/280-405
Item no.: 216-123
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-123
Ferrule
Ferrule
Hansastr. 27
32423 Minden
07.10.2021 Page 3/14
Item no.: 216-122
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-122
Item no.: 216-124
Ferrule; Sleeve for 1.5 mm² / AWG 16; uninsulated; electro-tin plated
www.wago.com/216-124
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24; uninsulated; electro-tin plated
www.wago.com/216-132
Item no.: 216-121
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-121
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-223
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-223
Item no.: 216-222
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-222
Item no.: 216-221
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-221
Item no.: 216-224
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; black
www.wago.com/216-224
Item no.: 216-321
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-321
Item no.: 216-322
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-322
Item no.: 870-402
Jumper; 2-way; insulated; light gray
www.wago.com/870-402
Item no.: 870-404
Push-in type jumper bar; insulated; 4-way; Nominal current 18 A; light gray
www.wago.com/870-404
Item no.: 870-405
Jumper; 5-way; insulated; light gray
www.wago.com/870-405
Item no.: 870-407
Jumper; 7-way; insulated; light gray
www.wago.com/870-407
Item no.: 870-407/011-000
Ready-made push-in type jumper bar; insulated; 1-3-5-7; Nominal current 18 A; light gray
/011-000
Jumpers
Jumper
Item no.: 870-408
Hansastr. 27
32423 Minden
07.10.2021 Page 4/14
Item no.: 870-408
Jumper; 8-way; insulated; light gray
www.wago.com/870-408
Item no.: 870-403
Jumper; 3-way; insulated; light gray
www.wago.com/870-403
Item no.: 870-409
Jumper; 9-way; insulated; light gray
www.wago.com/870-409
Item no.: 870-409/011-000
Ready-made push-in type jumper bar; insulated; 1-3-5-7-9; Nominal current 18 A; light gray
/011-000
Item no.: 870-406
Jumper; 6-way; insulated; light gray
www.wago.com/870-406
Item no.: 870-405/011-000
Ready-made push-in type jumper bar; insulated; 3-way (1-3-5); Nominal current 18 A; light gray
/011-000
Item no.: 870-433
Jumper; from 1 to 3; insulated; light gray
www.wago.com/870-433
Item no.: 870-435
Jumper; from 1 to 5; insulated; light gray
www.wago.com/870-435
Item no.: 870-410
Push-in type jumper bar; insulated; 10-way; Nominal current 18 A; light gray
www.wago.com/870-410
Item no.: 870-434
Jumper; from 1 to 4; insulated; light gray
www.wago.com/870-434
Item no.: 870-440
Push-in type jumper bar; insulated; from 1 to 10; Nominal current 18 A; light gray
www.wago.com/870-440
Item no.: 870-406/020-000
Delta jumper; insulated; light gray
/020-000
Marking accessories
Marking strip
Item no.: 709-196
Marking strips; for laser printer; translucent
www.wago.com/709-196
Item no.: 709-178
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; white
www.wago.com/709-178
Hansastr. 27
32423 Minden
07.10.2021 Page 5/14
Item no.: 709-177
Marking strips; on reel; 7.5 mm wide; not stretchable; plain; snap-on type; translucent
www.wago.com/709-177
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
www.wago.com/2009-115
/000-002
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Marker
Item no.: 2009-145/000-006
www.wago.com/2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue /000-006
Item no.: 2009-145
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 2009-145/000-002
yellow
/000-002
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray /000-007
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; 1700 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-012
orange
/000-012
Item no.: 2009-145/000-023
Hansastr. 27
32423 Minden
07.10.2021 Page 6/14
green
/000-023
Item no.: 2009-145/000-024
violet
/000-024
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
www.wago.com/248-501
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-005
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-5501/000-007
Hansastr. 27
32423 Minden
07.10.2021 Page 7/14
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap-on www.wago.com/793-5501
/000-007
type; gray
Item no.: 793-5501/000-012
/000-012
type; orange
Item no.: 793-5501/000-017
/000-017
type; green
Item no.: 793-5501/000-023
/000-023
type; light green
Item no.: 793-5501/000-024
/000-024
type; violet
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
www.wago.com/793-501
/000-002
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-006
Hansastr. 27
32423 Minden
07.10.2021 Page 8/14
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501/000-005
/000-005
type; red
Item no.: 793-5501/000-002
/000-002
type; yellow
Item no.: 793-5501/000-006
/000-006
type; blue
Item no.: 793-5501
type; white
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Mounting
Mounting accessories
Item no.: 209-120
Mounting foot; can be snapped on terminal blocks with snap-in mounting foot; for mounting on relaymodules; 6.4 mm wide; gray
www.wago.com/209-120
Carrier rail
Item no.: 210-154
Hansastr. 27
32423 Minden
07.10.2021 Page 9/14
Item no.: 210-154
Aluminum carrier rail; 1000 mm long; 18 mm wide; 7 mm high; silver-colored
www.wago.com/210-154
Testing and measuring
Testing accessories
Item no.: 870-425
Tap-off module; with anti-rotation protection; modular; suitable for 870 Series terminal blocks with
jumper slots in the current bar; gray
www.wago.com/870-425
Item no.: 870-426
Tap-off module; modular; suitable for 870 Series terminal blocks with jumper slots in the current bar;
gray
www.wago.com/870-426
Item no.: 870-427
Spacer module; modular; bridging commoned terminal blocks; gray
www.wago.com/870-427
Insulation stop
Insulation stop
Item no.: 280-472
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip
www.wago.com/280-472
Item no.: 280-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/280-470
Item no.: 280-471
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/280-471
Tool
Operating tool
Item no.: 210-657
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; short; multicoloured
www.wago.com/210-657
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short; multicoloured
www.wago.com/210-658
Item no.: 210-720
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; multicoloured
www.wago.com/210-720
Downloads
Documentation
Bid Text
869-155
Jun 14, 2017
doc
24.6 kB
Download
Feb 19, 2019
xml
3.2 kB
Download
doc - Datei
869-155
X81 - Datei
Hansastr. 27
32423 Minden
07.10.2021 Page 10/14
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
ZUKEN Portal 869-155
URL
Download
WSCAD Universe 869-155
URL
Download
URL
Download
CAD/CAE-Data
CAD data
2D/3D Models 869-155
CAE data
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 869-155
2-conductor terminal strip; without push-buttons; with snap-in mounting feet; 5-pole;
for plate thickness 0.6 - 1.2 mm; Fixing hole 3.5 + 0.1 mm Ø; 2.5 mm²; CAGE CLAMP®;
2,50 mm²; gray
Installation Notes
Commoning
Hansastr. 27
32423 Minden
07.10.2021 Page 11/14
Push jumper bars down firmly until fully
inserted. When using multipole bars, push
alternately on the right and then left side
until installed.
Push-in type jumper bars 1 – 3 – 5 – 7 or
1 – – 4 – – 7
upon request
Mounting a terminal strip with snap-in feet
into holes.
onto aluminum rail.
Terminal strip with snap-in mounting feet:
End plate
Center terminal blocks with/without
End terminal block with/without
Hansastr. 27
32423 Minden
07.10.2021 Page 12/14
Terminal strips with snap-in mounting feet,
for 0.6 … 1.2 mm plate thickness,
mounting holes: 3.5+ 0.1 mm Ø
Cover
Protective warning markers (280‑405), with a
black high-voltage symbol
Marking
Hansastr. 27
32423 Minden
07.10.2021 Page 13/14
WMB markers in Mini-WSB marker slots
Translucent marking strip
Mini-WSB markers
Hansastr. 27
32423 Minden
07.10.2021 Page 14/14
很抱歉,暂时无法提供与“869-155”相匹配的价格&库存,您可以联系我们找货
