890-254
890-254
    WAGO(万可电子)
    P=4.4mm
    接线端子 间距:4.40mm 1x4P 自由悬挂
890-254 数据手册
Data sheet | Item number: 890-254 Plug; 4-pole; 1,50 mm²; gray www.wago.com/890-254 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 1/10 Data sheet | Item number: 890-254 www.wago.com/890-254 Item description Male connector/plug WINSTA® MINI 4-pole Use effective pluggable connections instead of laborious screw connections: With the WINSTA® MINI male connector/plug with protection against mismating. On PCBs, in control cabinets or for connecting lights – pluggable installation connectors from WAGO allow you to establish connections according to various requirements in no time flat. The color coding and mechanical coding of the pluggable installation connector ensure error-free installation of the individual components – including protection against mismating. Pluggable installation connectors with B coding from the WINSTA® MINI line are available in pink, light grey, or grey, allowing you to distinguish different circuits, for example for light, pumps or, sun blinds. Your own pole marking is possible as well. Especially where space is tight, our smallest pluggable connection system, WINSTA® MINI, consistently displays its advantages. It is very compact, and, with Push-in CAGE CLAMP® spring pressure connection technology, it also can be installed quickly, since the connection is low-maintenance and requires no screw connections. WINSTA® MINI solutions for your electrical installation – protected against mismating and maintenance-free The WINSTA® Pluggable Connection System allows pluggable electrical installation. This significantly reduces the need for servicing and lowers costs. Choose durability and quality – the WINSTA® MINI pluggable installation connector with marking from WAGO makes the installation of electrical components noticeably easier. effective protection against mismating easy tool-free operation, a wide range of coding options with B coding for use in automation of processes, such as lighting technology, among other examples exact dimensions quick replacement of defective units during ongoing operation Data Notes Other versions (or variants) can be requested from WAGO Sales or configured at https://configurator.wago.com/. Other pole markings Electrical data Note on contact resistance approx. 1 mΩ of contact resistance approx. 0.25 mΩ contact transition plug/socket Ratings per IEC/EN 60664-1 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 2/10 Data sheet | Item number: 890-254 www.wago.com/890-254 Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 400 V Rated surge voltage (III/3) 6 kV Rated current 16 A Note on rated current 1 13 A for 3-pole load 10 A for 4-pole load Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Hinweis für den amerikanischen Markt Application note for the U.S. market (USR): Some versions may also be used for current interruption in accordance with the UL certificate in select applications with currents below 5 A and voltages up to 600 V. For further information, please contact your local sales office. Rated voltage UL 1977 600 V Rated current UL 1977 12 A Connection data Total number of connection points 4 Total number of potentials 4 Connection technology Push-in CAGE CLAMP® Actuation type Operating tool Push-in Nominal cross-section 1.5 mm² Solid conductor 0.25 … 1.5 mm² / 22 … 16 AWG Solid conductor; push-in termination 0.75 … 1.5 mm² / 20 … 16 AWG Stranded conductor 0.25 … 1 mm² / 22 … 18 AWG Fine-stranded conductor 0.25 … 1.5 mm² / 22 … 16 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 0.75 mm² / 22 … 20 AWG Fine-stranded conductor; with uninsulated ferrule 0.25 … 0.75 mm² / 22 … 20 AWG Fine-stranded conductor; with ferrule; push-in termination 0.75 mm² / 20 AWG Strip length 9 mm / 0.35 inch Pole No. 4 Conductor entry direction to mating direction 0  ° Physical data Pin spacing 4.4 mm / 0.173 inch Width 19.2 mm / 0.756 inch Height 11.7 mm / 0.461 inch Depth 34.1 mm / 1.343 inch Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 3/10 Data sheet | Item number: 890-254 www.wago.com/890-254 Mechanical data Application Measurement and regulation technology Coding B Marking 1234 Potentialkennzeichnung 1234 Mating force of a plug-in connection approx. 20 … 70 N (depending on pole number) Retention force of a plug-in connection Locked: > 80 N Unmating force of a plug-in connection Unlocked: approx. 20 … 70 N (depending on pole number) Number of mating cycles 200, without resistive load Protection class IP20; IP40 when mated with strain relief housing Plug-in connection Contact type (pluggable connector) Male connector/plug Connector (connection type) for conductor Mismating protection Yes Note on mismating protection All WINSTA® components are 100% protected against mismating when: a.) plugging different numbers of poles b.) plugging while rotated 180  c.) plugging while laterally staggered d.) plugging one pole Locking lever Can be retrofitted Locking of plug-in connection locking lever Hinweis zur Verriegelung All connectors for mounted installations (snap-in versions for lighting fixtures or devices, all types of PCB and distribution connectors) are factory-equipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for flying leads (plug/socket). Material data Color gray Insulation material Polyamide (PA66) Clamping spring material Chrome nickel spring steel (CrNi) Contact material Copper or copper alloy (surface-treated) Fire load 0.099 MJ Weight 4.6 g Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 4/10 Data sheet | Item number: 890-254 www.wago.com/890-254 Environmental requirements Processing temperature -5 … +40 °C Continuous operating temperature -35 … +85 °C Note on continuous operating temperature Insulating parts for temperatures ≤ 105 °C Commercial data Product Group 20 (WINSTA) PU (SPU) 50 Stück Packaging type box Country of origin PL GTIN 4055143523660 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CB DEKRA Certification B.V. IEC 61984 NL-64351 CB DEKRA Certification B.V. EN 61984 71-112993 KEMA/KEUR DEKRA Certification B.V. EN 60320 2148952.04 Approval Additional Approval Text Certificate name DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001Z6 LR Lloyds Register EN 61535 08/20047 (E2) Ship Approvals Logo UL-Approvals Logo Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Certificate Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 5/10 Data sheet | Item number: 890-254 www.wago.com/890-254 Logo Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.890-1631 T-distribution connector; 4-pole; Cod. B; 1 input; 2 outputs; 2 locking levers; gray www.wago.com/890-1631 Item no.890-1681 www.wago.com/890-1681 h-distribution connector; 4-pole; Cod. B; 1 input; 2 outputs; outputs on one side; 2 locking levers; gray Item no.890-1731 T-distribution connector; 4-pole; Cod. B; 1 input; 2 outputs; 3 locking levers; for flying leads; gray www.wago.com/890-1731 Item no.890-1734 3-way distribution connector; 4-pole; Cod. B; 1 input; 3 outputs; gray www.wago.com/890-1734 Item no.890-1781 h-distribution connector; 4-pole; Cod. B; 1 input; 2 outputs; outputs on one side; 3 locking levers; for flying leads; gray www.wago.com/890-1781 Item no.890-244 Socket; 4-pole; Cod. B; 1,50 mm²; gray www.wago.com/890-244 Item no.890-744 Snap-in socket; 4-pole; Cod. B; 1,50 mm²; gray www.wago.com/890-744 Item no.890-844 Socket for PCBs; straight; 4-pole; Cod. B; gray www.wago.com/890-844 Item no.890-844/011-000 Socket for PCBs; angled; 4-pole; Cod. B; gray www.wago.com/890-844 /011-000 Item no.891-8994/005-103 pre-assembled interconnecting cable; Eca; Socket/plug; 4-pole; Cod. B; Control cable 4 x 1.0 mm²; 1 m; 1,00 mm²; gray www.wago.com/891-8994 /005-103 Item no.891-8994/105-103 www.wago.com/891-8994 pre-assembled connecting cable; Eca; Socket/open-ended; 4-pole; Cod. B; Control cable 4 x 1.0 mm²; /105-103 1 m; 1,00 mm²; gray Required accessories Strain relief     Strain relief housing Item no.: 890-504 Strain relief housing; 4-pole; with locking clip; for 1 cable; 6.5 … 10.5 mm; 45 mm; black www.wago.com/890-504 Item no.: 890-514 Strain relief housing; 4-pole; with locking clip; for 1 cable; 6.5 … 10.5 mm; 45 mm; white www.wago.com/890-514 Locking levers     Locking device Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 6/10 Data sheet | Item number: 890-254 www.wago.com/890-254     Locking device Item no.: 890-111 Locking lever; for flying leads; for tool operation; black www.wago.com/890-111 Item no.: 890-101 Locking lever; for manual operation; black www.wago.com/890-101 Item no.: 890-121 Locking lever; for manual operation; white www.wago.com/890-121 Item no.: 890-131 Locking lever; for flying leads; for tool operation; white www.wago.com/890-131 Optional accessories Cover     Other Item no.: 897-2003 Protective cap; Type2; for sockets and plugs; PVC; red www.wago.com/897-2003 Tool     Operating tool Item no.: 210-719 Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft www.wago.com/210-719 Downloads Documentation Bid Text 890-254 Jun 8, 2015 doc 24.1 kB Download Feb 19, 2019 xml 3.0 kB Download WSCAD Universe 890-254 URL Download ZUKEN Portal 890-254 URL Download doc - Datei 890-254 X81 - Datei CAD/CAE-Data CAE data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 7/10 Data sheet | Item number: 890-254 www.wago.com/890-254 CAD data 2D/3D Models 890-254 URL Download URL Download Environmental Product Compliance Compliance Search Environmental Product Compliance 890-254 Plug; 4-pole; 1,50 mm²; gray Installation Notes Conductor termination 1. Strip length, outer insulation = 30 mm (2pole), 37 mm (3-pole), 45 mm (4- and 5-pole) 2. Strip length = 9 mm 3. Extended ground conductor = 8 mm To terminate fine-stranded conductors, open the clamping unit via screwdriver – 2.5 mm blade width – and insert a stripped conductor until it hits the backstop. Terminate solid conductors by simply pushing them in. To terminate fine-stranded conductors, open clamping units via operating tool (890382) and insert stripped conductors until they hit backstop. Terminate solid conductors by simply pushing them in. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 8/10 Data sheet | Item number: 890-254 www.wago.com/890-254 To terminate fine-stranded conductors, open clamping units via operating tool (890383) and insert stripped conductors until they hit backstop. Terminate solid conductors by simply pushing them in. Installation Latch the wired connector into the base of the strain relief housing. Push down strain relief clamp by hand. Push down strain relief clamp with 2.5 mm screwdriver alternately on both sides. Latch the top of the strain relief housing. Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 9/10 Data sheet | Item number: 890-254 www.wago.com/890-254 The printed marking of the connector is clearly visible in the openings of the strain relief housing. Mismating protection B-coded connectors with different colors can be plugged together. Important note: Different colors and/or pole markings are used for circuit identification. Only connectors of the same color and same pole marking must be plugged together. B-coded connectors (shown in gray) not only differ in color, but also in their design, making them incompatible with other coded connectors. Product family WINSTA® MINI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 07.10.2021    Page 10/10
890-254 价格&库存
很抱歉,暂时无法提供与“890-254”相匹配的价格&库存,您可以联系我们找货
