890-684
890-684
    WAGO(万可电子)
    接线端子 自由悬挂
890-684 数据手册
Data sheet | Item number: 890-684 h-distribution connector; 3-pole; Cod. A; 1 input; 2 outputs; outputs on one side; 2 locking levers; white www.wago.com/890-684 Color: Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 1/7 Data sheet | Item number: 890-684 www.wago.com/890-684 Item description Distribution connector WINSTA® MINI 3-pole For signal and power transmission: The WINSTA® MINI distribution connector 3-pole. WAGO pluggable installation connectors are used when requirements repeat or are distributed on a defined grid, for example for installing grid lighting or flush-mount lighting. For greater security in electrical installations, the pluggable installation connector is equipped with mechanical protection against mismating. Standard mains applications for almost any domain of use can be realised with WINSTA® MINI pluggable installation connectors with A coding. WINSTA® MINI follows the trend towards miniaturisation. Our smallest pluggable connection system is especially suitable for lights, for example, since as a result of LED technology; due to complex systems, these offer much less space for the connection technology. Push-in CAGE CLAMP® spring pressure connection technology – pluggable installation instead of laborious screw connections! The WINSTA® Pluggable Connection System allows pluggable electrical installation. This significantly reduces the need for servicing and lowers costs. Choose durability and quality – the WINSTA® MINI pluggable installation connector with protection against mismating from WAGO makes the installation of electrical components visibly easier. pluggable installation connectors with protection against mismating consistent IP40 protection suitable for any application custom-engineered solutions convenient installation and commissioning Data Electrical data Note on contact resistance approx. 1 mΩ of contact resistance approx. 0.25 mΩ contact transition plug/socket Ratings per IEC/EN 60664-1 Nominal voltage (III/3) 250 V Rated surge voltage (III/3) 4 kV Rated current 16 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Hinweis für den amerikanischen Markt Application note for the U.S. market (USR): Some versions may also be used for current interruption in accordance with the UL Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 2/7 Data sheet | Item number: 890-684 www.wago.com/890-684 be used for current interruption in accordance with the UL certificate in select applications with currents below 5 A and voltages up to 600 V. For further information, please contact your local sales office. Rated voltage UL 1977 600 V Rated current UL 1977 14 A Connection data Total number of potentials 3 Ground function preceding ground contact Pole No. 3 Physical data Pin spacing 4.4 mm / 0.173 inch Width 16.4 mm / 0.646 inch Height 29 mm / 1.142 inch Depth 57.85 mm / 2.278 inch Mechanical data Application General mains applications Coding A Marking L⏚N Potentialkennzeichnung L⏚N Mating force of a plug-in connection approx. 20 … 70 N (depending on pole number) Retention force of a plug-in connection When locked: > 80 N Unmating force of a plug-in connection Unlocked: approx. 20 … 70 N (depending on pole number) Number of mating cycles 200, without resistive load Distributor type h-distribution connector (unidirectional) Protection class IP20; IP40 when mated Plug-in connection Contact type (pluggable connector) Socket/plug Mismating protection Yes Note on mismating protection All WINSTA® components are 100% protected against mismating when: a.) plugging different numbers of poles b.) plugging while rotated 180  c.) plugging while laterally staggered Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 3/7 Data sheet | Item number: 890-684 www.wago.com/890-684 c.) plugging while laterally staggered d.) plugging one pole Locking lever yes Locking of plug-in connection locking lever Hinweis zur Verriegelung All connectors for mounted installations (snap-in versions for lighting fixtures or devices, all types of PCB and distribution connectors) are factory-equipped with locking levers to ensure plugs and sockets are securely locked. Additional locking levers are only required for flying leads (plug/socket). Material data Color white Insulation material Polyamide (PA66) Contact material Copper or copper alloy (surface-treated) Fire load 0.237 MJ Weight 13.4 g Environmental requirements Processing temperature -5 … +40 °C Continuous operating temperature -35 … +85 °C Note on continuous operating temperature Insulating parts for temperatures ≤ 105 °C Commercial data Product Group 20 (WINSTA) PU (SPU) 50 Stück Packaging type box Country of origin DE GTIN 4045454404451 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 61535 71-11299 CCA IEC 61535 DEKRA Certification B.V. Subject to changes. Please also observe the further product documentation! NL-64352 Logo WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 4/7 Data sheet | Item number: 890-684 www.wago.com/890-684 CCA DEKRA Certification B.V. IEC 61535 NL-64352 Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping Steel Vessel Rules 19HG1869855PDA DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001Z6 LR Lloyds Register EN 61535 08/20047 (E2) UL-Approvals Logo Approval Additional Approval Text Certificate name cURus Underwriters Laboratories Inc. UL 1977 E45171 Counterpart Item no.890-123 Socket; with strain relief housing; 3-pole; Cod. A; 1,50 mm²; white www.wago.com/890-123 Item no.890-133 Plug; with strain relief housing; 3-pole; 1,50 mm²; white www.wago.com/890-133 Item no.890-223 Socket; 3-pole; Cod. A; 1,50 mm²; white www.wago.com/890-223 Item no.890-233 Plug; 3-pole; 1,50 mm²; white www.wago.com/890-233 Item no.891-8993/005-102 pre-assembled interconnecting cable; Eca; Socket/plug; 3-pole; Cod. A; 1 m; 1,00 mm²; white www.wago.com/891-8993/005-102 Item no.891-8993/105-102 www.wago.com/891-8993/105-102 pre-assembled connecting cable; Eca; Socket/open-ended; 3-pole; Cod. A; 1 m; 1,00 mm²; white Item no.891-8993/205-102 pre-assembled connecting cable; Eca; Plug/open-ended; 3-pole; Cod. A; 1 m; 1,00 mm²; white www.wago.com/891-8993/205-102 Required accessories Mounting     Mounting accessories Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 5/7 Data sheet | Item number: 890-684 www.wago.com/890-684     Mounting accessories Item no.: 890-623 Mounting plate; 3-pole; for distribution connectors; Plastic; black www.wago.com/890-623 Item no.: 890-673 Mounting plate; 3-pole; for distribution connectors; Plastic; white www.wago.com/890-673 Downloads Documentation Bid Text 890-684 Nov 30, 2018 doc 23.0 kB Download Feb 19, 2019 xml 2.8 kB Download URL Download EPLAN Data Portal 890-684 URL Download WSCAD Universe 890-684 URL Download ZUKEN Portal 890-684 URL Download URL Download doc - Datei 890-684 X81 - Datei CAD/CAE-Data CAD data 2D/3D Models 890-684 CAE data Environmental Product Compliance Compliance Search Environmental Product Compliance 890-684 h-distribution connector; 3-pole; Cod. A; 1 input; 2 outputs; outputs on one side; 2 locking levers; white Installation Notes Installation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 6/7 Data sheet | Item number: 890-684 www.wago.com/890-684 Installation Secure the mounting plate via pins. Product family WINSTA® MINI Show all products from the family Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 13.10.2021    Page 7/7
890-684 价格&库存
很抱歉,暂时无法提供与“890-684”相匹配的价格&库存,您可以联系我们找货
  • 1+96.771401+12.55601
